nicolas3141
Joined: May 25, 2007 Posts: 185 Location: Christchurch, New Zealand
drapdap
Posted: Tue May 19, 2009 4:46 am Post subject:
Thank You for sharing this Nicolas, these circuits are really nice work.
I haven't got round to building any of them yet, but this filter was the last straw, im gathering parts now...
i'm not shure i understand the +6v switch on the input tho. Is it just to boost the signal so the resonance behaves well?
Does it tolerate +/- 12 volts, or do i need to raise some resistors?
(Of course i'll try it, but a firsthand answer really won't hurt my ego.)
is there more of these?
thank you a gain
róbert |
nicolas3141
Posted: Tue May 19, 2009 3:07 pm Post subject:
That switch to +6V is my crude way of showing a switched socket that sees +6V when nothing is attached. It doesn't really need to be +6V, any stable +ve voltage would be fine.
To run it on higher voltage up to +/-15V should be fine, but increase the value of R4, R15 and R17 proportionally (say 6k, 14k and 14k or similar).
Nicolas |
loss1234
Dego
Posted: Thu Jun 11, 2009 12:26 pm Post subject:
Built the filter today. But ran in to some problems.
The q pot does not work properly
It just work a little bit of the pots axel. I use a 100k pot just like in the schematics but should it be 10k?
What could else be wrong? |
nicolas3141
Posted: Thu Jun 11, 2009 2:14 pm Post subject:
I am not quite sure what you mean. When I turn the Q pot to 100% my filter rings (oscillates if there is no input). If I back it off a bit to around 70-90% the filter has that resonant wah type sound. Then as I turn it down further it loses the resonance and becomes more like a tone control type filter. Between 0-70% the changes in the sound of the filter are not very dramatic.
Perhaps a log pot would be better here so that we could get better control over the high resonance end and waste less rotation on the low resonance end.
This general type of filter is quite common, but what distinguishes one from the next is the feedback arrangement to provide Q control. So I encourage you to experiment with different pots and types of feedback. Let us know what you find that works.
Nicolas |
Dego
Posted: Sun Jun 14, 2009 1:57 pm Post subject:
It works now. I have the same result when I turn the Q pot now. I think that was what puzzled me was that there was not much action until you get to 70% turned Q pot. After 90 it goes crazy...
I will try later on with a log pot....
So that is number 4 of your designs
ADSR
LFO
VC-LFO
FILTER
Now I look forward to the Sample & Hold and VCA. Is there a ringmodulation as well?
Thanks for your educational and fun designs! |
ogg
Posted: Thu Oct 01, 2009 5:23 pm Post subject:
Filter simulation online |
Hello, I've put an interactive simulation of this filter online at Music circuit simulations. It seems to be working but not entirely, I'm not sure which input is which and I don't think I have the op-amp voltages right. Thought you might like to see it, please send me corrections if you can see any mistakes.
I've credited you, nicolas3141, and linked to this discussion.
Ollie |
Posted: Fri Oct 02, 2009 8:25 am Post subject:
Hey Ollie! to electro-music.com!
I'm afraid this isn't working here (Safari on a MacIntel running OSX). Says it can't read a text file- although I'm getting a screen. A black screen I should add  _________________ ACHTUNG!
Joined: Apr 03, 2004 Posts: 24544 Location: The Netherlands, Enschede
Audio files: 299
Posted: Fri Oct 02, 2009 8:47 am Post subject:
| v-un-v wrote: | | I'm afraid this isn't working here (Safari on a MacIntel running OSX). |
Hmm .. but it does here ... you have an old Java version? _________________ Jan
ogg
Posted: Fri Oct 02, 2009 9:50 am Post subject:
| v-un-v wrote: | Hey Ollie! to electro-music.com!
I'm afraid this isn't working here (Safari on a MacIntel running OSX). Says it can't read a text file- although I'm getting a screen. A black screen I should add  |
Thank you
Occasionally I find the applet doesn't start properly and shows a black screen, usually when I click or right-click on it before it's finished setting up. So you might like to try refreshing, or as Blue Hell suggests you could check you have the latest version of Java, the OS X software update should show you if you don't. |
nicolas3141
Project_2501
Posted: Tue May 01, 2018 1:44 pm Post subject:
New to the party
Does anyone have the wiring layout? Stripboard layout has only one potentiometer (Q pot) which is P3, in schematic, they're 3 total pots right? I am missing something?
Once again, thank you nic for you layouts. I'm slowly building my rig. Ordering a MFOS psu soon  |
gabbagabi
Project_2501
Posted: Wed May 02, 2018 11:48 am Post subject:
I'm learning slowly but surely
To apply that +V, can i just hookup the +V from the power supply to give it a stable voltage? Where's the easiest place to find that +V to that switch socket. Thats the only confusing part for me. |
gabbagabi
Posted: Wed May 02, 2018 9:57 pm Post subject:
we need to know on what voltage u run
and
the resistor-value of the pots u use |
Project_2501
Posted: Wed May 02, 2018 10:08 pm Post subject:
| I'm going to be using a +V/-V 12 wall power supply by mfos. For pots, I guess 100k lin, but I have 10k, 25k, 50k lin available. |
tinfoilcat
Joined: Apr 16, 2019 Posts: 8 Location: Stockholm, Sweden
Posted: Sat Sep 21, 2019 4:11 pm Post subject:
This thread deserves a bump!
I built this filter and added sockets for the diodes. Then I tried red LED:s
Crude video, second part with LED:s (close to max resonance all the time, it is pretty well behaved at lover settings! But slightly more agressive overall): https://www.youtube.com/watch?v=Ig_0-0Mmv3s
Thank you Nicholas! |
