2017 Build Photos!
Page 3 of 5 [102 Posts]
Nordl3
PostPosted: Fri Apr 28, 2017 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
My first DIY Case Very Happy
 Filesize:  4.1 MB
 Viewed:  619 Time(s)
 Filesize:  3.88 MB
 Viewed:  637 Time(s)
Nordl3
PostPosted: Fri Apr 28, 2017 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thomas Henry LM-VCO
 Filesize:  4.63 MB
 Viewed:  624 Time(s)
Nordl3
PostPosted: Fri Apr 28, 2017 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
2 x LM13700 FQM's (from the datasheet)
1 X Thomas Henry - Balanced modulator
1 X CGS - Passive Real Ring Mod (LT44's)
 Filesize:  4.77 MB
 Viewed:  610 Time(s)
PostPosted: Fri Apr 28, 2017 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
RingMad wrote:
The Bag Balm Box is "for bunches, caked bags, cuts, sore teats, chapping and inflammation".....
nice bag balm box james, it sounds udderly delicious Laughing
I still have a half built space laying around here myself
that I should finish some day.
Nice work on the case and the modules kevin!
Did you drill all those holes in the rails by hand or did you use the CNC ?
I guess I should post something here too, so here's the latest lunetta
module I built which uses a 4543 binary to 7-segment decoder chip.
more info here
Nordl3
PostPosted: Fri Apr 28, 2017 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers amigo!
Oh no way! Not by hand! Lol
My trusty CNC done all the leg work whilst I relaxed in the next room.
Sanding all those little joints was less enjoyable. Surprised
Groovy case BTW!
intercorni
PostPosted: Mon May 15, 2017 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
PSU Modul
https://scontent.xx.fbcdn.net/v/t1.0-9/18403625_10212556752851147_4079096432139316916_n.jpg?oh=dd8df8f62fd24944014552e2c2f9cecc&oe=597C54CA
LFLab
PostPosted: Mon May 22, 2017 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice, but eurorack power and 6.35mm jacks? That's a new one Very Happy
intercorni
PostPosted: Tue May 23, 2017 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
this is not a Eurorack Wink
Another one
https://scontent.xx.fbcdn.net/v/t1.0-9/18556301_10212655082269321_7632996048532781412_n.jpg?oh=e09a846ccae687eac8ea92933d8cf130&oe=59B541FF
PostPosted: Tue May 23, 2017 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
But the power bus behind it appears to be a TipTop Euro distribution board. Are you making custom cables?
intercorni
PostPosted: Tue May 23, 2017 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I have modified the TipTop Bus Board. Is without 5V regulator and LEDs.
My PSU provide +/- 15V, +/- 12V and +/- 5V.
With custom cables.
PostPosted: Tue May 30, 2017 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmz... don't know why the pics are rotated, but anyway: a new midi input /thru module for my modular.
It is customised for my very old Target midi keyboard and my diy arduino based keyboard (which failes the mod and pitch wheels)
So at the bottom are the midi in and midi thru connectors with a gate output which gives a 5 volt signal as long as a key is pressed and a trigger output which gives a short puls when a key is pushed.
Above that is a clock output that gives triggers that may be used for triggering the sequencer or adsr or what have you.
The repitition rate is set by a potmeter and there is also a cv input to change the rate.
The two outputs above this are 8 bit dac outputs representing the velocity, note number and above those are the 12 bit dac outputs representing the position of the mod and pitch wheel. All four outputs are also controlled by a potmeter and a cv input.
I don't have to worry about the 1v per octave dogma since all modules that have to be in tune with the keyboard are midi controlled.
https://youtu.be/Yul-BRG8Yhw
edit: added some text
 Filesize:  2.65 MB
 Viewed:  452 Time(s)
 Filesize:  3.27 MB
 Viewed:  422 Time(s)
 Filesize:  2.91 MB
 Viewed:  401 Time(s)
PostPosted: Sat Jun 03, 2017 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
if6spaced9 : A temporary "box" for a circuit that will be expanded into a proper enclosure, once some subcircuits are perfected. In the meantime, I needed to get it off the prototype boards and playable in a live situation. The circuit is a slightly expanded version of my Bag Balm Box, specialized for use with a resistive ribbon controller. Thus, it is again based on the Space4069 schematic by Synaesthesia. The name is a cross between "Space4069" and a Jimi Hendrix tune.
