Buy Classic modular or keep 2 G2's?
Page 2 of 3 [57 Posts]
PostPosted: Fri Dec 16, 2005 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Edit; I take this back.
Instead I'd encourage everybody interested to try and repeat my findings. After that we can talk.
PostPosted: Fri Dec 16, 2005 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kass - I think the larger price on the 1616m is more associated with the ADC's than the DACs (those freaky high end AKM converters with >120db SNR ). Still, as with all things "high-end" they have a higher overhead in price as well Smile
Not to stay on this well beaten path, but I wonder if anyone has ever looked at the clocking structure of the G2's. Jitter causes more high freq. garbage and inharmonic junk than nearly anything else. It may be the cause of your distress.
cebec
G2 patch files: 31
PostPosted: Fri Dec 16, 2005 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the end, though, I think a better test would be a side by side comparison with the 1820 or 1616 (non-'m' models) running the G2 Demo, and a G2 KB.
But yeah, it could be the clock, the implementation of the converter, and choice of op-amps, etc., rather than the converter itself that is responsible for the phenomena Kassen says he can hear.
How could we look at the G2's clocking structure, or any audio interface's clocking structure, if we wanted to? The data sheet for the CS4392 states high tolerance to clock jitter/low sensitivity to clock jitter, which is the same thing. If we grant that, then hypothetically the G2s clock would have to be really bad, more of us would hear it, most likely.
I think most almost all of this is on topic, however.
When I compared the NM Classic to the G2 using my ears and plots, I found the NM Classic a bit grainier and a little beefier than the G2 which sounded more detailed and open. It's become relatively easy for me to add the girt and beef to a G2s sound character that you get on the NM Classic.
As for my examinations of the FFT plots, the aliasing on both systems was identical, and repeatable, with little variation, in/on other digital synths (Reaktor, Bidule, Max/MSP, VAZ Modular).
So, this is what I hear and what I see when I've compared the two synths...
Use your own judgment, of course. An NM Classic won't set you back that much and you're likely to make your money back if you decide it's not for you.
PostPosted: Fri Dec 16, 2005 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the record, I have had similar discussions re how one specific analog synth sounds compared with another. There were often very obvious differences even in cases when the products shared used almost the same components. I think this info kassen is sharing with us is very interesting, but it might be that this DAC issue or whatever this is about could be contained inside a new thread. Or not..
Re the "Buy Classic modular or keep 2 G2's?" - I love the NM-1. It sounds crude and cosy and even warm. I am using it mainly for those Roland 100M and 700 patches and even for some Formant style noises. It is an excellent product.
Flickr
PostPosted: Fri Dec 16, 2005 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it might not exactly be just simply about the DACs. I wonder how the demo will sound using the latest Echo firewire interfaces?
Flickr
PostPosted: Fri Dec 16, 2005 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
JKS;
Yes, I was quite pleased with the specs on those ADC's :¬). I haven't tried testing those yet but I'm quite pleased with it overall. Ok, I'm not pleased with E-MU messing up the on board "test tone generator" nor am I pleased with the lack of a reply to my bug-report on this but the bits that actually matter are top notch
I have to admit that I didn't considder jitter yet Embarassed you may well be right. The trouble is that i`m not entrily sure I can even test for that here and now. It's a beaten path for sure, but at least we are on the beaten path with new data and new ideas.
PostPosted: Fri Dec 16, 2005 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
But yeah, it could be the clock, the implementation of the converter, and choice of op-amps, etc., rather than the converter itself that is responsible for the phenomena you say you're hearing.
Those are solid points, it could well be that I was too hasty. Still, considering that the actual algorithems are identical I still think this is interesting. Thanks for pointing that out. Next time I want a more simple world to be born in ;¬)
cebec
G2 patch files: 31
PostPosted: Fri Dec 16, 2005 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kassen, check out this forum, if you haven't already. Several E-MU reps regularly reply to posts, here, and can help you get your bug reports, etc. expedited.
http://www.productionforums.com/forum-52.html
Audio files: 235
PostPosted: Fri Dec 16, 2005 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I downloaded the G2 Demo and can't hear too much difference. Maybe because I run my G2 though the same MOTU 828MKII interface as the computer uses. Kassen, please post the patch that sounds so different to you. Have you considered that your particular G2 has a problem?
