Thomas Henry LM VCO problem
Page 1 of 1 [21 Posts]
MrZu
PostPosted: Thu Mar 23, 2017 7:47 pm    Post subject: Thomas Henry LM VCO problem
Subject description: It won't work, just silence. Has a voice when touching pins 5 and 7 of the LM13700
Hi everyone!
Has anyone any experience with the Thomas Henry LM VCO?
I breadboarded one after purchasing a copy of An Analogue Synthesizer for the 21st Century.
I double checked all soldering connections, ground and power as well. Everything seems proper. But it won't work, just silence. Confused
I couldn’t find LF444, so I replaced it with TL074, I also used 2N5457 instead of the MPF102. Maybe the LF444 and MPF102 is critical for the layout?
I also noticed that if I touch pins 5 and 7 of the LM13700 I can hear a signal out - for sine out is a sine, for ramp out is a ramp … etc… Fine and Coarse control pots do nothing.
Is anyone familiar with this, or has any idea why I'm getting these results?
Thanks in advance!
PostPosted: Thu Mar 23, 2017 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's your C3?
Polystyrenes are VERY easy to melt. Sounds vaguely like you have no (or insufficient) capacitance until you add your own with your fingers.
Edit:
As for the pots, see whether you get any voltage change at IC2a pin1 when you adjust those pots. If not, you may have a hook-up problem. If you do, perhaps the problem is the 2SA798. Those are fairly rare, you may have gotten a bogus one?
MrZu
PostPosted: Fri Mar 24, 2017 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
elmegil wrote:
What's your C3?
I use ceramic capacitors. Hope it is not critical. Rolling Eyes
I'm not quite sure I make the measurements right Confused , but the voltage across the pot (from the middle pin) and pin 1 of IC2a is shifting when I adjust the pots.
So maybe I've got a bogus one. And that's a pity, because it is not easy to get!
Is there a replacement for 2SA798?
PostPosted: Fri Mar 24, 2017 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Ceramic caps can be ok, but you need good quality and stability there, so a C0G type. Classic "disc" type ceramic caps wouldn't be a good choice.
You should measure from ground to pin 1.
A matched pair of PNP transistors would work in place of the 2SA798. Hand matched or something like the SSM2220.
MrZu
PostPosted: Fri Mar 24, 2017 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
So, the voltage at the pin 1 of IC2a is 11.5V and no change while adjusting the pots. It is about 10V at pin2 (unchangeable). And again checked all connections, and it's ok. No hook-up problem found. dunno
PostPosted: Fri Mar 24, 2017 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
What's your supply voltage?
If I assume 12V, then that sounds like the op amp is stuck at the + rail.
It also sounds like the wiper voltage is changing? (measure before R34/R52, not after, the other side is supposed to be a virtual ground courtesy of the op amp, so you'll see no voltage change there).
That really sounds like something wrong with the op amp itself if your wiring/soldering is ok. In this particular case I would not consider the LF444 to be critical, a TL074 should work just fine.
Are you sure the tempco is in correctly? I could see a problem with your feedback there leading to this kind of thing possibly.
Edit: and don't worry if you don't have a tempco, or don't have another to try. A regular resistor there should work too, it's just that you won't have temp stability.
MrZu
PostPosted: Fri Mar 24, 2017 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
What's your supply voltage? If I assume 12V, then that sounds like the op amp is stuck at the + rail.
Actually, it is 15V Wink I use MFOS PSU.
So voltage across pins 4 and 11 of IC2 is about 14,5V. I noticed that if PSU doesn't supply the VCO the voltage from PSU is about 14,9V Confused
The voltage at R34/R52 is changing by those pots. But after is always 11.5V Confused
I don't have tempo Embarassed I use 2K resistor instead of it. Temp stability is not the main problem Smile
PostPosted: Fri Mar 24, 2017 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
That sounds like something is wrong and pulling too much current.
So your problem is somewhere between the pots and that op amp, or the op amp itself. I'd try swapping it for another.
MrZu
PostPosted: Fri Mar 24, 2017 9:08 pm    Post subject:   Reply with quote  Mark this post and the followings unread
I think so. I try to measure without ICs in the sockets - and it is 14.5V across pins 4 and 11, the same. And try to measure without 2SA798 and then without Q5. Nothing changes.
Without supplying the VCO the voltage from PSU is about 14,9V (across + / - and +/0), but if it supplies the VCO the voltage across +/- is about 14,5 and across +/0 is 14,9. No matter with or without ICs.
I swapped ICs and it doesn't solve the problem Sad And again I've checked every connections and compare it with the schematic. This thing drove me nuts
I can show you the photos, or pcb layout if it helps somehow.
