simple 8 step sequecer for SL
Page 5 of 9 [204 Posts]
Scott Stites
Audio files: 96
PostPosted: Mon Jan 09, 2006 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whups - P1-P4 and Preen should be tied low (to ground). Lunch hour's over, canna change it now Very Happy
Scott Stites
Audio files: 96
PostPosted: Mon Jan 09, 2006 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used an asychronous load, just like the Moog sequencer. I built a big diode array connected to the switches and the preset inputs. Simple but effective.
Thanks, Howard! Wish this would have come up before the panel was designed.....
Scott
PostPosted: Mon Jan 09, 2006 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Position 1 is where all the counters sit on the "reset" clock. You only want one output for each step though, so you use position 1 on counter 1 and waste the others. You can keep adding more 4017s in this way, but you lose position 1 on each, because they don't have a "no output" state.
For kind of the same reason you lose position 10 on every counter because that's where they "wait" when they hand over to the next counter. In this case you're not really losing outputs, they are just being used as part of the logic.
That final schem is based on the circuit design idea which you find at the end of some 4017 data sheets. I knew I'd seen how to do it before, but it took a while to track it down. I almost got there on my own, but not quite. Using this setup you can make 16, 32, 80, 200 step sequences, you just need another AND gate for each new 4017.
Audio files: 227
PostPosted: Tue Jan 10, 2006 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's the main lesson I learned about electronics design; first design the front panel. Design the function you want. Don't worry about the circuits until that's done.
The circuits are acutally less important, and they can be redesigned and refined as needed. In fact, I redesigned the innards of my sequencer several times.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Jan 10, 2006 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
dnny wrote:
Macaba wrote:
Indeed, after checking, it seems they are called DIL switches which answers my question rather well. Seems getting "merry" at christmas hurt a few brain cells. Cool
sorry about the DIP/DIL confusion - is just that the vocabulary at my work uses the word "dipping" (in Finnish "dipata")- every time we set up a address of some lights whit these DIL- switches so it got me confused ... sorry.
Seems Paia call them DIP switches as well
http://www.paia.com/midi2cv.htm
I think it is Dual In Line or Dual Inline Package.
PostPosted: Tue Jan 10, 2006 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, you're right Ian.
Juno60
PostPosted: Thu Feb 09, 2006 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks,
has anybody finished building the pretty li'l sequencer? Does it work on the SL? I'm building my second SL right now (patched out version) and I like to build a simple sequencer next. The scheme seems too be perfect for me, but I wonder if it runs.
Greetings from Germany,
Chris
fabreeze
PostPosted: Tue Mar 14, 2006 12:24 am    Post subject: On Using two 4017's
Subject description: here's a link!
I heard some talk on the forum about using two 4017's to get 16-steps.
I saw this design while researching:
http://www.gozen.demon.co.uk/godric/synth/seqcirc.html
Hope this is helpful to y'all.
PostPosted: Tue Mar 14, 2006 4:08 am    Post subject: Re: On Using two 4017's
I saw this design while researching. Hope this is helpful to y'all.
It sure is Smile Thanks!
Oh yes- welcome to The SoundLab forum at electro-music.com! Very Happy
PostPosted: Tue Mar 14, 2006 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Juno60 wrote:
Hi folks,
Hi Juno60! welcome to E-M. Yes the sequencer works fine so get stuck in Very Happy
EraSer
PostPosted: Wed May 03, 2006 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everybody.
How can I sustitute 74HC4016? I don't succeed to find it in electronic-stores.
Crying or Very sad
PostPosted: Wed May 03, 2006 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
If you want a quad bi-lateral switch, then it's the 4016 part that counts. So a CD4016 or a CD4016B will do just as well. The 4016 is also pin for pin the same as a 4066 (except that a 4066 has a lower "on" resistance, (80R)) so that would usually be fine as well.
EraSer
PostPosted: Wed May 03, 2006 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Uncle K
you are a knowledge source Wink
thank you. Very Happy
Have someone build this sequencer?have you also sample it?
tanaelyn
PostPosted: Thu May 04, 2006 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone have an opinion on Ray Wilson's 8 Channel Expandable Analog Sequencer? It seems to me that it would be a great sequencer for the Sound Lab.