PostPosted: Fri Dec 16, 2005 8:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not the DAC's allowance for jitter that hurts the sound.
All Digital algorithmns are based on 0% jitter in the clock. They expect a perfect sample rate. Most algorithms that try to account for it, use over sampling followed by a decimation filter. When you generate a square wave, for example, you want those edges exactly at the frequency chosen. But what happens when the tone generated can't be represented by 44.1khz, 48khz, or 96kHz? Well, you're edge moves to the closest sample, and you live with the results. This is part of the reason for higher sample rates...you can more accurately describe the intended wave.
But jitter is slightly different. What happens when the sample rate changes ever so slightly, from 96000 on one sample, to 96010 on the next? What happens to your square wave? It becomes inconsistent. And the result is high frequency junk, and harmonics that don't belong.
I'm guessing Kassen is a little more sensitive to this than most people, and would think his experience is something like tinitus (ringing of the ears) and it drives him crazy. I know someone who studied tinitus. The population that suffers from it has a higher suicide rate than those that don't have it.
PostPosted: Fri Dec 16, 2005 10:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
(can't sleep, curses)
Well, my original test was conducted using just a oscB set to saw straight to the out. I could immediately tell the difference. I then used two identical oscB's ringmodulated to various degrees at various mostly very high frequencies. I also used some two Osc FM feedback loops with various wave shapes, also all at very high rates and using deep modulation, basically I was trying to create as many extremely high sidebands as possible. This did not make my jaw feel like I had just eaten a thinck slice of fresh lemon.
The various G2's I've heard all *do* make me feel like that at such experiments. That's about a dozen or so. After prolonged exposure to the G2 something in my head starts getting very anoyed about something in the spatial properties of sound too; this was abscent now as well. Sometimes icepicks are experienced. I get the same sort of sensation at low bitrate mp3's blasted loud and to a lesser degree cracles from records recorded too hot to MD when heard on headphones. I could try some more using impulses and and other trouble making techniques but I'd be surprised if those yielded other results.
Anyway, I didn't save those patches but I could recreate all of it from memory if you realy want them.
PostPosted: Fri Dec 16, 2005 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, erm, chances are I'll kill myself for being too sensitive? That sounds quite romantic and goth. ;¬)
I found that most of the time it helps to just sugest that the sound is turned down. Suicide, while arguably a very solid and failproof solution, causes too many artefacts for my tastes.
Thanks for the info, seriously, do you perchance have a good link on what to read on this?
E-MU users might want to look at that test tone generator. Listen to the pink noise, then the white noise. Then scratch your head and read the labels again. Something went not quite right there....
PostPosted: Sat Dec 17, 2005 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Not that you'd kill yourself over loud mp3's. But imagine the agony you feel at hearing these high pitched sounds NEVER GOING AWAY.
The friend who looked into it didn't suffer from tinitus, but his brother did. But he was studying brain programming techniques, and looking for a (method/theory/technique) that might help reprogram the brain to avoid this high frequency loop, that often causes headaches and real pain. Part of his theory was that tinitus wasn't actually generated by the ear, but by the brain itself (the inital cause however was extended over stimulation by the ear). The brain usually is good at filtering out constant stimulation (you don't usually hear that clock ticking in the corner of your room, but your friends do since they aren't always exposed to it like you are). But if it gets traumatic levels of stimulation, it can end up re-wiring itself and possibly causing a loop (his theory was based on the chain reaction timing of neurons firing, and in a small loop it would equal a high frequency pitched sound).
So, unless you start experiencing this all the time, I don't think you're at risk Smile The physical cause of the pain might be different, but I can imagine that at the moment you do feel it, it would be a similar sensation (as in "I *really* don't want to be listening to this right now!!!").
paul e.
PostPosted: Sat Dec 17, 2005 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
jksuperstar wrote:
\ It becomes inconsistent. And the result is high frequency junk, and harmonics that don't belong.
