Joined: Apr 03, 2004 Posts: 24669 Location: The Netherlands, Enschede
Posted: Sat Dec 28, 2024 5:20 pm Post subject:
Please note ..
the schdule has been changed - some people and some switchers have been moved to different time slots.
keep an eye at : https://electro-music.com/wiki/pmwiki.php?n=Radio.NextSpecialEvent _________________ Jan
Joined: Feb 04, 2005 Posts: 2886 Location: Nottingham, UK
Audio files: 281
Posted: Sun Dec 29, 2024 7:28 am Post subject:
Looks like my last bus into town is 20:01, so is there any chance my set could finish by 19:30 please, if not then I'll just do 30 minutes instead _________________ Jez
music | adventures in sound | gear for sale |
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Sun Dec 29, 2024 9:22 am Post subject:
| modulator_esp wrote: | | Looks like my last bus into town is 20:01, so is there any chance my set could finish by 19:30 please, if not then I'll just do 30 minutes instead |
Looks like I can make a revision so that you can start earlier. I have to step away now and will be back around 2330 GMT to work on it. _________________ -- Kevin
http://kevinkissinger.com |
electro-nyc
Posted: Sun Dec 29, 2024 11:53 am Post subject:
redgreenblue |
2 things, can my name be changed to redgreenblue on the poster?
And the link in the poster is for the Sept 2024 concert
That time works for me, see you all Tuesday! |
Posted: Sun Dec 29, 2024 12:35 pm Post subject:
The wiki was pointing to the previous event .. i've changed that .. but i don't know about a link in a poster ...
Also changed redgreen to redgreenblue on the wiki, but not on the poster(s). _________________ Jan
Audio files: 281
Posted: Sun Dec 29, 2024 12:57 pm Post subject:
| kkissinger wrote: | | modulator_esp wrote: | | Looks like my last bus into town is 20:01, so is there any chance my set could finish by 19:30 please, if not then I'll just do 30 minutes instead |
Looks like I can make a revision so that you can start earlier. I have to step away now and will be back around 2330 GMT to work on it. |
Thanks  _________________ Jez
Audio files: 281
Posted: Sun Dec 29, 2024 12:58 pm Post subject:
Re: redgreenblue |
| electro-nyc wrote: | 2 things, can my name be changed to redgreenblue on the poster?
I thought it was odd you were shown as redgreen Shane, but checked and that's what you put in your sign-up post, so I thought maybe it was something new _________________ Jez
Ron Holmes
Joined: Sep 27, 2016 Posts: 48 Location: state college
Audio files: 19
Posted: Sun Dec 29, 2024 6:58 pm Post subject:
| Looking for the port information so I can test. Thanks. |
mtvic
Joined: Feb 03, 2003 Posts: 526 Location: Townbank Cape May NJ
Posted: Mon Dec 30, 2024 1:17 am Post subject:
| kkissinger wrote: | | Mike, you are now on the schedule at 22:30 GMT. |
Thanks Kevin.
I will try testing my port later today. _________________ "I'm the transmitter' I give information."
>>> Kraftwerk Radioactivity<<< |
Posted: Mon Dec 30, 2024 4:12 am Post subject:
| mtvic wrote: | | kkissinger wrote: | | Mike, you are now on the schedule at 22:30 GMT. |
Thanks Kevin.
I will try testing my port later today. |
Excellent! btw -- I had to revise the schedule, and your start time has moved by 30 minutes to 22:00 GMT.
Hope that works for you. Thank you! _________________ -- Kevin
Posted: Mon Dec 30, 2024 9:24 am Post subject:
Hello! I went ahead and closed the signup now. Since the schedule changed a few times, please check it and let me know if your assigned time won't work for you.
See you Tuesday! _________________ -- Kevin
Audio files: 281
klangumsetzer
Audio files: 37
Posted: Mon Dec 30, 2024 11:03 am Post subject:
Thanks Kevin, all fine with me. _________________ Make a joyful noise!
