piedwagtail
Posted: Mon Sep 04, 2017 6:23 am Post subject:
Quote: | Then there are those head band magnifiers which I haven't tried myself but seem like a good idea. |
I got a cheap pair and found them near on useless. For the high magnification you need have your nose in the work to focus. Great for fume sniffing.
A useful set of plastic lenses perhaps for extra stacking.
It also took a chunk out of my forehead when taking it off, due to a sharp plastic edge.
I'm doing ok with a big desk magnifying glass and a lot of light. And glasses!
looks great PHOBoS
R |
THeff
Audio files: 33
Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Fri Sep 08, 2017 1:33 pm Post subject:
Why would you not want to?  |
Posted: Fri Sep 08, 2017 9:42 pm Post subject:
Check the BOM before you solder the processor into the other two. I'm pretty sure that Clouds uses a newer family of STM32 processor than Braids does. |
DES
Posted: Sat Sep 09, 2017 9:29 am Post subject:
Nice work - as usual! Quite a few years ago I remember we used crazy glue to hold components in place by putting a tiny drop between pads or so it didn't get on them...but it stinks when the heat hits it. Now I have to laugh because if I tried doing smd work now my tremors would make it next to impossible to do. On occasion at work I have to remove bad parts and replace (fuses, Leds, etc) and its frustrating. I've been meaning to look into a hot-air reflow system...they're cheap enough these days. Still, I need to be able to place the part without chasing it around the board.  _________________ Dave
www.davesneed.com |
Posted: Sat Sep 09, 2017 7:28 pm Post subject:
Thanks
Not sure if 'Kragle' would work with the very tiny components but I could see it work with the ICs.
Of course you'd still have to be very careful with placement as you can't change it once it's stuck,
so I think in that regard that solder is more useful. For the DIP chips I started with soldering 1 pin
and if placement was correct I soldered a pin diagonally across it and after a final check soldered
the rest of the pins. Actually pretty much how I usually solder sockets as well. For the processor
I soldered 1 side or at least a couple pins at once and had to reheat & reposition a couple of times
untill I had it correct, before soldering the other pins. I guess for placement something like this would
be ideal but I don't think there are any cheap options for it. Unless you built something yourself. _________________ "My perf, it's full of holes!"
Joined: Apr 03, 2004 Posts: 24444 Location: The Netherlands, Enschede
Audio files: 297
Posted: Wed Sep 20, 2017 11:39 am Post subject:
Pick & place machines use vacuum to pick up components, maybe that is an idea. _________________ Jan
Posted: Wed Sep 20, 2017 12:53 pm Post subject:
I actually have used a manual vacuum pick and place machine in the past (in school) which does indeed work nice. However,
that was with using solder paste. I don't know how well it would hold when you jam a soldering iron against the component.
It seems like there are some DIY options though so I'll look into it. _________________ "My perf, it's full of holes!"
Posted: Wed Sep 20, 2017 11:41 pm Post subject:
My usual tweezers worked fine with Elements -- I have a really cheap pair of eyebrow tweezers from the ladies section of the supermarket.
The only real trouble I have with the tweezers is when I start to get self-conscious and nervous, and my hands resultingly start to shake. |
Posted: Wed Sep 27, 2017 11:42 pm Post subject:
http://www.vo1t.com/Vo1tIllustrated.html
Download the Braids Illustrated Manual from here -- it's very good in explaining what each cryptic WXYZ on the display means. |
Posted: Thu Sep 28, 2017 5:12 am Post subject:
Thank you, I'll check it out
I was already planning to search for a manual since there are some submenu settings besides the wave form selection.
edit: I noticed the order of the waveforms is slightly different and I don't have a HARM setting. I guess I have
a different firmware version, don't know if it's an older one. If I remember correctly it also needs to be calibrated.
(or was that a different MI module ?)
edit2: yep, it looks like I have v1.7. since the bootloader is installed updating should be pretty easy though. _________________ "My perf, it's full of holes!"
Joined: Nov 23, 2015 Posts: 1314 Location: Netherlands
Posted: Sun Oct 01, 2017 1:31 am Post subject:
looking great! very nice project!
Is the colour of the panel etched or reflection of the light?
If it was etched after the toner transfer, do you have a link to the recipe? _________________ my synth |
Joined: Apr 24, 2009 Posts: 2494 Location: Bristol UK
Audio files: 495
