the snappiest adsr eg of the world schematic
Page 4 of 4 [82 Posts]
mosheen
PostPosted: Thu Feb 13, 2014 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I built one of these tonight. Works great. My function generator is starting to sound like a synth finally. Laughing
siri
PostPosted: Tue Apr 07, 2015 9:51 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Just made a layout for 4U systems.
I only :
- made smoother traces
- added a MTA-156 pad
- spaced the pots 3/4" center to center.
Apart for that the rest is the same, you can use the parts layout provided by frequency central.
enjoy Very Happy
Preview
 Filesize:  69.06 KB
 Viewed:  7458 Time(s)
FC_ADSR-4U-LAYOUT.pdf
Ready to print
 Filename:  FC_ADSR-4U-LAYOUT.pdf
 Filesize:  26.54 KB
 Downloaded:  552 Time(s)
jbeuckm
Audio files: 9
PostPosted: Fri Aug 28, 2015 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the FrequencyCentral layout from the post 29/12/11 verified? It says "verified ... 30/12/11" on the image but he talks about needing to verify it in the post. Then he mentioned just having verified the layout on the 31st. Confused Question
isak
PostPosted: Fri Aug 28, 2015 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there Smile
i built 2 X FC EG's, from a PDF.
use the attached file in my post, its verified by me.
enjoy Smile
Roland-100M-ADSR-Build-Rev-2-Doc.pdf
 Filename:  Roland-100M-ADSR-Build-Rev-2-Doc.pdf
 Filesize:  377.76 KB
 Downloaded:  795 Time(s)
LFLab
PostPosted: Fri Aug 28, 2015 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built three of of this layout, actually changed the layout to allow for 9mm Alpha pots.
Rick sells the PCBs plus panels.
jbeuckm
Audio files: 9
PostPosted: Sat Aug 29, 2015 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I just built my first from the PDF. It's the fastest and simplest envelope I have built. The adjustment is nice even with my linear pots - log must be really great. I want 100 of these Smile
CNC layout: https://github.com/jbeuckm/Roland-140-EG
Working with these substitutions: 2N3904 (flipped), BC556, TL071, TL082
Sethkaine
PostPosted: Sat Oct 03, 2015 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had built this Magnificent Module with long sliders! very impressive control! I want to build all Roland diy modules.
my youtube channel - https://www.youtube.com/user/SethKaine/videos
my paper mix - https://paper.fiftythree.com/1865071
