2021/2022 BUILD PHOTOS
Page 2 of 3 [75 Posts]
PostPosted: Thu Sep 02, 2021 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
no knobs yet and not the best toner transfer ever but I finally have an Elements and it even works. Razz
I only did a quick test but it has some nice sounds and can go quite orchestral.
thanks
Thank you very very much for the PCB Alan!
sorry it took so long to finish. Embarassed
 Filesize:  367.69 KB
 Viewed:  377 Time(s)
DES
PostPosted: Sat Sep 04, 2021 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice!
www.davesneed.com
wakyct
Audio files: 12
PostPosted: Sat Sep 04, 2021 8:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool panel!
I hadn't heard Elements and just watched a video, looks really fun!
PostPosted: Mon Sep 06, 2021 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Built a wav trigger into euroformat.
This is midi controlled.
my synth
PostPosted: Mon Sep 06, 2021 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd heard of the Tsunami Wav Trigger, but hadn't realised that they had that model as well. It sounds good!
Phobos, it's a fun module!
PostPosted: Mon Sep 06, 2021 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Got mine from: https://www.antratek.com/wav-trigger
They have 3 types: wavtrigger, tsunami and the mp3trigger.
edit: missed the LITTLE SOUNDIE AUDIO PLAYER
my synth
analogmonster
PostPosted: Tue Oct 05, 2021 4:57 am    Post subject: Formant Poly Demo
Subject description: Short 3-voice polyphonic patch demo
Reactivated my Formant polyphonic synthesizer solution from the year 2004 and had a go at some old and nearly forgotten software bugs in my UCVM module and my poly keyboard
YouTube
Universal Control Voltage Module
 Filesize:  46.17 KB
 Viewed:  12781 Time(s)
MIDI Keyboard
 Filesize:  117.6 KB
 Viewed:  361 Time(s)
I am not the master of a metal rasp
 Filesize:  47.03 KB
 Viewed:  323 Time(s)
PostPosted: Fri Oct 15, 2021 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are some things I did earlier this year:
DIY Eurorack Modular Case PSU and USB
DIY Monitor Controller
JacobWatters.com
PostPosted: Sun Nov 14, 2021 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally have a Benjolin Smile
Actually I finished it about 2 months ago and used it during the September Equinox concert and a recent halloween set,
but I mistakenly ordered only one knob of each type so had to wait untill I was ready to place another order. doh
 Filesize:  224.95 KB
 Viewed:  324 Time(s)
 Filesize:  196.99 KB
 Viewed:  336 Time(s)
 Filesize:  258.88 KB
 Viewed:  342 Time(s)
 Filesize:  311.33 KB
 Viewed:  333 Time(s)
PostPosted: Sun Nov 14, 2021 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
And another project finished, a Video Inverter (inverts chroma and luma).
 Filesize:  242.41 KB
 Viewed:  275 Time(s)
 Filesize:  269.51 KB
 Viewed:  268 Time(s)
 Filesize:  238.45 KB
 Viewed:  247 Time(s)
wakyct
Audio files: 12
PostPosted: Sun Nov 14, 2021 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks great! Nice work.
dk
PostPosted: Sun Nov 14, 2021 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Both of those look great PHOBoS!
PostPosted: Sun Nov 14, 2021 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lovely work PHOBoS....
Audio files: 161
PostPosted: Wed Nov 17, 2021 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
they look fantastic Phobos , great work Smile
PostPosted: Mon Nov 29, 2021 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys! have another one Wink
The Phosterizer. a video posterizer effect which is a modified version of an Elektor Magazine video effect generator (June 1983 issue).
The enclosure used to be a bench power supply, hence the holes in the sides. I was thinking of covering it up with some wood but
I don't think it's worth wasting material and time on, it would just make it more bulky. Maybe I'll glue some thin black cardboard or
plastic on it. Connector and switch on the backside are a last minute addition so not labeled. Haven't been able to record it properly
as capturing and encoding makes it all kinds of blurry but you can find some earlier tests here and here.
 Filesize:  278.39 KB
 Viewed:  230 Time(s)
 Filesize:  258.86 KB
 Viewed:  228 Time(s)
 Filesize:  213.79 KB
 Viewed:  240 Time(s)
PostPosted: Mon Nov 29, 2021 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wind controller.
A pressure sensor is read with a BluePill STM32, programmed with the Arduino IDE.
The waveform of the pressure is displayed on an Oled display.
the output is from a multiplying DAC, so with a potmeter I can set the amplitude, while with the rotary encoder I can set the offset, and by pressing the switch of the encoder, the output of the pressure sensor (I2C controlled) is calibrated to 0 volt out.
