today> Bill Fox solo tonight! Chez Mosc
Yusynth Wavefolder troubleshooting
Page 1 of 2 [26 Posts]
YashN
PostPosted: Tue Apr 17, 2018 7:10 am    Post subject: Yusynth Wavefolder troubleshooting Reply with quote  Mark this post and the followings unread
Built and populated a Yusynth Wavefolder and I am quite happy about it. Merci Yves. Very Happy
I do seem to have a couple of issues. I tested it with my Fonik / Thomas Henry VCO-555 and using on board single turn VRs as that's what I had at hand. Now, the default TH VC0-555 has quite a low Sine output and I still have to mod that. Some settings I tried: VCO Tri into Wavefolder In, VCO Ramp into Wavefolder Control (really cool on some Pot settings!).
Issues:
1. The Shape Pot does sound like it is merely attenuating. I can also see the corresponding effect on my DSO scope.
2. An odd thing happens when I put my DVM +ve on the TL074 P6: my output buzzes (it is as if it now gets the Wavefolder effect out). I also find that when my hand is around the Shape wires or its pot, or just moving it around, that seems to also increase buzz on the output.
3. Both the Range and Control Pots sometimes go: 'No Sound/Low' to 'Big effect' and 'Back to No Sound/Low' depending on settings instead of an expected (IMO) smooth sweep from Nothing/Low to Large Effect.
I cleaned the board again today which seemed to help a bit. I also tested for continuity around the TL074 and R11, R14 and R15 and everything seems fine here.
I have 2 3904 transistors, so if I didn't mess this up, I used them 180 degrees rotated.
YashN
PostPosted: Wed Apr 18, 2018 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Re-tested and re-calibrated. This time I removed my circuit linked to the 1V/Oct to see whether that was making any interference.
VR A1 doesn't seem to do much for me.
Shape still sounds like an attenuator.
I used Sine into Control over a Triangle at Input. It does look like it's wavefolding a little. First, Control to minimum:
And the rest, as I increase the Control Amount:
YashN
PostPosted: Wed Apr 18, 2018 1:34 pm    Post subject: Board pics Reply with quote  Mark this post and the followings unread
Hopefully all components are the right ones. There are 2 or 3 resistors values that I had to do some series combinations as I didn't have the exact values at hand.
How would I really check whether the VCA is working properly or what else should I check?
I left out the CV3 pads untouched.
PostPosted: Thu Apr 19, 2018 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
If you didn't used a 10x probe and these are output voltages, they are very low compared to http://www.yusynth.net/Modular/FR/WAVEFOLDER/wavefolderscope.html.
Also I see some differences according to the populated pcb:
my synth
marfoski
PostPosted: Thu Apr 19, 2018 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
IMHO, 1N4007 diodes are not a direct replacement for 1N4148, being rectifiers and much slower.
Just my two cents, tho
YashN
PostPosted: Thu Apr 19, 2018 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think that explains why I get buzz on the output when probing the TL074 P6.
The issue should be elsewhere IMO. So far, I am thinking something could be bad around the VCA, or else the 1-turn VRs in lieu of the 10-turn trimmers aren't allowing me to calibrate properly.
Apart from that, I am using a +12V, 0, -12V PSU but I think that is OK with this module although output volume may vary.
For the resistors where I had to use 2 or 3 in series to approximate, these aren't specified as precision resistors IIRC, so that should be OK too.
YashN
PostPosted: Thu Apr 19, 2018 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
What's up, Grumble. Yes, I have listed the differences where I can:
1. 3 areas where I used series resistors to approximate the resistor value.
2. Different diodes (shouldn't matter too much for the wavefolding operation but drop can be different and should probably be adjusted).
3. I am using this with a TH VCO-555, which if you don't dig into threads, then the output volume of the Sine is low and I still need to modify that. For now, that explains it. Volume is quite OK with other waveforms.
4. There are 2 3904 instead of BC547. These are the two which are close to each other. I have rotated them 180 degrees after double-checking the pin-outs.
5. 2 one-turn VRs instead of multi-turn trimmers
6. I have a 50K Lin Pot for Shape
Diodes were hand-matched with my DVM.
