Ramp wave?
Page 1 of 1 [11 Posts]
Pehr
PostPosted: Sat Aug 20, 2005 3:48 am    Post subject: Ramp wave? Reply with quote  Mark this post and the followings unread
This might be a stupid question, but is a ramp wave the same as a sine wave? Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Clack
PostPosted: Sat Aug 20, 2005 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
its a sawtooth / / / / ramps. but i think it could mean it goes the other way ascending
Pehr
PostPosted: Sat Aug 20, 2005 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
aha! Smile thanks!
YouTube channel
flickr photostream
dnny
PostPosted: Sat Aug 20, 2005 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
well Pehr there are no stupid questions and we all have been newbies.
(and I'm still one)
i have learn that the waves goes like this
but I'm not sure about it, because sometimes i hear people talking about sawtooth, triangle and ramp like they are the same wave ?
if someone knows please clear the thing to me and others
thanks
daniel
www.koelse.org
flickr: cable porn group
PostPosted: Sat Aug 20, 2005 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ramp and sawtooth are the same thing (although I think that technically or mathematically the word ramp is used mostly when the signal is non-repeating (and goes on to climb or descend "for ever")).
BTW ascending or descending makes no difference for how the sawtooth wave sounds. A triangle is different, that one sounds softer and has less high frequency energy in it (when you sweep a filter over the signals it will be clear immediately)
Clack
PostPosted: Sat Aug 20, 2005 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
On the LFO of the soundlab there is a switch with ramp triangle and saw so im guessing in this case it means one ramps up and the other ramps down and the tringle ramps up and down
I dont know if thats true, im guessing. i havnt got it working yet
Mohoyoho
PostPosted: Sat Aug 20, 2005 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a difference when modulating with ramp waves. With a reverse ramp (when the sloped side comes first) there is a gradual modulation and then an abrupt end. The standard saw has the opposite effect.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Pehr
PostPosted: Sat Aug 20, 2005 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Doesn't it? I thought so... Embarassed
YouTube channel
flickr photostream
PostPosted: Sun Aug 21, 2005 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
That's not entirely true. Back in my hedonistic days (naturally after taking copious amounts on cannabis, LSD and MDA!!) listening to the sound of of a Roland TB-303 over a large PA, while raving to 6am or so in the morning it is quite possible to 'see' the sawtooth waveform- especially when using high resonance on the filter. It was definitely 'descending'.
Those were the days :D
PostPosted: Sun Aug 21, 2005 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I should add that a ramp wave (sawtooth) is rich in both odd and even harmonics, whereas a sinewave only has one- its fundamental.
A triangle is like a sinewave- but has a couple more harmonics (even I think- been a while- childcare takes it out of you!!). Triangle waves are good for synthesising flute-like or pipe organ sounds.
A squarewave only contains odd harmonics and has a much more buzzy sound. Therefore its good for making other woodwind sounds. for eg, Instruments that contain a reed such as an oboe or clarinet. Squarewaves can also be manipulated through mark-space-ratio to create 'pulsewaves'. Pulsewaves are good for creating vocal sounds- especially if used with a high resonance filter.
A sawtooth is good for creating string sounds- because they are rich in harmonics. Saw's are also good for filtering because it's easy to get that classic 'rasping filter' sound- so beloved of Tangerine Dream and 70's sci-fi fanatics.
It's a shame that no one has come up with an analogue alternative (although I did find an excellent circuit for the Serge modular which sweeps through all available waveforms from a sawtooth).
Hope that helps :)
PostPosted: Sun Aug 21, 2005 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's hard to reason against that :-)