.:James:.
 Filesize:  287.19 KB
 Viewed:  348 Time(s)
PostPosted: Sun Jun 04, 2017 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice one james, I like how you got creative with the panel desing Very Happy
PostPosted: Mon Jun 26, 2017 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
my latest DIY project
Nemesis Prototype by Matthias Herrmann, on Flickr
PostPosted: Fri Jul 14, 2017 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Expansion module for the Nine Sixty -- this should be dead useful.
It takes the Stage Out voltages from the 960 (plus the clock) and uses them to create a handy gate sequencer, slaved to the 960. Merge selects whether it's continuous (Gate Out is high for the entire step), or staccato (trigger at the start of each step.)
The small PCB on the back is because I'm a numpty and forgot to mirror the pin header for the expansion cable.
Audio files: 161
PostPosted: Sat Jul 15, 2017 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
wow , nice modules guys Smile
PostPosted: Tue Aug 08, 2017 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Euro SN Voice
 Filesize:  2.36 MB
 Viewed:  355 Time(s)
 Filesize:  2.32 MB
 Viewed:  369 Time(s)
 Filesize:  2.4 MB
 Viewed:  348 Time(s)
 Filesize:  3.77 MB
 Viewed:  329 Time(s)
PostPosted: Tue Aug 08, 2017 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
and a one more pic .... Cool
 Filesize:  2.72 MB
 Viewed:  359 Time(s)
joshco
PostPosted: Wed Aug 09, 2017 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
After almost ten years I finished finally a Rene Schmitz 4069VCO on perfboard Wink
4969VCO
 Filesize:  1.28 MB
 Viewed:  353 Time(s)
Nordl3
PostPosted: Thu Aug 24, 2017 5:14 am    Post subject: Fonitronik--TH-555-VCO Reply with quote  Mark this post and the followings unread
 Filesize:  1.02 MB
 Viewed:  337 Time(s)
Nordl3
PostPosted: Thu Aug 24, 2017 5:17 am    Post subject: YuSynth - Wave Folder Reply with quote  Mark this post and the followings unread
 Filesize:  647.6 KB
 Viewed:  332 Time(s)
Nordl3
PostPosted: Thu Aug 24, 2017 5:18 am    Post subject: Ian Fritz - 5 Pulser Reply with quote  Mark this post and the followings unread
 Filesize:  920.07 KB
 Viewed:  335 Time(s)
wackelpeter
Audio files: 10
PostPosted: Sun Sep 03, 2017 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Spent some days within the last weeks to start a new little case.
Not really finished so far as i have to build in the 4th VCO and some knobs are still on the way, but will be completed soon as i think.
When completed we have here:
4x ASM01 VCO with a Thomas Henry Expo converter
1x Serge triple wave shaper
1x Yusynth saw animator
3xLFO (from the Yusynth saw animator)
1x BPF from the Mutant Vactrol Filter by Scott Stites
Maybe must have a look at the BPF again as it's resonance is a bit too wild for my taste, even with the clipping diode and higher resistors in the feedback path... Guess it has something to do with my home made vactrols and their resistance specs...
Also have to sort the rats nest of wires at least a little bit.
 Filesize:  764.28 KB
 Viewed:  318 Time(s)
 Filesize:  989.11 KB
 Viewed:  337 Time(s)
PostPosted: Sun Sep 03, 2017 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Synth in a Suitcase! I like it, definitely different to the Eurorack suitcases I've seen before.
wackelpeter
Audio files: 10
PostPosted: Sun Sep 03, 2017 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Alan,
for travelling definitely some advantage compared against handling a whole rack. Very Happy
Wish i had enough space left to build some little speakers in.
