first time streamer?
Page 1 of 1 [7 Posts]
laura woodswalker
PostPosted: Mon Sep 09, 2019 5:58 pm    Post subject: first time streamer? Reply with quote  Mark this post and the followings unread
Hi! After going to Neemfest, Bill Fox invited me to be in the Streaming event & I thought I'd try. Never did streaming before. I was never a chatroom person so I'm clueless on that. I did install the Butt software & I don't know what's next.
PostPosted: Tue Sep 10, 2019 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Laura, it would be great if you could participate in a streaming event and if you have BUTT installed you are already on the right track.
you can find some general information about streaming here:
http://electro-music.com/wiki/pmwiki.php?n=Radio.ConnectionDetails
and info on how to set up BUTT here:
http://electro-music.com/wiki/pmwiki.php?n=Radio.ConnectInfoButt
BUTT itself is not very hard to configure but people sometimes run into routing problems when using a DAW. For testing and help setting up
someone might be available in the chatroom but it can be quiet there, especially considering timezones.
Audio files: 309
PostPosted: Wed Sep 11, 2019 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Laura, did you try the links PHOBoS gave? Could you be specific as to what bits you want help with?
laura woodswalker
PostPosted: Thu Sep 12, 2019 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just made it thru the maze & found it. On to the next level!
laura woodswalker
PostPosted: Thu Sep 12, 2019 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, for starters, where is the link to BUTT .16?
JovianPyx
Audio files: 224
PostPosted: Fri Sep 13, 2019 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Laura,
If you've just recently downloaded the BUTT software, then you already have the latest version ( 0.1.18 ). So you should be fine with the software you have.
I know this is a bit frustrating, but there are times during which there is nobody "paying attention" in the chat room. I know I stay logged in constantly, but when I'm busy, the chat window isn't visible. I know I'm not the only one that does that. You might consider checking into the chat room periodically to see if anyone is "alive". Note that as we move closer to the event date, there are usually more people in chat who can do the streaming test and who can help you if there are problems making the connection and doing the stream test.
Hope that helps a bit.
Time flies like a banana.
corruptio optimi pessima
laura woodswalker
PostPosted: Fri Sep 13, 2019 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Laura,
I had the old software from the last attempt I made at streaming. I just googled it & got #18.
OK, I will keep checking back. Thanks. I'm not normally a chatroom user, I usually just hang out on facebook.
