Stutter and Scratch
Page 1 of 1 [7 Posts]
jamos
G2 patch files: 41
PostPosted: Thu Dec 15, 2005 3:45 pm    Post subject: Stutter and Scratch Reply with quote  Mark this post and the followings unread
Here's a patch that does stuttering and scratching on any stereo audio input. Tempo is determined by the master clock.
The building block is in slot D. The pitch stick will bring in the effect - if you just brush it, you'll get a rhythmic stutter; if you whack it, you'll get a delay-modulated stutter. And/or use the Stutter and Rate controls on page A1 in slot D.
The crossover is Rob Hordijk's design; it excludes low frequencies from the stuttering circuit, which smooths things a bit. The loop capture engine is also someone else's design, but I can't find that info; if anyone recognizes it please let me know and I'll edit this.
The sequencer in Slot C is Qualium's Qualium-303, from http://www.electro-music.com/forum/topic-7945.html, with some minor routing and sync changes.
StutterDemo.prf2
Qualium's 303 sequencer with interactive stutter/scratch unit.
 Filename:  StutterDemo.prf2
 Filesize:  13.86 KB
 Downloaded:  2088 Time(s)
cebec
G2 patch files: 31
PostPosted: Thu Dec 15, 2005 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow! much fun! love the pitch stick control...
G2 patch files: 626
PostPosted: Thu Dec 15, 2005 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is cool!
BobTheDog
Audio files: 32
PostPosted: Sat Dec 17, 2005 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, just got to work it out how it works now!
Andy
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Dec 17, 2005 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
A much nicer way of doing it than my old patch (stereo dance style looper). I used morph groups and cc assignments which is ugly if you want to copy it into another patch... Embarassed
Thanks very much for this!
mother misty
G2 patch files: 130
PostPosted: Tue Dec 20, 2005 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool one Jamos!
Works great on drums, I love this!
and70it
PostPosted: Wed Dec 21, 2005 4:21 am    Post subject: great
Subject description: great
it's great and flexible.....
this can very intersting with 2
different clk set up (1/8 and 1/32) at the same time
(i use this patch with the button, not with the pitch stick, i mean with 2 different
button and 2 different set up)
