French vs english bead
Page 1 of 1 [14 Posts]
benfox
PostPosted: Fri Feb 03, 2006 11:44 am    Post subject: French vs english bead Reply with quote  Mark this post and the followings unread
I want to do this
http://www.cgs.synth.net/
What does "bead" means please ?
I know it's really a stupid question for you but...
PostPosted: Fri Feb 03, 2006 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome ben
here is the long answer Smile
bead Pronunciation (bd)
n.
1.
a. A small, often round piece of material, such as glass, plastic, or wood, that is pierced for stringing or threading.
b. beads A necklace made of such pieces.
c. beads Roman Catholic Church A rosary.
d. Obsolete A prayer. Often used in the plural.
2. A small, round object, especially:
a. A drop of moisture: beads of sweat.
b. A bubble of gas in a liquid.
c. A small metal knob on the muzzle of a firearm, such as a rifle, used for sighting.
3. A strip of material, usually wood, with one molded edge placed flush against the inner part of a door or window frame.
4. Architecture
a. A decoration consisting of a usually continuous series of small spherical shapes, as on a convex molding.
b. Beading.
5. A projecting rim or lip, as on a pneumatic tire.
6. A line of continuously applied ductile material, such as solder or caulking compound.
7. Chemistry A globule of fused borax or other flux used in a bead test.
tr. & intr.v. bead·ed, bead·ing, beads
To furnish with or collect into beads.
Idiom:
draw/get a bead on
To take careful aim at.
[Middle English bede, rosary bead, prayer, from Old English bed, bedu, gebed, prayer; see gwhedh- in Indo-European roots.]
The American Heritage® Dictionary of the English Language, Fourth Edition copyright ©2000 by Houghton Mifflin Company. Updated in 2003. Published by Houghton Mifflin Company. All rights reserved.
ThesaurusLegend: Synonyms Related Words Antonyms
Noun 1. beadbead - a small ball with a hole through the middle
bugle - a tubular glass or plastic bead sewn onto clothing for decoration
jewellery, jewelry - an adornment (as a bracelet or ring or necklace) made of precious metals and set with gems (or imitation gems)
2. bead - a shape that is small and round; "he studied the shapes of low-viscosity drops"; "beads of sweat on his forehead"
drop, pearl
round shape - a shape that is curved and without sharp angles
teardrop - anything shaped like a falling drop (as a pendant gem on an earring)
dewdrop - a drop of dew
3. bead - a beaded molding for edging or decorating furniture
astragal, beading, beadwork
moulding, molding - a decorative strip used for ornamentation or finishing
bead and quirk, quirk bead - beading formed with a narrow groove separating it from the surface it decorates
Verb 1. bead - form into beads, as of water or sweat, for example
take form, take shape, spring, form - develop into a distinctive entity; "our plans began to take shape"
2. bead - decorate by sewing beads onto; "bead the wedding gown"
adorn, decorate, grace, ornament, embellish, beautify - make more attractive by adding ornament, colour, etc.; "Decorate the room for the party"; "beautify yourself for the special day"
3. bead - string together like beads
string, thread, draw - thread on or as if on a string; "string pearls on a string"; "the child drew glass beads on a string"; "thread dried cranberries"
benfox
PostPosted: Fri Feb 03, 2006 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't see the equivalent in french my dictionnary is bad ?
Is there a specefical meaning in electronic
It's so cute isn't it. (stupid french man Laughing )
PostPosted: Fri Feb 03, 2006 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's so cute isn't it. (stupid french man :lol: )
I do not know of a specific meaning for electronics, I searched the site you linked to but did not find the word "bead" there - just nice synth stuff :-)
Do you want the french word for "bead" ? http://www.wordreference.com says :
perle, goutte, grain (perle)
Audio files: 227
PostPosted: Fri Feb 03, 2006 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am just guessing, but since this site is about synth circuits, I think bead means a little donut shaped piece of ferrite material that you put a wire through. They are used to increase the inductance of the wire which will act as an RF filter and reduce interference.
Scott Stites
Audio files: 96
PostPosted: Fri Feb 03, 2006 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Ken uses these on the power in lines of all of his modules to reduce any potential RF interference on the power lines. You have the option of replacing it with a 10 to 22 Ohm resistor, which is what I always do with no adverse effects. I use 10 Ohm resistors.
Scott
PostPosted: Fri Feb 03, 2006 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah right, that makes sense - couldn't find it on the site.
benfox
PostPosted: Fri Feb 03, 2006 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanx that's clear to me now !
bugbrand
PostPosted: Sat Feb 04, 2006 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I reckon these are them::
Rapid Electronics Ferrite Beads
I'm doing a couple of Ken Stone designs at the moment and just using 10r resistors
http://www.bugbrand.co.uk
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Aug 14, 2008 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I've found something and I'm not shure is it a bead or choke.
It looks like cylindric piece of ferrite with six little holes and trough that holes wire goes is loop. I'll try to draw this (got no camera and cant find it on net).
I've found it in dead cable modem. Power goes straight trough it.
Can I use this?
 Filesize:  17.21 KB
 Viewed:  5961 Time(s)
PostPosted: Thu Aug 14, 2008 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
This firefox has trouble displaying the jpg, but I guess you mean the "pig snout" thingies, those would be usable.
Like this one :
except it has more holes.
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Aug 14, 2008 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I've uploaded it again. There it is.
So I'm fine. Grrrrreat.
Thnx
a.b.o.z.
G2 patch files: 4
PostPosted: Sat Aug 16, 2008 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
magnet wire??
hmm
Wire that's in loop is too short to solder to pcb..can I use cooper wire instead?
RF
Audio files: 28
PostPosted: Sat Aug 16, 2008 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
'Magnet wire' is just enameled single strand wire...
