 Forum index » Instruments and Equipment » Ableton
Ableton & Cycling74 partnership
Page 1 of 1 [7 Posts]
cappy2112
PostPosted: Fri Jul 13, 2018 5:48 pm    Post subject: Ableton & Cycling74 partnership
Subject description: This is about a year old, but I didn't see any posts about it here.
Ableton & Cycling74
Ableton & Cycling74
cslammy
PostPosted: Thu Oct 04, 2018 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a post!! Hope this is being posted to the right place?
I just upgraded to suite and got "MAX" along with AL10.
I see tutorials on youtube etc. for Cycling/Max but the UI appears to have changed in Ableton10--in the best Microsoft/Adobe tradition the "furniture has been moved around" although features might be the same?
Q: Are there youtubes/vids with tutorials that reflect the latest GUI for Max? I can muddle through ones with the icons in different places etc. but I am a full newbie here.
Thanks in advance!
cappy2112
PostPosted: Thu Oct 04, 2018 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks in advance!
Are you sure that isn't just Max 8 For Live (as opposed to the full stand-alone Max)?
Max4Live is a subset of Max 8, and there is a lot of mulual exclusivity between the two.
 Filesize:  48.95 KB
 Viewed:  743 Time(s)
cslammy
PostPosted: Mon Oct 08, 2018 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I upgraded from Ableton Live 9 standard to Ableton suite 10. I need a tutorial for whatever version of MAX comes with Ableton suite 10. The Youtube tutorials I have found online so far have a different UI.
Thanks
cappy2112
PostPosted: Mon Oct 08, 2018 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
You should probably post a message on the Ableton or Cycling74 forums.
I'm fairly sure that they bundled Max4Live with Ableton Suite- it makes sense.
It's NOT the stand-alone Max.
cslammy
PostPosted: Tue Oct 09, 2018 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
cappy2112 wrote:
Thanks
Have done that, good suggestion. Thanks.
cappy2112
PostPosted: Tue Oct 09, 2018 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
