2017 Build Photos!
Page 1 of 5 [102 Posts]
Goto page: 1, 2, 3, 4, 5 Next
PostPosted: Fri Jan 06, 2017 4:56 am    Post subject: 2017 Build Photos!
Subject description: Show us what you have been building
I was hoping to finish this during the holidaze, but didn't end up having time due to visiting relatives.
CLK-OSC: clock oscillator module for a collective synth at the Eastern Bloc soundLab​ in Montreal... Some basic square wave oscillators: 2 with inverted outs as well, 1 normal, and one with mark & space control (i.e. adjustable duty cycle), all with 2 frequency ranges.
The LEDs are sanded flush with the wooden panel. It's a bit of a mess on the back... it was my first panel rather than a box, and probably it would have been better to mount the panel perpendicular. Oh, well.
.:James:.
Edit: replaced verso photo with updated circuit.
CLK-OSC module panel (front)
 Filesize:  288.84 KB
 Viewed:  638 Time(s)
CLK-OSC module (back)
 Filesize:  200.09 KB
 Viewed:  675 Time(s)
PostPosted: Fri Jan 06, 2017 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
You are off to a great start james Very Happy
Does the dute cycle control work by using diodes to create seperate controls for rise/fall times ?
PostPosted: Fri Jan 06, 2017 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Does the duty cycle control work by using diodes to create separate controls for rise/fall times ?
Yes, exactly. And in this case I used LEDs for the diodes, which will blink in some cases. When I tried using LEDs with a higher forward voltage, it didn't work. Probably using 1N4148's is best, and driving separate indicator LEDs somehow, but I went with a basic circuit I've used before.
.:James:.
PostPosted: Fri Jan 06, 2017 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
ah so that's why I wasn't able to spot any diodes on the PCB. Makes sense about the forward voltage, it will probably depend a bit on the supply
voltage but if it is too large the voltage over the capacitor will never get high enough to go beyond the treshold level of the schmitt trigger inverters.
PostPosted: Fri Jan 06, 2017 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-65656.html
^^ 2016 Smile
J3RK
PostPosted: Fri Jan 06, 2017 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
More of a 2016 project really, but I finished in 2017. Very Happy
 Filesize:  1.94 MB
 Viewed:  666 Time(s)
wackelpeter
Audio files: 10
PostPosted: Fri Jan 06, 2017 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow... Looks really nice and lovely... cheers thumleft
Feel a bit reminded of old Serge modules... Can i ask what modules it contain?
haebbmaster
PostPosted: Fri Jan 06, 2017 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lunetta style synth
Schemactics by Castle Rocktronics
http://castlerocktronics.com/modular.html
4 * LFO, 40106
R2R
 Filesize:  76.37 KB
 Viewed:  594 Time(s)
VCO, LFO, R2R
 Filesize:  88.11 KB
 Viewed:  602 Time(s)
4 * VCO, 40106
 Filesize:  77.92 KB
 Viewed:  593 Time(s)
Case
 Filesize:  192.64 KB
 Viewed:  574 Time(s)
PostPosted: Fri Jan 06, 2017 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice synth and a nice photo J3RK, would love to see a bit more of it. Love the arcade buttons Razz
I still have a couple of those laying around here which I should use someday, hmm actually I might
have an idea. Thanks for reminding me.
Broadwave
Audio files: 6
PostPosted: Sat Jan 07, 2017 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I've finally finished it - Sparta Synthesizer, based on the ARP Odyssey with an extra VCO (Mono/3 VCO Paraphonic), Patch Points and Aftertouch/Modulation routing. I cheated a bit by using a CME Xkey 37 - I couldn't face all those J-Wires again. Wink
I think I'm done with DIY now - I have no more room left and I need to reclaim my sanity.