Eike |
Ron Holmes
Audio files: 19
Posted: Tue Dec 31, 2024 8:15 pm Post subject:
mtvic just turned up in the irc chat and said he did have troubles using the internet.
This would of course have made it impossible for him to perform - bloody interwebs always.
Anyway, this was not a noshow but a sad case of tech issues.
too bad mike & next time beter
We missed you. _________________ Jan
Posted: Wed Jan 01, 2025 7:57 am Post subject:
| blue hell wrote: | Anyway, this was not a noshow but a sad case of tech issues.
We missed you. |
Sorry that you had internet issues. Alas, these things happen sometimes.
Mike, please plan to play for the March Equinox event. Always enjoy your music! _________________ -- Kevin
usr_sbin
Joined: Sep 18, 2006 Posts: 33 Location: Montréal, Quebec, CA
Posted: Wed Jan 01, 2025 8:25 am Post subject:
Unplanned Improvisation for the Event
Although I wasn’t originally scheduled to perform, I ended up doing an impromptu improvisation using my modular system with a test patch.
Lately, I’ve been focused on building Arduino-based control modules, which served as the backbone of the setup. The audio path was intentionally simple: just four VCOs (each outputting triangle waves) without any filters or additional complexity.
The first new module I used was a Sample and Hold with voltage quantization and mapping. It includes a built-in mini-sequencer that I can engage and adjust on the fly, with a selectable number of steps. The quantizer/mapper allows me to choose from several predefined scales and modes, which are stored in software. One of the key features is the cross-fader, which lets me smoothly transition between modes. A particularly useful algorithm for the cross-fader is the common-tone method, where the transition passes through a middle mode that represents the intersection of the two scales.
I also used a new Quad Envelope Generator. On this prototype module, all the envelopes share the same ADDSR parameters, but I can control two sets of envelopes (A and B) and blend between them using the cross-fader.
The melodies in the set were generated by an older module I built years ago, the CGS 1/finite Melody Generator (designed by Ken Stone). The new Sample and Hold module was designed with this and future melody generators in mind, providing a versatile foundation for evolving patches.
In the end, the performance was an off-the-cuff exploration, with me adjusting the patch in real-time—turning knobs and tweaking parameters to keep the sound musically varied and interesting.
| Unplanned improv for NYE, Dec 31 2024 streaming event |
 Download (listen) |
| Filename: |
NYE_Dec_31_2024.mp3 |
53.21 MB |
| Downloaded: |
311 Time(s) |
Audio files: 281
Posted: Wed Jan 01, 2025 9:13 am Post subject:
Here's my set, a space music/ berlin school improvisation for hydrasynth, jd-08, se-02 (arpeggiated by hydrasynth), minifreak and wavestate (through 2 pole filter)
Available to view on twitch for another 6 days:
https://www.twitch.tv/videos/2340807779
288.24 KB |
| Viewed: |
165 Time(s) |
268.13 KB |
| Viewed: |
165 Time(s) |
| modulator_esp_e-m_nye_2024_timeshifts |
 Download (listen) |
| Filename: |
modulator_esp_e-m_nye_2024_timeshifts.mp3 |
55.47 MB |
| Downloaded: |
306 Time(s) |
Joined: Jan 07, 2009 Posts: 1226 Location: Scottish Borders
Audio files: 161
klangumsetzer
Audio files: 37
Posted: Thu Feb 27, 2025 12:01 pm Post subject:
| Skrog Productions wrote: | Here is the Epicyclus set , had a great day yesterday streaming and listening in till i zonked out on couch and missed the bells!!  |
I finally made some time to have a listen or rather finally made some time to leave a comment after making some time to listen 2 weeks ago.
Great set, even gave me some goosebumps at parts,. also nice 303 acid bassline  _________________ "My perf, it's full of holes!"