Also a gate is implemented, when pressure is applied, the gate goes HIGH, and goes LOW again when there is no more pressure measured.
About every 30mSec a measurement is taken.
 Filesize:  748.38 KB
 Viewed:  239 Time(s)
 Filesize:  323.24 KB
 Viewed:  232 Time(s)
my synth
analogmonster
PostPosted: Tue Nov 30, 2021 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Grumble wrote:
Wind controller.
Which software did you use for 3D printing? And have you printed the poti knobs also?
PostPosted: Tue Nov 30, 2021 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
No, the knobs are from aliexpress, the software I used for the 3d drawing is Autodesk Fusion 360.
my synth
PostPosted: Tue Dec 14, 2021 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
An Eurorack Module around the YMF704, this chip has GM midi on board and can play Wave-tables ánd FM-synthesis.
For now it's only playing Wave-Table sounds, but on the module there also is a BluePill that should be able to set the FM Synthesis parameters.
my synth
PostPosted: Sat Dec 18, 2021 4:55 pm    Post subject: Upgrade to vintage modules (updated) Reply with quote  Mark this post and the followings unread
Has been a while since I've built anything new however my synthesizer has had a long-standing problem that I solved today.
The issue was I noticed distortion on the VCOs when tuned above 2500hz. At first I suspected a power supply issue but a quick check of the schematics indicated that the modules all had filter capacitors, etc.
However, the old oscillators' circuits did not include ferrite beads. So, I added ferrite beads in series with the power supply input on each module and happily the distortion disappeared. Indeed, the oscillator signals (most likely the square waves) were bleeding through the power supply buss.
Though I haven't built any new modules, I enjoy modifying the old ones to work better-than-new!
Update!
Well, I spoke too soon. Indeed, the ferrite beads helped however there was still bleedthrough.
I finally found the culprit! Turns out that in the Aries module designs, every square wave output -- from clocks, LFOs, and VCOs feeds a voltage divider (which in turn, feeds the output jack). The resistor values are relatively low (390 ohms and 1500 ohms). In other words, every square wave output was connected to the ground bus through a 1500 ohm resistor! Arrgh... my ground bus didn't stand a chance!
Anyway, I don't really see the need for a voltage divider and modified the output simply with a 10K protection resistor in series with the output jack and no feed to the ground bus. I know that 10K is a high value -- what it accomplishes is that this resistance reduces the load on the oscillator which, in turn, can pull down the power supply buss on the PCB and can be transmitted to the power supply busses.
I haven't done all the oscillators yet -- I started with the clocks. I have still to do the LFOs and will do the VCOs last. I suspect that I may need to mess with the values of the protection resistors on the VCOs but that remains to be seen.
I am not sure why Aries chose to run the square waves through voltage dividers (they didn't do this with other waveforms). I don't know why they chose such small resistance values for the voltage dividers. There were likely reasons that made sense in the 1970s that don't apply now with current technology.
Thanks for indulging me this long post. Details such as this make the difference between creativity and frustration. I have been fighting and working around this issue for a long time. Indeed, it was hard to feel creative when the tone of the VCOs was unsteady and harsh.
Aries Ar-341 Voltage-controlled Oscillators
 Filesize:  2.46 MB
 Viewed:  251 Time(s)
PERFORMANCE
PostPosted: Mon Feb 07, 2022 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woaaaah, cool - any board layout by chance? I'll gite it a try on stripboard but maybe I'll turn mad doing this so any inspiration appreciated!
EDIT: Late to the 2021 party, I know, I know Very Happy
PostPosted: Mon Feb 07, 2022 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Benjolin, if you are OK with Euro and SMD
https://github.com/forestcaver/Benjolin
I'm not Forest Caver, but my understanding is he did get permission to release it this way.
PERFORMANCE
PostPosted: Mon Feb 07, 2022 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey! Thanks for that - I already got all the schems and stuff (Euro-conversion...) but was especially interested in Phobos stripboard-/ veroboard-layout!
PostPosted: Tue Feb 08, 2022 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's pad per hole perfboard and the largest one I soldered to date. I'll see if I can post a layout but I design them with Sprint-Layout
which isn't the most convenient when it comes to sharing layouts, at least not the version I have. Note that I did add some mods to
the original benjolin circuit, inspired by casperelectronics, so I guess I schould upload the schematic aswell.
PostPosted: Fri Feb 11, 2022 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Quad VCA/Mixer.
Also useable with CV-es (DC coupled and not inverting) at the individual outputs and AC coupled at the mix output.
 Filesize:  882.47 KB
 Viewed:  230 Time(s)
my synth
