4 Channel Quadrature LFO
Page 1 of 1 [8 Posts]
PostPosted: Sat Jan 16, 2021 4:18 am    Post subject: 4 Channel Quadrature LFO
Subject description: Module in progress
my synth
PostPosted: Sun Jan 17, 2021 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm something X Y Cool
PostPosted: Mon Jan 18, 2021 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
What You see here is the output signal of two of the four outputs of a quadrature LFO, four outputs all 90 degrees shifted and the idea is that you can choose 4 different wave forms for each output. I am playing with the idea to construct each wave form out of four parts of the four wave form types, e.g. you can have one output a clean sine wave, while the next consists of for different parts of wave forms, so you can have the first quarter a sine shape, the next quarter a saw part etc.
But that would take some extra programming... but I’m playing with the idea.
The four leds are red/green leds, so when an output is more positive than 2.5 volt it will light up green, lower as 2.5 volt it will light up red.(starting very dim to more brightness)
SCH-quadrature.pdf
 Filename:  SCH-quadrature.pdf
 Filesize:  156.35 KB
 Downloaded:  429 Time(s)
my synth
PostPosted: Mon Jan 18, 2021 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
I'm finding 120 degrees nice to have too BTW Laughing
PostPosted: Mon Jan 18, 2021 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
What is special about 120 degrees?
my synth
PostPosted: Mon Jan 18, 2021 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
That when added up you get constant power.
I use it for (slow) fading three part things, such that the levels can be more or less equal over the course.
Also you can add up two phases to get one inbetween, so a 60 degree phase.
PostPosted: Mon Jan 18, 2021 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
That makes sense... but would require so much more programming...
 Filesize:  878.22 KB
 Viewed:  357 Time(s)
 Filesize:  818.8 KB
 Viewed:  378 Time(s)
my synth
PostPosted: Wed Jan 20, 2021 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Demo (allow for subtitles)
my synth
