RYO 3x VCA - Stripboard layout help
Page 2 of 2 [41 Posts]
Goto page: Previous 1, 2
BlacKcaT
PostPosted: Wed Jan 24, 2018 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
hey Nardu, you are a master! I will swap the TL084 with a TL074 without any change. Is this ok?
Nardu
PostPosted: Wed Jan 24, 2018 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
BlacKcaT wrote:
....I will swap the TL084 with a TL074 without any change. Is this ok?
puts sockets and tests, usually works
Here the v.3: with the original power input schema. Personally I prefer ferrite bead instead of R1, R2
I corrected the missing link v.2: R3 to V-ref
 Filesize:  239.41 KB
 Viewed:  736 Time(s)
http://nardusynth.blogspot.ro/
Nardu
PostPosted: Thu Jan 25, 2018 1:17 am    Post subject: RYO 2X VCA_v.3 stripboard Lochmaster Reply with quote  Mark this post and the followings unread
Sorry, I found 2 errors: LM324, TL084 must be rotated 180 degrees (in all variants), a wrong connection to VR7 and VR8.
Here,
- RYO 2x VCA top v.3 revised. The attachment RYO 2X VCA_v.3 stripboard.zip, contains the LM4 file.
- RYO 2x VCA v.3 helper, like silkscreen. Print from ryo 2x vca_v.3 silkscreen helper.pdf file 1:1, crop to edges and stick the corners on top side.
Note!, are some connections on bottom side (in all variants).
Use Viewer for LochMaster for printing
RYO 2x VCA v.3 helper, like silkscreen, stripboard, Lochmaster
 Filesize:  179.9 KB
 Viewed:  714 Time(s)
RYO 2x VCA top v.3 revised, stripboard, Lochmaster
 Filesize:  373.42 KB
 Viewed:  739 Time(s)
 Filename:  ryo 2x vca_v.3 silkscreen helper.pdf
 Filesize:  220.18 KB
 Downloaded:  680 Time(s)
RYO 2X VCA v.3 revised, LM4 file, stripboard, Lochmaster
 Filename:  RYO 2X VCA_v.3 stripboard.zip
 Filesize:  382.77 KB
 Downloaded:  688 Time(s)
Ayab
PostPosted: Fri Jan 26, 2018 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Nardu - Greetings and thank you for your generosity sharing these! Laughing
Nardu
PostPosted: Sun Jan 28, 2018 3:31 am    Post subject: RYO 2X VCA_v.3 stripboard Lochmaster, helpers Reply with quote  Mark this post and the followings unread
So you do not miss any spilt points, use this helper. Print from ryo 2x vca_v.3 split points helper.pdf file to 1:1 scale, crop to edges and stick the corners on bottom side.
Note! For any prints for the bottom side you must press the mirror button (vertical)
Use in Lochmaster the Print function (ryo 2x vca_v.3 printing tips.png)
Lochmaster 4.0 printing tips & helpers
 Filesize:  106.85 KB
 Viewed:  697 Time(s)
 Filesize:  168.96 KB
 Viewed:  730 Time(s)
 Filename:  ryo 2x vca_v.3 split points helper.pdf
 Filesize:  72.02 KB
 Downloaded:  639 Time(s)
Ayab
PostPosted: Mon Jan 29, 2018 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Very helpful thank you
Unfortunately have to change heating element in soldering iron before can do any more circuits! Have replacement hope repair goes well!
Nardu
PostPosted: Sun Feb 04, 2018 2:21 am    Post subject:  RYO 2X VCA_v.4 stripboard Lochmaster; a shorter version Reply with quote  Mark this post and the followings unread
By putting some resistors in a vertical position, we obtained a shorter version of only 100mm x 50mm, corresponding to the usual dimensions of the PCB stripboard
RYO 2X VCA_v.4 stripboard Lochmaster; 100mm x 50mm version
 Filesize:  320.63 KB
 Viewed:  743 Time(s)
BlacKcaT
PostPosted: Sun Feb 04, 2018 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
This design is going to be more and more interesting! Surprised
I have a question Nardu, why you choose to use two different op-amp in there? I mean, TL082 and LM324? It is possible, in this design, to use 2 identical one (the TL or the LM), without any change?
thank you for your effort!
Nardu
PostPosted: Sun Feb 04, 2018 7:02 am    Post subject:   Reply with quote  Mark this post and the followings unread
Use TL074 both, has lower noise figure.
I like synth on stripboard. Check this - https://www.indiegogo.com/projects/otto-s-diy-eurorack-modules#/
RYO 2x VCA v.4 short.zip
Lochmaster LM4 file
 Filename:  RYO 2x VCA v.4 short.zip
 Filesize:  371.75 KB
 Downloaded:  561 Time(s)
Nardu
PostPosted: Mon Feb 05, 2018 12:49 pm    Post subject:  Replace LM324 & TL084 Reply with quote  Mark this post and the followings unread
Analyzing the circuit RYO VCA, LM324 (cheaper) is used for CV, work with DC; is not critical. TL084 works with audio and the noise figure (NF) is important; affects the signal-to-noise ratio (SNR). TL074 has lower noise than TL084.
Now, by looking at the calibration instructions - pages 13 & 14, I deduce that you can use other compatible CIs.
Nardu
PostPosted: Tue Feb 13, 2018 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another approach to this project for - an interesting idea on 8HP EuroRack Otto's DIY EuroRack Modules - Facebook Otto's DIY Eurorack User Group
Possible 4xRYO VCA
 Filesize:  266.61 KB
 Viewed:  469 Time(s)
 Filesize:  516.23 KB
 Viewed:  532 Time(s)
gabbagabi
PostPosted: Wed Feb 14, 2018 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one!
BlacKcaT
PostPosted: Thu Feb 15, 2018 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Din't expect to see so much effort! You'r a king Nardu! Cool
Nardu
PostPosted: Tue Feb 20, 2018 11:25 pm    Post subject: RYO 2x VCA Otto's Stripboard-480 version Reply with quote  Mark this post and the followings unread
With potential, Otto's Eurorack modules - Stripboard-480 version
 Filesize:  326.52 KB
 Viewed:  480 Time(s)
kamielsd
PostPosted: Mon Jul 16, 2018 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I just more or less finished recreating RYO 2x VCA top_v.3_corect1.jpg, but when testdriving without the ic's placed it keeps igniting r1. i checked for any short circuit but couldn't find anything, eventually tried minus c1 and c3, but same results, any suggestions?
kamielsd
PostPosted: Tue Jul 17, 2018 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
allready found the problem, accidently manage to short 2 rows somewhere else on the board