Synth DIY Projects
Musical Doodlings
PostPosted: Sun Jan 08, 2017 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Re mark & space / duty cycle control: Since I still had it on the breadboard, I tried using 1N4148's for the diodes and simple transistor drivers for the LEDs, and it works much better. The output wave is cleaner (before, using LEDs, it wouldn't go all the way back down to 0V). With the drivers, the LEDs are good and bright. I had a little bit of space left on the perfboard, so I made the changes... I updated the photo above, so you might spot the diodes now Smile.
.:James:.
J3RK
PostPosted: Mon Jan 09, 2017 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a list.
Panel 1
FlexWave Complex Dual VCO
Dual VCA (my version of the Mike Sims style pre-distortion VCA)
Dynamix (this contains two resonant LPGs, two linear slope generators, stereo output mixer, analog OR mixer to mix slopes)
Panel 2
DXOR (Schottky diode XOR circuit with logic and audio outputs plus a voltage controlled integrator)
DivisiClock (VC clock with /2 /3 and /4 divisions)
Bit Station (shift register based pseudo random CV, digital noise, white noise module)
MicroState Filter (state variable filter with two variable FM inputs, "Ping" input, etc.)
CV Processor/Offset Generator
Audio Mixer
Panel 3
UltraFlop 08 (sequencer with up, down, and pingpong counting, individual gate outputs, a combined gate output (post switches)
Two manual gate and manual DC voltage sections.
Thanks for the kind words!
J3RK
PostPosted: Mon Jan 09, 2017 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I love arcade buttons. I actually occasionally build arcade controllers for MAME use, so I have these around sometimes.
I'll post a couple more pics as soon as I get a chance.
Thanks!!
Also, there are audio demos up here: http://soundcloud.com/drj3rk/sets/stroh-modular-silver-synth
Cfish
PostPosted: Mon Jan 09, 2017 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hay Broadwave. That turned out great. Watched it throughout your progress.awesome project.
PostPosted: Mon Jan 09, 2017 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats the pitfall of building a modular synth: it is never finished!
Very nice build! thumb up
But as the British say: The proof of the pudding is the eating, so... we want sounds too much coffee
PostPosted: Wed Jan 11, 2017 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
haebbmaster: nice looking case Very Happy are you going to fill it up completely or leave the bottom part for patch cables ?
Broadwave: stellar job on that synth Razz I am amazed at how fast it came together. And I agree with Grumble; we want sounds!
haebbmaster
PostPosted: Sat Jan 14, 2017 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you. This will be for cables. But I got two cases of the same type. So maybe only one of them will have space for cables.
MoonBase 69
PostPosted: Mon Jan 16, 2017 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yusynth VCA and Env Gen, Thomas Henry XR2206 VCO, not prettied up the panel is still being finalized.
 Filesize:  473.53 KB
 Viewed:  466 Time(s)
Cfish
PostPosted: Mon Jan 16, 2017 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice sky surfer.
They look to be 5u, however pictures sometimes deceive.
I like how you mounted your boards.
MoonBase 69
PostPosted: Mon Jan 16, 2017 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The older I get the more I appreciate 5U, big knobs and everything out in the open. Ideally there will be normaling of signals coming and going on D connectors with a basic patch hardwired.
PostPosted: Mon Jan 23, 2017 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
My first finished build for 2017: an ARP 4072 VCF module for my euro-rack synth.
more info here
PostPosted: Wed Feb 01, 2017 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
okay, made from a PCB/panel kit, nonetheless, i designed the additional circuitry and the PCB.
DualHaibleWaspVCF by Matthias Herrmann, on Flickr
PostPosted: Wed Feb 01, 2017 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I have not been around for quite a while. Nice to see you are still so productive!
PostPosted: Wed Feb 01, 2017 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks matthias, you are one of my electronic heroes !
Nice looking filter although it could use a couple of yellow knobs Bug squash
PostPosted: Wed Feb 01, 2017 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Ridiculous. Laughing
well, even though it was built in 11/2016 i will post this, since it meets your requirements:
