Joined: Apr 03, 2004 Posts: 24498 Location: The Netherlands, Enschede
Posted: Wed Mar 31, 2021 5:24 pm Post subject:
| wakyct wrote: | | interrupt input |
heh, ok, added the following to the "currently working on" section of the Wren page:
2021-03-31 : Changed the help for some Envelope modules to explain the function of the inh(ibit) input.
oh, and also really did that - it will show up in a next release.
Then, to ensure a minimum gain, or a controllable range rather, you could use the Scaler or RangeConverter modules - the latter probably the easier one to use (both on the Ctrl1 tab).
Scaler uses a gain and an offset to control the range and the RangeConverter simply sets a minimum and a maximum value.
To understand how such modules work you can use the Value module (from the Utility tab). _________________ Jan
wakyct
Audio files: 12
Posted: Sun Apr 11, 2021 12:56 pm Post subject:
I've been enjoying trying out different combinations of sequencer modules, here is a basic one of Pattern and SeqRandom. Pattern makes it easy to play the rhythm by adjusting steps in small increments.
Modulating frequency and filter cutoffs by just a few semitones gives a nice buzzy sound.
| Description: |
 Download (listen) |
| Filename: |
pattern_on_seqrand_sinkdrumming.wren |
| Filesize: |
17.59 KB |
| Downloaded: |
369 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
sinkdrumming.mp3 |
| Filesize: |
999.57 KB |
| Downloaded: |
457 Time(s) |
Posted: Sun Apr 11, 2021 3:36 pm Post subject:
| wakyct wrote: | | nice buzzy sound. |
wakyct
Audio files: 12
Posted: Sat Apr 24, 2021 9:32 pm Post subject:
Kind of realized anything can be a sequencer I guess, and in that spirit I recorded a sample from a tape of the Vienna Hofburgkapelle choir. Routed through a sample & hold and RangeConverter then quantized, it modulates the frequency. The LFO that triggers the S&H then also goes through a divider to inhibit the main voice's envelope and add some dynamics.
This makes me wonder in what ways a sample can control a patch in general.
| Description: |
 Download (listen) |
| Filename: |
gregorian_demake.wren |
| Filesize: |
21.73 KB |
| Downloaded: |
411 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
gregorian_demake.mp3 |
| Filesize: |
1.48 MB |
| Downloaded: |
441 Time(s) |
John_W_Thompson
G2 patch files: 5
Posted: Wed Jan 26, 2022 1:29 pm Post subject:
Hope this is not offensive I tweaked the LFO freq and it sounded like an engine so I had to take it to it's logical conclusion. I am on day 1 of WREN; thanks for the snare patch it taught me a lot.
https://youtu.be/agKM7ffb6Zw |
wakyct
Audio files: 12
Posted: Wed Jan 26, 2022 7:00 pm Post subject:
Not at all, I'm even YT famous now thanks to you  |
John_W_Thompson
G2 patch files: 5
Posted: Thu Jan 27, 2022 6:04 am Post subject:
| ha! |