PostPosted: Sat Mar 25, 2017 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
It's worth looking, but I make no promises Smile
MrZu
PostPosted: Sat Mar 25, 2017 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the layout Rolling Eyes
THLMVCO.pdf
 Filename:  THLMVCO.pdf
 Filesize:  160.34 KB
 Downloaded:  883 Time(s)
MrZu
PostPosted: Sat Mar 25, 2017 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
And the PCB... it is without ICs, Q1/Q2 and Q5 Confused
 Filesize:  196.24 KB
 Viewed:  743 Time(s)
 Filesize:  195.2 KB
 Viewed:  751 Time(s)
PostPosted: Sat Mar 25, 2017 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I found 2 problems with your layout, neither of which I'd expect to have anything to do with the issue you've reported Smile
1) you reversed the designators for R7 & R45. I think you have the right values rather than reversing them in your build, but there's not enough resolution on the top-side photo to be sure.
2) The sine round trimmer, R37, is supposed to have the wiper connected to one of the two sides of the trimmer. The symbol with the cross arrow indicates a trimmer that is wired as a rheostat, and it is common to tie the side and the wiper together on one side or the other. I don't think it matters a whole lot which side, it just determines which direction the adjust goes CW vs CCW.
Even if you swapped R7 & R45, neither of these should prevent all outputs.
I think the next thing I'd do is lift one side of R1 and see if adjusting the pots *then* will make that voltage go up and down. That completely disconnects the input section from the expo converter. If the problem is with the input then you still won't get any change, if the problem is with the expo converter or downstream it will start working at pin 1.
PostPosted: Sat Mar 25, 2017 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, you should note that the voltage on pin 1 is not expected to go up and down VERY MUCH. If you have a low resolution meter, it could be that it's been going up and down, but you didn't notice.
The gain on IC2a is 2K / 100K for the coarse adjustment and 2K / 3.3M for the fine adjustment, so a swing of 30V on the coarse is only going to swing about half a volt on pin 1 from all the way up to all the way down.
MrZu
PostPosted: Sat Mar 25, 2017 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
The labels swapped somehow in the CAD. I've noticed it when I build it. So everything in its place Wink
Oh! I've skipped it, and it's ok now, but it doesn't solve the problem Sad
Expo conversion seems alright. So the voltage goes up and down, as you told not very much, it's about 0.5V.
So what should I do next? Confused I'm not good at troubleshooting, but that pure signal that appears when I touch 13700 is kind of clue Smile I can hear it, but can't adjust it Crying or Very sad Anyway I can't touch that chip all the time Very Happy
Or maybe it's 2SA798. Can I check it somehow to find out is it a bogus or not?
PostPosted: Sun Mar 26, 2017 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have a transistor tester? That would be one thing to check, are the transistors checking out OK, testing one at a time since you have the common emitter.
You might also swap the LM13700.
If it's the 2SA798, it would be possible to substitute two hand-matched PNP transistors. Search around here for information on transistor matching, or you could even, if you have transistors on a tape, just pick a couple adjacent ones. Those are usually sufficiently matched to work reasonably well. Doing it this way doesn't really require any particular type of transistor, but be aware of the pinouts and make sure the emitters are tied together at pin 3, then collectors at 2 & 4, and bases at 1 & 5.
MrZu
PostPosted: Sun Mar 26, 2017 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a bunch of the LM13700 with two different batch codes from the different suppliers. I've tried all of them without any success. Anyway I’ve never heard about bogus LM13700 Mad
Actually this is my second TH VCO. A month ago I had no luck with making a XR-VCO work. I tried it with the low supply voltage source for the XR-2206 chip and "correct" batch codes. So I gave up and than I switched to the LMVCO. Rolling Eyes
So I've tested the 2SA798 and it seems ok. Two hand-matched BC557 doesn't solve the problem anyway.
I am close to giving up again Evil or Very Mad
MrZu
PostPosted: Tue Apr 04, 2017 6:04 am    Post subject:   Reply with quote  Mark this post and the followings unread
It works!
My AC Adapter Transformer has a little switch with DC mode. And it was switched on. Laughing So PSU didn't work proper.
Anyway, thanks!
PostPosted: Tue Apr 04, 2017 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Those kinds of issues are simultaneously the best and the worst. Best because they're easy fixes. Worst because they're hard to find. Good job!
Scott Stites
Audio files: 96
PostPosted: Sat Jun 10, 2017 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Elmegil: you rock!
My Site
PostPosted: Sat Jun 10, 2017 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why thank you, Scott Embarassed