I'm guessing Kassen is a little more sensitive to this than most people, and would think his experience is something like tinitus (ringing of the ears) and it drives him crazy.\.
i think Kassen may 'suffer' from having a particularily well-attuned musical ear/sonic perception system capable of perceiving and processing more bandwidth than most others, and perhaps this is a biological pre-disposition that is somewhat rare, and thus may seem odd or obtuse to others..
since most of the sonic world is organized around those who do not have real 'musical' ears, people who can really really hear music will be driven nuts more easily as they will be detecting 'hidden' artifacts and affects in sounds that may appear 'just fine' to some [mp3's for example]
and those with 'normal' hearing will find those objections strange, as they just aren't hearing itt ..
but in the case of musician or engineer, this talent is a highly valuable tool, and may be one of the most essential pre-conditions for excellence in this field
[if put into practice in a sensible way]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Dec 17, 2005 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Wasn't someone working on a way to hack into the digital path before the DAC's so they could get a digital spdif output? I wonder what happened with that... Could be the solution to all the DAC issues people are hearing.
Also, I'd like to point out that if all you want a classic for is harder edged sounds and to test out and learn from patches in the archive, you'd do well to buy a micro mod. They go pretty cheap on ebay these days, and can run all patches just with a quarter the polyphony - no need to sell the second G2!
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Dec 17, 2005 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
right...ask someone with perfect pitch to play a piano tuned half step down. it will be impossible, it would drive them crazy. for me it wouldn't be a problem Confused
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Dec 17, 2005 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I have perfect pitch. And yes, having to perform on beaten pianos in music venues is an agonizing experience (although the maladjusted keyboard actions are even more frustrating).
I can also not stand MP3 and especially ATRAC (Minidisc) for too long. (With MP3 it's the frequency content and with ATRAC it's the transients that bother me.)
I also had a problem with the "G2 sound" for quite some time. However, that problem has disappeared since I use a new and very good amplification system (Kling&Freitag CA1001 SP -one of those dudes costs more than a G2!), and -far more important- since I've got better at patching!!
Kassen wrote:
A good console is expected to be neutral, a good synth is excpected to be "nice".
If that were true, nobody would pay ridiculous amounts of money for old Neves. Laughing And expecting a good synth to be "nice" is part of the polka-board attitude you detest so strongly (and vocally).
Modular synthesis fosters a scientific approach to sound-design, for which "neutralness" is downright mandatory. So, if the G2 DACs seem more neutral, that's fine with me.
PostPosted: Sat Dec 17, 2005 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Was your friend the same guy that tried developing the system with different modulations around those "phantom tones" in order to treat them? I read about that. Very interesting.
I do have a "beep in my ear" but it's not that bad aside from that I think my hearing is quite good. Which I suppose is how it should be because there are already more then enough ear damaged engineers in the world.
I'd realy like to thank you for bringing this up because this would clarify quite a lot. I could imagine that to -say- Mosc the G2 would sound like the demo does to me on the 1616m and in that case we've been arguing like those blind men around the elephant!
Next steps then are for me; *) being very carefull with how I clock this CMOS stuff I'm getting into and *)wondering how hard it would be to swap out one of those cristal clocks. Yous see; the G2's cpu is on a cristal clock and there might be primium models of those?
PostPosted: Sat Dec 17, 2005 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps. But it would depend on what stage the jitter is in and wether it affects everything at the same time. As JKS points out; once a square wave's slope is a sample early, how do you move it? I've had trouble in a different system with jitter in controll signals and I can tell you it was a absolute bitch to even detect and very hard to even try to fix.
About the Micro; I think the prices of the rack and the micro have been getting so close that the difference is now many about cpu power v.s. compact size. Both are very nice buys in my opinion.
Acidfever
PostPosted: Sat Dec 17, 2005 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
If someone could educate me on how to achieve this (since i don't have a Nord Modular "classic" or Nord Lead 2 to compare with) i could end up not even having to go to the trouble of getting a Nord Modular rack in the first place.
My question is....after you achieve this.....does it become possible to patch Nord Lead 2 like structures that sound similar to the NL2? Doesn't have to be exact match...i just like what i've heard.....
PostPosted: Sat Dec 17, 2005 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I know exactly what you mean; that's the "record crackle" thing I mentioned. Clean atrac recordings at modest volumes are fine with me but short loud snaps seem to run into something that sounds like heavy amounts of FFT is involved and gets glass-like. Not pleasant at all.
