benfox
Posted: Fri Feb 03, 2006 11:44 am Post subject:
French vs english bead |
I want to do this
http://www.cgs.synth.net/
What does "bead" means please ?
I know it's really a stupid question for you but... |
Joined: Apr 03, 2004 Posts: 24488 Location: The Netherlands, Enschede
Posted: Fri Feb 03, 2006 11:53 am Post subject:
ben
here is the long answer
Quote: |
bead Pronunciation (bd)
n.
1.
a. A small, often round piece of material, such as glass, plastic, or wood, that is pierced for stringing or threading.
b. beads A necklace made of such pieces.
c. beads Roman Catholic Church A rosary.
d. Obsolete A prayer. Often used in the plural.
2. A small, round object, especially:
a. A drop of moisture: beads of sweat.
b. A bubble of gas in a liquid.
c. A small metal knob on the muzzle of a firearm, such as a rifle, used for sighting.
3. A strip of material, usually wood, with one molded edge placed flush against the inner part of a door or window frame.
4. Architecture
a. A decoration consisting of a usually continuous series of small spherical shapes, as on a convex molding.
b. Beading.
5. A projecting rim or lip, as on a pneumatic tire.
6. A line of continuously applied ductile material, such as solder or caulking compound.
7. Chemistry A globule of fused borax or other flux used in a bead test.
tr. & intr.v. bead·ed, bead·ing, beads
To furnish with or collect into beads.
Idiom:
draw/get a bead on
To take careful aim at.
[Middle English bede, rosary bead, prayer, from Old English bed, bedu, gebed, prayer; see gwhedh- in Indo-European roots.]
The American Heritage® Dictionary of the English Language, Fourth Edition copyright ©2000 by Houghton Mifflin Company. Updated in 2003. Published by Houghton Mifflin Company. All rights reserved.
ThesaurusLegend: Synonyms Related Words Antonyms
Noun 1. beadbead - a small ball with a hole through the middle
bugle - a tubular glass or plastic bead sewn onto clothing for decoration
jewellery, jewelry - an adornment (as a bracelet or ring or necklace) made of precious metals and set with gems (or imitation gems)
2. bead - a shape that is small and round; "he studied the shapes of low-viscosity drops"; "beads of sweat on his forehead"
drop, pearl
round shape - a shape that is curved and without sharp angles
teardrop - anything shaped like a falling drop (as a pendant gem on an earring)
dewdrop - a drop of dew
3. bead - a beaded molding for edging or decorating furniture
astragal, beading, beadwork
moulding, molding - a decorative strip used for ornamentation or finishing
bead and quirk, quirk bead - beading formed with a narrow groove separating it from the surface it decorates
Verb 1. bead - form into beads, as of water or sweat, for example
take form, take shape, spring, form - develop into a distinctive entity; "our plans began to take shape"
2. bead - decorate by sewing beads onto; "bead the wedding gown"
adorn, decorate, grace, ornament, embellish, beautify - make more attractive by adding ornament, colour, etc.; "Decorate the room for the party"; "beautify yourself for the special day"
3. bead - string together like beads
string, thread, draw - thread on or as if on a string; "string pearls on a string"; "the child drew glass beads on a string"; "thread dried cranberries" |
_________________ Jan
benfox
Posted: Fri Feb 03, 2006 1:06 pm Post subject:
I don't see the equivalent in french my dictionnary is bad ?
Is there a specefical meaning in electronic
It's so cute isn't it. (stupid french man ) |
Posted: Fri Feb 03, 2006 1:36 pm Post subject:
benfox wrote: | I don't see the equivalent in french my dictionnary is bad ?
It's so cute isn't it. (stupid french man :lol: ) |
I do not know of a specific meaning for electronics, I searched the site you linked to but did not find the word "bead" there - just nice synth stuff :-)
Do you want the french word for "bead" ? http://www.wordreference.com says :
perle, goutte, grain (perle) _________________ Jan
Joined: Jan 31, 2003 Posts: 18252 Location: Durham, NC
Audio files: 227
Posted: Fri Feb 03, 2006 1:39 pm Post subject:
I am just guessing, but since this site is about synth circuits, I think bead means a little donut shaped piece of ferrite material that you put a wire through. They are used to increase the inductance of the wire which will act as an RF filter and reduce interference. _________________ --Howard
my music and other stuff |
Scott Stites
Audio files: 96
Posted: Fri Feb 03, 2006 1:42 pm Post subject:
Yes, Ken uses these on the power in lines of all of his modules to reduce any potential RF interference on the power lines. You have the option of replacing it with a 10 to 22 Ohm resistor, which is what I always do with no adverse effects. I use 10 Ohm resistors.
Scott |
Posted: Fri Feb 03, 2006 1:50 pm Post subject:
Ah right, that makes sense - couldn't find it on the site. _________________ Jan
benfox
Posted: Fri Feb 03, 2006 5:13 pm Post subject:
Thanx that's clear to me now ! |
bugbrand
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Thu Aug 14, 2008 10:28 am Post subject:
This firefox has trouble displaying the jpg, but I guess you mean the "pig snout" thingies, those would be usable.
Like this one :
except it has more holes. _________________ Jan
a.b.o.z.
G2 patch files: 4
Posted: Thu Aug 14, 2008 10:30 am Post subject:
I've uploaded it again. There it is.
So I'm fine. Grrrrreat.
Thnx |
a.b.o.z.
G2 patch files: 4
Posted: Sat Aug 16, 2008 10:32 am Post subject:
magnet wire??
hmm
Wire that's in loop is too short to solder to pcb..can I use cooper wire instead? |
RF
Audio files: 28
Posted: Sat Aug 16, 2008 7:49 pm Post subject:
'Magnet wire' is just enameled single strand wire... |