I also noticed some bleed when only the Control signal is patched in.
YashN
PostPosted: Thu Apr 19, 2018 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you point out these differences?
wackelpeter
Audio files: 10
PostPosted: Fri Apr 20, 2018 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Apart from the diodes that are in the Feedback path of the OPamp and Point in the opposite direction but that wouldn't matter as they're in parallel, i only spotted the trannie on the upper left... when this is not an BC547 and an 2n3904 instead, shouldn't it be rotated by a 180 degree?
YashN
PostPosted: Fri Apr 20, 2018 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is a BC547.
Hubaswift
PostPosted: Sun Apr 22, 2018 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't see any problems with the part values. A picture of the bottom of the pcb would also be helpful.
PostPosted: Sun Apr 22, 2018 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
bottom left resistor, should be 680ohm, you have 332ohm.
my synth
YashN
PostPosted: Mon Apr 23, 2018 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
That should affect solely the input level directly I think. As stated on Yves' site:
R21 680/330 ohms to selected depending on the input levels 1
and
By the way, if you need to modify the voltage range of the input and output signals, it is just a matter of changing the values of R20 & R21 for the input signal and that of R17 & R18 to adjust the output level.
The Shape Pot could be a bit suspect. I'll see if I can swap it for a new one.
There's a possibility I get the multi-turn trimmers today, so I can try those as well.
YashN
PostPosted: Thu Apr 26, 2018 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey @Hubaswift, missed your post. Definitely a good idea. Will do that soon.
YashN
PostPosted: Fri May 18, 2018 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the feedback on the part values, @Hubaswift.
I have since put in the proper trimmers. Haven't swapped the Shape Potentiometer.
Here is a recent pic of the trace side:
Flipped PCB printout for comparison:
YashN
PostPosted: Sat Jul 21, 2018 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any ideas?
How would I test only the VCA part to diagnose it and perhaps troubleshoot it if it's the culprit?
gabbagabi
PostPosted: Mon Jul 23, 2018 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
refering to this schematic http://yusynth.net/Modular/Commun/WAVEFOLDER/wavefolder-schema.gif
u would connect ur probe to pin1 of U2a (before R1) and measure there if a signal goes thru as desired
good luck
edit: do u feed in a 10Vpp signal? or not?
YashN
PostPosted: Mon Jul 23, 2018 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
good luck
Thanks a lot, g.gabba, will check that.
I believe my TH VCO-555 is entirely capable of 10Vpp.
gabbagabi
PostPosted: Mon Jul 23, 2018 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
well,
its better to measure than belive
YashN
PostPosted: Mon Jul 23, 2018 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Already measured. It was a while ago though.
gabbagabi
PostPosted: Tue Jul 24, 2018 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, it was just that the amplitudes looking so low on the scope-shoots
YashN
PostPosted: Tue Jul 24, 2018 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
True, true. I will have to both measure again and re-calibrate: I made quite a lot of modifications on the VCO-555 itself to bring some of the low levels up (like Sine and Triangle, etc...)
I think I might either use a generated signal from Audacity or use my Kurzweil for the 10Vpp instead - will take less time to set up.
romaindegode
PostPosted: Thu Feb 28, 2019 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
No news about your wavefolder ?
YashN
PostPosted: Wed Sep 02, 2020 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
romaindegode wrote:
Salut Romain,
Missed your post, was away for a good while.
Been busy and secondly, I like doing R & D and building things, but I like troubleshooting electronic circuits a lot less Very Happy
Will have to revisit at one point. I have a larger and better scope now, so it could be interesting as there are a few modules that seem to be out-of-whack,
romaindegode
PostPosted: Thu Sep 10, 2020 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hanging around Yusynth website, I manage to find PCBs of Jurgen Haible 's TAU The Pipe Phaser and built it 15 months ago.
That module never worked properly and I probably spent whole days to debug it.
Last week, totally desperate, after too many beers, I had the idea to tap on all the components.
It actually gave me a way to spot few of bad connections , fixed the yelds and... Tadaaaaaa that little man is alive
https://youtu.be/qS8yvIZ00yY
Debugging can be sometimes a little bit funky 😁
