NordLead3 Unison
Page 1 of 1 [6 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 09, 2005 6:02 am    Post subject:  NordLead3 Unison
Subject description: ...the infamous Nordlead3 unison function...
Finally, the NordLead3 unisono function as a building block.
Just like the original, it creates 4 detuned replicas of the ingoing signal and spreads those over the stereo field, two hard-panned right and two hard-panned left.
I's actually just a clever-dick crossbreed between a multitap chorus and a pitch shifter. I have no sure info about how the original works, but I'm pretty convinced it works this way. At least, it sounds exactly like it. (I tried several other more fancy approaches, and they fell short.)
NL3 Unison TK.pch2
 Filename:  NL3 Unison TK.pch2
 Filesize:  1.47 KB
 Downloaded:  1944 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 09, 2005 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
And here, a deluxe version: twice the madness!
Eight detuned replicas spreaded over the stereo field. Sounds far denser. Killer for pads!
DeluxeUnisono TK.pch2
 Filename:  DeluxeUnisono TK.pch2
 Filesize:  1.91 KB
 Downloaded:  1887 Time(s)
Audio files: 235
PostPosted: Wed Nov 09, 2005 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
An excellent addition to the building block section. Nice one..
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Nov 09, 2005 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks Tim! Very Happy
Wan
G2 patch files: 46
PostPosted: Sat Nov 12, 2005 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, nice indeed, Tim, thanks for sharing.
I've had some fun time combining this unisonthing with the ridiculohyper you posted. Making it more ridiculo, but still, on certain sounds, when there is just a little bit ridiculo getting through, i like it.
Placing this unison buildingblock in the fx area sounds a lot better than the inbuild chorus module Exclamation
Grtz Wan
Funky40
G2 patch files: 5
PostPosted: Thu Mar 16, 2006 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this patch is meant as an Idea to show the routing, and not as final, so my comment is not critically and especially for those who are not on the advanced side (as i are )
My comment:
I sugest to set the delay values much smaller and the smaller they are the smaller should be the modulation amount of the delays.
Set the Delaytimes for a first try between 0.39ms and 1.43ms . (more -less )
The effect becames more subtile and much more musical.
I use in every Synthpatch a 2tap- or 4tap-delay and 1 is allways set to 0.01 !
In the deluxversion i set detune between 5 and 15, or 25-40 for an audible effect.
