today> Twyndyllyngs Chez Mosc
The DoubleDeka Ultrasonic VCO
Page 6 of 6 [145 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6
frijitz
Audio files: 54
PostPosted: Sun Jul 25, 2010 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Abby Normal wrote:
What size screws are needed for the front panel to slider mounting? I have 2-56 size screws, but they don't seem to fit. It seems like the wrong thread pitch.
According to the Alpha data sheet, the screws are M2 x .4 . Did you not get screws with the kit?
I'm also wondering if I'm missing any documentation. All I have is the dd_board_doc.pdf. Is there anything else that I might be missing?
No, that's it. I can work with you on any issues or questions you have. Just let me know.
Ian
Abby Normal
PostPosted: Sun Jul 25, 2010 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian.. For some reason, I didn't think the kit came with screws. I looked in the bag and they are there. Scott doesn't leave anything out, does he? Smile
bridechamber
PostPosted: Mon Jul 26, 2010 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, don't say that -- I do!
I'm glad I didn't this time, though.
Smile
schmidtc
PostPosted: Mon Oct 22, 2012 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian, the link to the documentation on your site looks to be broken. Is there some other corner of the internet where I might find the info I need to get building? Thanks!
frijitz
Audio files: 54
PostPosted: Mon Oct 22, 2012 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately I had to take down a lot of material because of the Blue Lantern debacle. Did you buy a board or a kit from Bridechamber? If so, Scott should have emailed the docs to you.
Ian
PostPosted: Tue Oct 23, 2012 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
any plans on doing a slider PCB for eurorack, ian?
frijitz
Audio files: 54
PostPosted: Tue Oct 23, 2012 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Laurie is doing the DD in Euro. I think it's almost finished.
Ian
schmidtc
PostPosted: Tue Oct 23, 2012 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Turns out, the build docs were buried in my hard drive
LED-man
PostPosted: Fri Oct 09, 2015 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
i have ordered the great VCO and miss the documentation specially BOM
where i can find this ?
frijitz
Audio files: 54
PostPosted: Fri Oct 09, 2015 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Which version did you order?
LED-man
PostPosted: Fri Oct 09, 2015 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
From bridechamber the MOTM version
sduck
PostPosted: Fri Oct 09, 2015 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
He should send it you when you order it - but he sometimes forgets, so don't be afraid to ask him for it again.
frijitz
Audio files: 54
PostPosted: Sat Oct 10, 2015 3:56 pm    Post subject: DD docs Reply with quote  Mark this post and the followings unread
Sent by PM.
Ian
LED-man
PostPosted: Sat Oct 10, 2015 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
davebr
PostPosted: Thu Oct 29, 2015 10:56 pm    Post subject: DoubleDeka Reply with quote  Mark this post and the followings unread
I just finished my DoubleDeka build using the Bridechamber kit. It came out pretty nice. I did a couple of minor mods on it. Photos, details and scope images on my page at http://modularsynthesis.com/bridechamber/doubledeka/doubledeka.htm. I used 0.5" square potentiometers and made an aluminum bracket for it. And yes, I did wire my octave switches backwards initially also.
LED-man
PostPosted: Tue Feb 19, 2019 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I’m looking for the BOM and the buildguide which was offered many years ago by bridechamber.
Starspawn
PostPosted: Tue Feb 19, 2019 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave, I tried your mods but it seems like the comparator for HF out at 12V is a bit off, could you suggest an alternate value for resistors 12V?
PostPosted: Tue Feb 19, 2019 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got curious about this vco, is there a way to have a look at schematics?
I’m not going to build it or make money out of it in any way, just interested from a technical point of view...
my synth
vladosh
Audio files: 51
PostPosted: Fri Feb 22, 2019 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
the schematics are http://ijfritz.byethost4.com/sy_cir15_DD_link.htm ,thanks to Ian for that ,for me it would take 3 pcb's at least to make it Very Happy
piedwagtail
PostPosted: Mon Feb 25, 2019 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I did it with 3 pcbs :mother/daughter/slider- used 4022 for 8 faders and 4040 for mega division. Jumpers rather than rotary.
As there's a lot of 4070 real estate sitting around looking for Chinese (pcb) investors- I implemented a /8 digital sine with a 4520 from Don Lancaster.
R