Ok, well you are right to some degree. I realy enjoy the EQ on old D&R mixers and those aren't neutral at all. I never touched a Neve but the higher quality mixer brands are quite neutral compared to more modest products. As I understand it this comes mostly from having lots and lots of headroom (clipping a Behringer internally is trivial, doing the same on a Taskam is a different matter!) but yes; "slightly flatering" is nice to have for mixers, I like A&H for this.
For synths I think the matter is more complicated. Clearly in modular synths the overal system should be neutral but what about modules? I think a module like the "classic filter" should have some speciffic character. IIR filters quite simply *can't* be perfect (from a math perspective, of cource, you may think your Moog is perfect for you and be right) which means that some compromises end up in some places. I could well imagine a G2 OS4.3 which would have a range of "classic" filters, each with it's own character. I think those characters would be quite different from what you'd find in -say- a Neve. The 303 has a terrible filter by mixer standards yet by synth standards it's quite nice if a bit of a one trick pony. The compromises made in synth are affected by very different criteria then those in mixers.
That's what I meant but indeed it's not B&W at all. "Nice" in polka boards means "nice at the press of a button" while "nice" in modular systems to me is more of a "pleansant to work with" thing. That may still be quite character full and excentric, polka boards seem to come with a rather unpersonal sort of "nice". We need way more words to deal with this sort of matter.
PostPosted: Sat Dec 17, 2005 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The very first thing to do would be getting Rob's "tilt filter" and "satuartion" building blocks. Those add a lot already, regardless of what else you do.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Dec 17, 2005 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
The reason to keep/have 2 G2's is midi.
imagine g2 #1 is the clock master. But it's patches also control the patches in the 2nd g2 (patch change events), and you have a cuelist which changes patches after some long time (clocked gate) ...
you have design with a sequencer which mutes the 2nd synth (fade out), and then send pc event, then you have the volume to bring it up...
then you load the patch into the 2nd g2. it's midi out control is muted, until the 1st g2 finishes it's control period. then the 2nd g2's midi out starts to control the 1st g2's midi in. the roles are reversed (but the clock is controlled from 1st g2)... so bpm is important to tweak between perfs with diff bpms ...
You see, my G2's are more like turntables or a master synth with mixer and RS7000 and G2 #2 for grooves ... rs7000 is the clock master ... i can tweak the bpm in +/-0.1 BPM or tap it ...
You see, papa nord did not do midi out and this was it's downfall, as was the inclusion of delay based FX into the g2 for me ... to have both of them you have 8 inputs and 8 outpus ... this is nicer than 6 inputs and 6 or 8 outputs (g2 + micro-or-NM1Key) .. and with 2 g2's you have control swapping ... midi control swapping ...
Some good crazy bass stuff is going on right now... a patch called Four_DZ
on a beautiful day (see http://www.katkam.ca at noon PST)
My set hopes to include some of this stuff ... I'll perform it and describe it at NordWest06.
/Dasz
[editor's note: Papa Nord is Dasz' endearing term for the NM Classic or the NM1. --mosc]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Dec 17, 2005 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do miss Papa Nord (thanks Howard for the editor's note Wink ) ... but it is in good hands ...
and the truth is I did not use it since the G2 arrived ... and the number of innovative patches made in the G2, completely overshadow what I did in Papa Nord.
/Dasz
ps.: My favorite Env? AHD Mod!
cebec
G2 patch files: 31
PostPosted: Sat Dec 17, 2005 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've looked at companies who'll do DAC upgrades, add digital outs, or provide boards that piggyback on the DACs and provide a clock with extremely low jitter. These modifications are typically for high-end CD and DVD players but I'm sure that doing something similar to a synth is possible in the right hands.
In addition, there are several people on such forums as Head Fidelity who are experienced at modifying soundcards from RME to E-MU. Changing capacitors and op-amps have led some to claim improved fidelity.
Regarding the E-MU's tone generator, I'm using the latest version of the PatchMix DSP (1.82). How odd! I just took a listen and checked with the analyzer -- the White starts to roll off at 12 or 13 kHz and the Pink doesn't at all. There doesn't seem to be much difference, otherwise.
