Bill's Sound Lab Construction pictures.
Page 1 of 2 [32 Posts]
lynes
PostPosted: Sat Feb 18, 2006 8:22 pm    Post subject: Bill's Sound Lab Construction pictures. Reply with quote  Mark this post and the followings unread
I'm going to document the construction of my Sound Lab with a digital camera. Here is the first batch of photographs.
I made up the drilling template from my front panel design in MS Visio, flipped in horizontally and taped it to the inside of the case. This allowed me to drill with the sloping panel lying flat on the drill press table.
I made up two power supplies, one with a LM317 for +9v and one with a LM337 for -9v.
Any comments are welcome.
Drilling holes in SL case from the inside.
 Filesize:  58.47 KB
 Viewed:  332 Time(s)
Drilling complete, holes reamed out to make them nice ond round, burrs removed.
 Filesize:  41.73 KB
 Viewed:  319 Time(s)
Two 9v power supplies, one pos, one neg.
 Filesize:  60.48 KB
 Viewed:  338 Time(s)
Scott Stites
Audio files: 96
PostPosted: Sat Feb 18, 2006 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
lynes
PostPosted: Sun Feb 19, 2006 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Another two photo's. I fitted the pots,knobs, switches, jacks and LED's to the front panel with a paper copy of my front panel design.
I did this to check the front panel layout and the spacing of the parts on the inside of the panel. Everything looks OK, I have enough room for the internal wiring and only need to make minor adjustments to the panel design.
Bill
Front Panel close up.
 Filesize:  60.46 KB
 Viewed:  375 Time(s)
Front panel with everything fitted.
 Filesize:  55.55 KB
 Viewed:  396 Time(s)
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Feb 19, 2006 10:29 am    Post subject: Re: Bill's Sound Lab Construction pictures. Reply with quote  Mark this post and the followings unread
it looks cool to me and I guess it sounds even cooler than it looks Very Happy
Audio files: 235
PostPosted: Sun Feb 19, 2006 3:05 pm    Post subject:   Reply with quote  Mark this post and the followings unread
It looks beautiful. Nice job. thumb up
dnny
PostPosted: Mon Feb 20, 2006 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
wow - really professional looking.
www.koelse.org
flickr: cable porn group
Wild Zebra
PostPosted: Mon Feb 20, 2006 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice indeed Razz
"your stripes are killer bro"
lynes
PostPosted: Mon Feb 20, 2006 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Guys,
Next step is to put all Ray's mods and tweaks onto some protoboards and work out the wiring to connect to the main board and front panel components.
Bill
PostPosted: Wed Feb 22, 2006 2:24 am    Post subject: front panel drilling Reply with quote  Mark this post and the followings unread
Hello Bill Smile
A very professional-looking front panel indeed.
I noticed that you emphasise about drilling from the back to the front. Is there a particular reason for doing it like that?
Tom
PS- that's a nice drill press too Smile
lynes
PostPosted: Wed Feb 22, 2006 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Drilling from the inside of the case allowed me to lay the case flat onto the horizontal table of the drill press. I could then drill the hole perpendicular to the surface of the sloping front.
If I had drilled the hole from the outside I would have had to prop up the case edges to again make the sloping front horizontal and ensure perpendicular holes.
I hope that makes sense.
Bill
opg
PostPosted: Wed Feb 22, 2006 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
This is great! A real piece of art. I'll keep this in mind when I get around to the SoundLab. I have a drill press just sitting there, asking me "Why aren't you using me to build a SoundLab yet?"
PostPosted: Wed Feb 22, 2006 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes- totally. I only ask because this is an educational forum. Hopefully by asking 'dumb' questions- others not so knowledgeable will also learn Smile
toppobrillo
PostPosted: Wed Feb 22, 2006 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
using tip jacks eh? i like those too.
PostPosted: Wed Feb 22, 2006 10:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really great looking!
What did you use to do the silk screening? I'd be interested in that process as well (complete with pics of course Smile Smile )
lynes
PostPosted: Wed Feb 22, 2006 10:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its a fake!.... I have not produced the final front panel graphic yet. What you can see in the photograph is just a paper copy of my design sandwiched between the pot, jack and switch nuts and the sloping front of the case.
I intend to print a good quality print then laminate the paper and stick it to the front panel.
Alternatively I may try and do something with Letraset inkjet film. If anyone has any experience using this I would be very interested in hearing about it.
Bill
toppobrillo
PostPosted: Wed Feb 22, 2006 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think i am going to try to make decals by printing onto paper with a laser then spraying it with clear enamel many coats, then soaking it in warm water.
PostPosted: Thu Feb 23, 2006 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Very smooth, and professional.
Scirocco
PostPosted: Thu Feb 23, 2006 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Absolutely nice job, It looks awesome !!!! Very Happy
Have a nice day Very Happy
http://www.flickr.com/photos/monocapa/
lynes
PostPosted: Sat Feb 25, 2006 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its tight, but I think its all going to fit in the box.
Will it all fit in the box?
 Filesize:  64.9 KB
 Viewed:  19433 Time(s)
PostPosted: Sat Feb 25, 2006 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beeaauuty Full!! Smile
toppobrillo
PostPosted: Sat Feb 25, 2006 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats a big ol' transformer there.
lynes
PostPosted: Sat Feb 25, 2006 9:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its a little bit big.... I suppose I could find a smaller one. This one is 2 1/4 W x 2 1/4 D x 1 3/4 H. Its one that I had in my 'Come in Handy Transformer Box'. Maybe I could splurge and get myself another smaller one. Laughing
Bill
lynes
PostPosted: Mon Mar 06, 2006 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok Its been a while since I posted any photographs, most of my time on the project has been spent on the wiring design and finalizing the front panel. The front panel is now complete. I printed out my final design on some 32lb presentation bright white paper using a laser printer..... then I laminated the print and cut it to size with a scalpel knife. Next I stuck down 2 strips of 4 inch wide 'adhesive transfer tape' onto the back of the laminate. Then I cut out four of the corner potentiometer holes with my trusty 'sharp' scalpel. I used four of the tip jacks sticking up from the inside of the case to align the laminate, I removed the 'adhesive tape backing and carefully lowered the laminate over the jacks onto the case. After cutting out the remainder of the holes I mounted all the hardware onto the case. The photograph shows the final result minus the knobs.
Tonight I spent about 3 hours on the front panel wiring. I have included most of the sound patch outs and tweaks, so I ended up drawing out my own wiring diagram simular to the one on Ray's web site. It really helped as I started the wiring. The second picture shows the wiring so far.
Thanks for all the great feedback
Bill
Inside of the front panel after 3 hours of soldering.
 Filesize:  183.22 KB
 Viewed:  314 Time(s)
Front panel complete.
 Filesize:  145.6 KB
 Viewed:  316 Time(s)
My wiring diagram draw using visio. Really helps to keep me on track with the wiring.
 Filesize:  213.91 KB
 Viewed:  393 Time(s)
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Mar 07, 2006 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
wonder full Exclamation Very Happy
Wild Zebra
PostPosted: Tue Mar 07, 2006 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a question. Oh and it looks awesome. So I see you have a rate LED for your LFO. How did you do it? Like Ray's diagram? I always had trouble with mine so I unhooked it. It allways "pulled down" on my oscillators even when I didn't have them patched to the LFO. Know what I'm saying? Without the LFO patched my OSC would be slightly effected by the LFO's LED.