PostPosted: Fri May 05, 2006 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I think Pehr has built one.
Pehr
PostPosted: Fri May 05, 2006 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, I haven't Embarassed I have two sets of PCBs for the 16 step sequencer waiting to be built though... when I have time.... and the money... Sad
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
SuperKoopa
PostPosted: Tue Aug 22, 2006 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Here's another way to get a 16 step sequence with relatively few components. The CD4067 16X1 mux seems well suited for it. A bloody big IC, though - it's a 'double wide'.
Hi Scott.
what i have to do if i want a reset at step modification?
PostPosted: Wed Aug 23, 2006 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think about building some modules from Daniel Veras circuit. so it would be convenient to use the mos versions (MOS 4016 & MOS 4017, they can be powered easily with 15V). do you think that would have any negative effects on the functionality of the circuit (ie CV outputs)?
goodrevdoc
PostPosted: Mon Sep 11, 2006 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a simple way of ganging two 4017's together for a 16 step output.
The original file came with some downloads for the dBop, a sequenced drum machine from a DIY synth site i forget (synthdiy perhaps?) Anyhow, it works pretty well and is simple to implement. I am currently redesigning the dBop to include 16 steps, a better clock, and slightly different drum sounds. The trick is to use an inverter (4049)between the inhibit pins. Not sure if a whole 4049 is warranted for the sequencer, but if uses can be found for the unused inverters, might make a nice addition. just my $.02
PostPosted: Mon Sep 25, 2006 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
refering to the original design i wonder if i could easy add an external clock control, which should work with both trigger and gate signals. i thought of something like the following.
i don't know how to handle the clock pulse width the 4017 requires (up to 250ns). would a cap do and what should be the value?
what do the experts say?
just a sketch...
 Filesize:  17.24 KB
 Viewed:  437 Time(s)
PostPosted: Mon Sep 25, 2006 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
just another idea: what about using a DPTP on-off-on switches for each step controlling both the gate and the reset function? (i.e. switch down: gate on; middle: gate off; up: gate off/reset)
i'm planning to do a small modul for my modular, not a real sequencer but a little automation, not very panel intensive...
PostPosted: Mon Sep 25, 2006 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
The 4017 will trigger on the positive going edge of any pulse down to a few nS in duration, so I wouldn't worry about it.
You know that circuit will send a negative pulse if you put in a positive one don't you? That may be what you want, but the 4017 will trigger at the end of the pulse that way.
PostPosted: Mon Sep 25, 2006 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
what i actually wanted was to be able to trigger with gate signals too. but this might be a little be more versatile (mr ken stones gate2trig conversion?).
i'd thought i would ground it just like the manual step switch. how could i accomplish that?
as you can see, uncle krunkus, i have to learn a lot, but i am willing to...
PostPosted: Mon Sep 25, 2006 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I've still got heaps to learn as well!
I just had another look at that circuit, (trying to work out exactly why I said what I said!) and I'm not sure now! Laughing
Now lets see if I can talk this through.
I think for a positive going pulse, you need to move the 10K down to the emitter, going to ground. Take your clock directly off the emitter. The cap can probably go either on the collector or the emitter, but probably would be better on the collector, (I think?)
Anyway, when there's no incoming gate/trig the transistor is the larger resistor, so the clock out is held low. When a signal comes in the transistor conducts and it's emitter voltage goes up towards +V. I'm beginning to think the cap would be best on the base.
Of course, if anyone else knows for sure, feel free to let us both know. Embarassed
PostPosted: Mon Sep 25, 2006 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
i think, i have a general misunderstanding - i thought the 4017 would be triggered if clock in was set to ground (regarding the momentary switch for manual step fwd)? So i tried to hold the clock high, when no trigger signal present...
if any trigger pulse would go, maybe the gate2trigger circuit from mr ken stone would do. i think i will breadboard the whole thing this week and then see...
gate to trigger converter by ken stone:
 Filesize:  9.94 KB
 Viewed:  24575 Time(s)
