today> Twyndyllyngs Chez Mosc
Help Re-creating Moog Matriarch: round-robin voices
Page 1 of 1 [11 Posts]
chapelier fou
PostPosted: Fri Aug 28, 2020 2:22 am    Post subject: Help Re-creating Moog Matriarch: round-robin voices Reply with quote  Mark this post and the followings unread
I have this project of recreating Moog Matriarch's architecture for the 4 voice paraphonic mode.
In this mode, first note is always osc 1, 2nd note osc 2, etc.
Basically, the four oscillator must be "gated" before going to a mixer. I've managed to create the correct algorithm for opening or closing them (with a counter and some logic), but I'm struggling with the pitch.
The whole architecture seems very hard to achieve in the context of how G2 voice allocation works.
Would anyone care to look at the current state of the patch and maybe provide some help ?
Matriarchi_work.pch2
 Filename:  Matriarchi_work.pch2
 Filesize:  1.92 KB
 Downloaded:  943 Time(s)
chapelier fou
PostPosted: Fri Aug 28, 2020 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
stupid me.
two errors in the attached patch.
1. polyphony must be set to mono.
2. the three ValueSwitched must be set to listen to 0, not 64.
Then the round-robin works.
chapelier fou
PostPosted: Fri Aug 28, 2020 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I'm facing another issue with the voice allocation.
You can't hold a note and play notes "on top". Only the first three will work. Anyway to keep track of the number of held notes ?
(missing something like [borax] in Max/MSP if you know what I'm talking about).
chapelier fou
PostPosted: Tue Sep 08, 2020 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone ?
I'd love to know a way to make a predictable round-robin voice allocation.
chapelier fou
PostPosted: Fri Jan 15, 2021 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm still stupidly stuck.
I can't find a way to step through 4 oscillators in a predictable order. Any help would be greatly appreciated.
shhh21
PostPosted: Tue Jan 26, 2021 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey there, I'm pretty sure this not exactly what you had in mind, but I thought I'd still share it due to lack of replies and because your post inspired me to try something out…
nord_2-098-2101_098-A.mp3
 Filename:  nord_2-098-2101_098-A.mp3
 Filesize:  1.82 MB
 Downloaded:  481 Time(s)
2101_098.pch2
 Filename:  2101_098.pch2
 Filesize:  1.79 KB
 Downloaded:  779 Time(s)
2101_099.pch2
 Filename:  2101_099.pch2
 Filesize:  3.19 KB
 Downloaded:  799 Time(s)
chapelier fou
PostPosted: Mon Feb 01, 2021 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
Well the patches you posted are nice but I've been there as well. But they don't solve my voicing issue.
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Feb 27, 2021 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Salut chapelier fou,
I posted a patch with similar features in the past. Can you take a look and tell me if this is what you are looking for?
https://electro-music.com/forum/post-427554.html#427554
Cheers!
chapelier fou
PostPosted: Sun Feb 28, 2021 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately, not... but thanks so much for sharing.
Simple thing to get what doesn't work :
Hit and hold note 1. While holding note 1, hit and hold note 2. While holding note 2, hit and hold note 3. Release note 3 : as a result, you have only osc 1 playing the pitch of note 2.
G2 patch files: 38
PostPosted: Sun Mar 07, 2021 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are right. I found a way to achieve the right result and get around the problem with your specific example.
I replaced the sequencer event modules by the sequencer controlled modules + few other mods. Then I can go back by one step everytime a note is released (by using the Velocity Release output from the Keyboard module).
But this workaround is not working if I change a bit your exemple >
Hit and hold note 1. While holding note 1, hit and hold note 2. While holding note 2, hit and hold note 3. Release note 1 : as a result, you have only osc 1 and osc 2 playing. Issue : Note 1 is still playing.
I have another idea in mind : Use a 'compare module' then send MIDI notes internally with the NoteZone module to match the correct notes/voices. I do not expect any positive results since so many talented people here already tried to find workaround for this problem but I will try. It's very educational for me!
Cheers!
chapelier fou
PostPosted: Mon Mar 08, 2021 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for trying !
