CV for vactrol rhythmic patterns?
Page 2 of 2 [38 Posts]
Goto page: Previous 1, 2
PostPosted: Thu Apr 20, 2017 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Grumble wrote:
I use an Arduino using SPI to control the position of the runner of the DCP.
Ah yes of course, I was just thinking of logic chips and forgot you were talking about an Arduino.
I don't plan on using one for any synth/Lunetta applications, but if others are interested and you wrote a piece about the module, I would certainly read it...
.:James:.
PostPosted: Mon Apr 24, 2017 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
zloth wrote:
Whilst on the subject of DACs, has anyone tried using outputs from a 4026/4033/40110 with other clocks into a DAC to create unusual "polyrhythms" or would that not work from a technical point of view?
Never used any of those chips to control one directly but it might actually be nice to make a simple module using one
similar to a binary and digital counter/divider.
and so I did: 4543 7-segment decoder Cool
gasboss775
PostPosted: Wed Apr 26, 2017 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is probably the best solution.
Its a 4 bit R2R feeding a voltage to current converter to drive the led. This is the best way to drive LEDs when variable brightness is required as the circuit automatically overcomes the Vf of the LED using negative feedback.
 Filesize:  64.79 KB
 Viewed:  419 Time(s)
gasboss775
PostPosted: Wed Apr 26, 2017 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using a binary counter and a 7 segment decoder to provide a complex modulation waveform
 Filesize:  42.04 KB
 Viewed:  437 Time(s)
PostPosted: Wed Apr 26, 2017 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
what kind of decoder did you simulate to get 16 different steps ?
I looked at some datasheets but they all had blank outputs above 9 (10 steps). I do recall seeing one which did have
valid outputs above 9, but I can't remember which one it was.
I was thinking of making it into a synth module with potentiometers on the outputs (like a sequencer) but realized that
it is much easier to get the same results with a standard 10 (or more) step sequencer. I might experiment a bit more with
it as a suboscillator though, maybe add a switch for some different presets. I guess the easiest thing to use for that is some
muxes controlled by a single switch, that could possibly create 12 different ones with a standard rotary switch.
gasboss775
PostPosted: Wed Apr 26, 2017 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aha, I wondered if someone might spot this!
The parts in the simulator are generic. It would seem that it is a binary to hexadecimal decoder, which I think may exist but I'm unsure of a part Number or if such a thing is readily available.
gasboss775
PostPosted: Thu Apr 27, 2017 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I have amended the circuit so that the counter resets at count=10 in other words a decade/BCD counter.
 Filesize:  39.12 KB
 Viewed:  429 Time(s)
PostPosted: Thu Apr 27, 2017 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
That's how I created the 10 steps too but it initially didn't work. The problem was that it would reset as soon as D becomes
high, so it only counted 8 steps. I had the same results with a CD4029 and a CD4040. To solve this I had to introduce a small
delay between output D and the AND gate which I did by chaining 4 gates in series. I used XNOR gates which is what I had
available in my modular lunetta but I guess using the remaing AND gates could have worked as well. Of course if you use
one of those chips with a built in counter it gets a bit easier.
I am actually wondering at the moment how hard it would be to create a reset at any given number of step >2 by uing the
a-g outputs. It is doable but might require a lot of gates. Looks like it could be a nice puzzle though.
gasboss775
PostPosted: Thu Apr 27, 2017 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
available in my modular lunetta but I guess using the remaining AND gates could have worked as well.
I'm guessing that the problem is down to differing propagational delays in the counter, resulting in the "2" output still being high very briefly when the counter flips from count "7" to count "8" something that might work is putting a little RC delay circuit between the AND gate and the reset input of the counter. This saves on having to use up gates, but if you've got spare gates you may as well use them for that.
I've also got some of those 4026 chips with the counter & decoder in one. I seem to recall buying quite a few of them because they were very cheap at the time ( 10p ) as one of the UK component retailers were selling off all of their 4000B CMOS chips. I even managed to snatch a few 4006's Very Happy before they became super rare and super expensive! Evil or Very Mad
PostPosted: Fri Apr 28, 2017 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that is indeed what is causing it and normally I would use an RC network. But I don't seem to have a module for that (maybe
I should build a small delay module) so the gates seem to be a good alternative.
I came up with a circuit to select the number of steps using the a-g outputs. I first checked if there where any redundant outputs
and with that I mean outputs that are not necessary to determine the current step. Turns out that c and d can be left out so that
made things a bit easier. I haven't tested it so don't know if it will work and there might be a better solution. Another option would
be the seperate counter+decoder and convert the binary to decimal to select the number of steps, which could be done with a single
4 bit mux, but the chip count would stay the same and then you might have to add some extra delays again.
I was also thinking that instead of using presets a simple way would be to add 8-position switches to the inputs of the R2R
connected to the 7 outputs a-g (+ an off setting). It would take up more panel space though so I will do some test to see
what is useful. (this would be a for a dedicated subosc synth module btw)
reset for 4 steps doesn't work in this version, updated version posted below
 Filesize:  63.79 KB
 Viewed:  425 Time(s)
gasboss775
PostPosted: Sat Apr 29, 2017 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Another thing that I've tried is to put XOR gates ahead of the R2R one input is from a counter, etc and the other input is connected to a switch. The switch then decides whether the signal is buffered or inverted.
I was thinking of doing this with the 7 segment output going into an R2R. Not sure whether to have a 7 bit R2R or a 4 bit R2R with the option of picking which of the 7 outputs is routed to the R2R inputs via the XOR buffer/inverters.
gasboss775
PostPosted: Sat Apr 29, 2017 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a schematic just to clarify what I was meaning in my last post:
 Filesize:  124.35 KB
 Viewed:  386 Time(s)
PostPosted: Sun May 07, 2017 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just tested the reset circuit and it almost worked except the reset for 4 steps; it resets on 2 steps instead.
In theory it should work but I decided to add an AND gate to the I/O pin of the second mux too. (I actually
had this in the first design and then figured out that it shouldn't be necessary) This AND gate would be
connected to outputs f and g of the CD4026. As with the other mux I was going to use 2 diodes and a resistor
but after I added the diode to output g it already worked. Shocked I am not sure why, but I have an LED display
connected to it so maybe the voltage drops a bit and therefor the reset doesn't properly work, I am using
4.7K series resistors for it though. It might also be caused by the mux itself.
Anyway, it seems to be working fine now so here is the updated version.
 Filesize:  64.69 KB
 Viewed:  366 Time(s)
