Win 10 Editor G2 Random USB Loss
Page 1 of 1 [9 Posts]
iPassenger
G2 patch files: 78
PostPosted: Mon Nov 22, 2021 2:32 pm    Post subject: Win 10 Editor G2 Random USB Loss Reply with quote  Mark this post and the followings unread
Hi All,
Has anyone found an answer to the seemingly random USB loss of connection between the editor, the G2 and windows 10.
I've tried different ports, cables, hubs, various settings in the editor and windows application settings.
Each time I change something, I reckon I have found the culprit and it is now resolved only for after a seemingly random amount of time (generally a few weeks later), it does it again.
The only thing that seems to sort it when it goes, is to disconnect and reconnect the G2 usb cable. Once reconnected, it then works and doesn't do it again for ages.
It's pretty rare and not that big an issue in the scheme of things but just wondered if anyone had solved it on their machine?
Nord seems fine and in good condition, so am pretty sure it is something to do with drivers/windows etc.
Am running 1.62 on the Nord and 3.0.2.0 64 Bit Clavia Driver if that helps?
R.
iP (Ross)
Audio files: 310
PostPosted: Tue Nov 23, 2021 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
One other thing I can think of .. is it sleep related?
iPassenger
G2 patch files: 78
PostPosted: Wed Nov 24, 2021 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The allow usb to sleep function, power saving etc? Am pretty sure have looked at that one but will have another look. Maybe the nord device is being allowed to sleep?
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Fri Nov 26, 2021 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm no dice, only thing I can think is check the system event viewer next time it errors and look for clues, probably should have tried that last time.
iP (Ross)
Audio files: 310
PostPosted: Fri Nov 26, 2021 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh .. hey .. I thought I had replied .. but yeah .. the power settings for USB .. turn off on sleep .. that's the thing I meant.
Too bad that was not it ...
iPassenger
G2 patch files: 78
PostPosted: Thu Mar 24, 2022 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
just for info, it has not crashed since! Very Happy
iP (Ross)
Audio files: 310
PostPosted: Thu Mar 24, 2022 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool great!
heh ..but why Shocked
iPassenger
G2 patch files: 78
PostPosted: Thu Mar 24, 2022 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I dunno, because it has become sentient and knows am planning to catch it!?
iP (Ross)
Audio files: 310
PostPosted: Thu Mar 24, 2022 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
