Resettable Clock for synchronisation
Page 1 of 1 [13 Posts]
NuttyMonk
PostPosted: Fri Apr 30, 2021 1:12 pm    Post subject: Resettable Clock for synchronisation Reply with quote  Mark this post and the followings unread
Hi all,
i am trying to figure out a way to create a clock signal which can be controlled using potentiometers and external voltages and can also be reset asynchronously so that i can keep multiple clocks in time with each other using a trigger at the start of each bar.
I've looked at 555 Timer IC's and have managed all of that except the reset part. Does anyone have an idea for how to go about this? Either with 555 Timers or some other method?
My brain is about to explode trying to understand the 555 timer and i'm getting really frustrated.
I've added an image and Falstad File of my current 555 Timer setup which works well, except for resetting.
NM
p.s. i guess i need an oscillator which can be adjusted by pots, control voltages and has a sync function like hard sync and is linear not exponential
 Filesize:  195.56 KB
 Viewed:  176 Time(s)
555 Falstad Sim.txt
 Filename:  555 Falstad Sim.txt
 Filesize:  3.09 KB
 Downloaded:  156 Time(s)
gabbagabi
PostPosted: Sun May 02, 2021 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
hm,
i guess i would go for linear saw vco´s
they usually sync better
and you have better pwm options if you would like to have different gate lengths
i remember 555 can cause problems cos of heavie current use when switching
NuttyMonk
PostPosted: Sun May 02, 2021 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks gabbagabi,
you know of any designs? i can find plenty of saw vco designs but they all employ exponential converters. I'm not good enough at this stuff yet to be able to change one of those designs to linear.
NM
gabbagabi
PostPosted: Sun May 02, 2021 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
may this could be a starting point?
edit: pic updated, the transistor was wrong orientated
 Filesize:  41.2 KB
 Viewed:  167 Time(s)
NuttyMonk
PostPosted: Sun May 02, 2021 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice. Thanks Gabbagabi.
I'll try simulating it and breadboarding it later tonight.
NM
NuttyMonk
PostPosted: Sun May 02, 2021 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've simulated it and it works well. The only problem i'm having is implementing a reset function. I'm shorting the 10pf cap using a JFET but that stops the regular pulses coming from U3 from working properly.
The pulses are -12V to 12V on the JFETs base(???) leg. Not sure what that leg is called on a JFET.
Any ideas?
NM
 Filesize:  187.79 KB
 Viewed:  142 Time(s)
 Filesize:  190.84 KB
 Viewed:  169 Time(s)
Audio files: 297
PostPosted: Sun May 02, 2021 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
How I see things ...
For a reset you should short C1, and as as Q1 already does that peridically for the 'regular' reset .. it should be sufficient to make the base of Q1 forced high for a short! time.
This should 'override' the regular reset from U3, so maybe a (left pointing) diode in series with R6 and then an extra diode and resistor where you put in the (short) reset pulse?
The pulse must be short, as oscillation will be inhibited for the duration of the reset signal. But it must not be too short, as otherwise the capacitor will not be discharged completely. You may want some differentiating RC thingy to make a short pulse with a defined length there, and then fiddle a bit with the RC time.
The 'base' of a FET is called the gate.
C2 (the 10pF one) is just making the regular reset from U3 a bit faster.
NuttyMonk
PostPosted: Sun May 02, 2021 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks BH.
i've tried that out and it seems to work ok. I can shorten the pulse like you said with an RC setup. Something like a clock to trigger converter does.
Excellent. I've been mashing my brain trying to figure this out. It's gonna be a long time before i'm even slightly competent with this stuff.
Your idea defo helped me get in the right direction, so thanks BH.
I inverted the sawtooth with some offset and used a comparator on it to get a nice clock pulse from it.
NM
 Filesize:  51.22 KB
 Viewed:  149 Time(s)
Audio files: 297
PostPosted: Sun May 02, 2021 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
You go pretty fast tho, with just a couple of words that could have been confusing. which I was afraid of ...
Good to see you have some progress, may the breadboarding work too :)
And yes, clock to trigger does that shortening.
gabbagabi
PostPosted: Mon May 03, 2021 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
uh, ah
things are going fast these days Shocked
i dunno if the idea wiht all the diodes on the transistor base will work, but i like how it looks, and my simulator also says it works.
i included an idea for the start/stop input, and seperate reset input, the simulator says again it works Very Happy
do you can breadboard? iam exepted from any hardware otherwise i would do it myself
a guessing:
100nf as integration cap could be a bit high in reality, because it could be that the reset time (determinated by the 10pF cap) could be to short to discharge a fully loaded 100nf Cap, i have in memory that if putted a 15nF in.
same time i was using a 10Mohm resistor as integration resistor (R2), i guess that way i was reaching like 3 seconds or so.
are you planing to have the pulse width modulated?
cheers, looking forward to hear about your progress
 Filesize:  143.08 KB
 Viewed:  152 Time(s)
NuttyMonk
PostPosted: Mon May 03, 2021 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Gabbagabi.
The Start/Stop works well. The rest i'm not sure about.
This is going to be for a clock and the counter chip i am using (CD4029) counts each time it gets a rising transition so i might not need the pulse output. I have inverted the saw wave so i get a hard rising transition whenever the capacitor is shorted. This works well to generate a pulse output using a comparator but when the reset pulse is activated the saw wave might not have dropped below the comparators limit so no new pulse is created. Although it looks like it works ok in your simulation.
The saw wave on it's own gives me a hard rising transition anyway which is all i need.
The other problem is getting it to work well down in the LFO range as a clock, so down in the range below 8Hz is probably what i need. Not sure how to do that if the capacitor can't be too big.
I'll keep fiddling with it and see if i can get it to work using your setup.
NM
NuttyMonk
PostPosted: Thu May 06, 2021 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I went looking around to see what other people have been using for their clocks and i came across Fonitroniks VC clock. It's exponential, not linear, but that's ok i think.
http://www.modular.fonik.de/pdf/VCClockSCH.pdf
The way it works is easy for me to understand and i think it should be easy to add in an On/Off switch and a reset input.
By shorting Pin 5 on IC1B to ground, the cycle resets by shorting C10. Works well in my simulation. Easy to implement an On/Off switch. Not sure about how to go about the Reset/Sync part of it though. I'm not good with transistors yet although that would be the obvious choice. I'm thinking about just using a single SPST switch IC instead. I can understand that easily enough.
NM
p.s. there is already a forum post about syncing Fonitroniks clock here on EM
https://electro-music.com/forum/viewtopic.php?highlight=clock&t=47164
gabbagabi
PostPosted: Fri May 07, 2021 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry there was to much work the last days.
just let me "complete" this a little bit.
the start-stop-gate-low-function could be implemented as shown.
for low frequencys u should consider for R2 a high-value resistor 1M up to 10M.
back to work,
have a nice weekend
 Filesize:  76.65 KB
 Viewed:  130 Time(s)
