gabbagabi
Joined: Nov 29, 2008 Posts: 652 Location: Berlin by n8
JovianPyx
Audio files: 224
Posted: Wed Feb 19, 2020 3:09 pm Post subject:
If I understand the question, it would seem to be about the Iabc pin.
Iabc current is referenced to -V not ground.
So to completely quiet a VCA made with LM13700, the Iabc pin needs to be at -V.
Also, the Iabc pin can withstand no more than 2 mA of current. Any more current will blow the amplifier (without any magic smoke fun either). So always make sure there is an appropriate resistor or other current limiting device in series with Iabc _________________ FPGA, dsPIC and Fatman Synth Stuff
gabbagabi
Posted: Thu Feb 20, 2020 6:15 am Post subject:
thanks for readindg my mind!
of course the question was about Iabc.
Good to know that neither iam stupid nor the chips  |
JovianPyx
Audio files: 224
Posted: Thu Feb 20, 2020 6:49 am Post subject:
I remember having the same question years ago.
The bit about Iabc being referenced to -V was the crux. _________________ FPGA, dsPIC and Fatman Synth Stuff
gabbagabi
Posted: Thu Feb 20, 2020 6:54 am Post subject:
| ive searched the datasheet up and down, but .... |
JovianPyx
Audio files: 224
Posted: Thu Feb 20, 2020 7:01 am Post subject:
Yeah, I've looked too. At that time, another DIYer on SDIY told me about it. He was an active EE and would have been able to look at the chip internal schematic and see that. _________________ FPGA, dsPIC and Fatman Synth Stuff
Joined: Nov 23, 2015 Posts: 1320 Location: Netherlands
Posted: Thu Feb 20, 2020 3:50 pm Post subject:
it is not that hard to see, and it is in the datasheet as well...
| Description: |
| Filesize: |
119.2 KB |
| Viewed: |
329 Time(s) |
| Description: |
| Filesize: |
123.31 KB |
| Viewed: |
307 Time(s) |
_________________ my synth |
JovianPyx
Audio files: 224
Posted: Thu Feb 20, 2020 4:00 pm Post subject:
I have a National datasheet that doesn't have the text you show, but it does have the schematic and other clues.
I do now see how it works, but when I looked at it (25+ years ago) I didn't see it, though my mentor did. There is also a block diagram that shows an Iabc current sink dumping into -V. _________________ FPGA, dsPIC and Fatman Synth Stuff
ixtern
Posted: Wed Feb 26, 2020 5:53 am Post subject:
It is in LM13700 datasheet - VCA and control voltage needed for it:
| Description: |
| Filesize: |
21.22 KB |
| Viewed: |
5886 Time(s) |
| Description: |
| Filesize: |
29.81 KB |
| Viewed: |
5887 Time(s) |
