lynes
Posted: Sat Feb 18, 2006 8:22 pm Post subject:
Bill's Sound Lab Construction pictures. |
I'm going to document the construction of my Sound Lab with a digital camera. Here is the first batch of photographs.
I made up the drilling template from my front panel design in MS Visio, flipped in horizontally and taped it to the inside of the case. This allowed me to drill with the sloping panel lying flat on the drill press table.
I made up two power supplies, one with a LM317 for +9v and one with a LM337 for -9v.
Any comments are welcome.
| Drilling holes in SL case from the inside. |
58.47 KB |
| Viewed: |
333 Time(s) |
| Drilling complete, holes reamed out to make them nice ond round, burrs removed. |
41.73 KB |
| Viewed: |
321 Time(s) |
| Two 9v power supplies, one pos, one neg. |
60.48 KB |
| Viewed: |
339 Time(s) |
Scott Stites
Audio files: 96
Posted: Sat Feb 18, 2006 9:10 pm Post subject:
lynes
Posted: Sun Feb 19, 2006 1:08 am Post subject:
Another two photo's. I fitted the pots,knobs, switches, jacks and LED's to the front panel with a paper copy of my front panel design.
I did this to check the front panel layout and the spacing of the parts on the inside of the panel. Everything looks OK, I have enough room for the internal wiring and only need to make minor adjustments to the panel design.
Bill
60.46 KB |
| Viewed: |
376 Time(s) |
| Front panel with everything fitted. |
55.55 KB |
| Viewed: |
397 Time(s) |
seraph
Editor
Audio files: 33
Posted: Sun Feb 19, 2006 10:29 am Post subject:
Re: Bill's Sound Lab Construction pictures. |
| lynes wrote: |
Any comments are welcome. |
it looks cool to me and I guess it sounds even cooler than it looks  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Joined: Jan 31, 2003 Posts: 18325 Location: Durham, NC
Audio files: 235
Posted: Sun Feb 19, 2006 3:05 pm Post subject:
It looks beautiful. Nice job.  _________________ --Howard
my music and other stuff |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Wild Zebra
Posted: Mon Feb 20, 2006 9:28 am Post subject:
Very nice indeed  _________________ "your stripes are killer bro" |
lynes
Posted: Mon Feb 20, 2006 9:37 am Post subject:
Thanks Guys,
Next step is to put all Ray's mods and tweaks onto some protoboards and work out the wiring to connect to the main board and front panel components.
Bill |
Posted: Wed Feb 22, 2006 2:24 am Post subject:
front panel drilling |
Hello Bill
A very professional-looking front panel indeed.
I noticed that you emphasise about drilling from the back to the front. Is there a particular reason for doing it like that?
Tom
PS- that's a nice drill press too  |
lynes
Posted: Wed Feb 22, 2006 6:54 am Post subject:
Drilling from the inside of the case allowed me to lay the case flat onto the horizontal table of the drill press. I could then drill the hole perpendicular to the surface of the sloping front.
If I had drilled the hole from the outside I would have had to prop up the case edges to again make the sloping front horizontal and ensure perpendicular holes.
I hope that makes sense.
Bill |
opg
Joined: Mar 29, 2004 Posts: 954 Location: Berkeley, CA, US
Posted: Wed Feb 22, 2006 7:17 am Post subject:
| This is great! A real piece of art. I'll keep this in mind when I get around to the SoundLab. I have a drill press just sitting there, asking me "Why aren't you using me to build a SoundLab yet?" |
Posted: Wed Feb 22, 2006 7:42 am Post subject:
| lynes wrote: | I hope that makes sense.
Oh yes- totally. I only ask because this is an educational forum. Hopefully by asking 'dumb' questions- others not so knowledgeable will also learn  |
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Wed Feb 22, 2006 8:17 pm Post subject:
| using tip jacks eh? i like those too. |
Posted: Wed Feb 22, 2006 10:07 pm Post subject:
Really great looking!
What did you use to do the silk screening? I'd be interested in that process as well (complete with pics of course ) |
lynes
Posted: Wed Feb 22, 2006 10:17 pm Post subject:
Its a fake!.... I have not produced the final front panel graphic yet. What you can see in the photograph is just a paper copy of my design sandwiched between the pot, jack and switch nuts and the sloping front of the case.
I intend to print a good quality print then laminate the paper and stick it to the front panel.
Alternatively I may try and do something with Letraset inkjet film. If anyone has any experience using this I would be very interested in hearing about it.
Bill |
toppobrillo
Posted: Wed Feb 22, 2006 11:12 pm Post subject:
| i think i am going to try to make decals by printing onto paper with a laser then spraying it with clear enamel many coats, then soaking it in warm water. |
Posted: Thu Feb 23, 2006 3:39 am Post subject:
Very smooth, and professional. _________________ What makes a space ours, is what we put there, and what we do there. |
Scirocco
Joined: Dec 11, 2005 Posts: 22 Location: Barcelona/Catalunya
lynes
Posted: Sat Feb 25, 2006 5:32 pm Post subject:
Beeaauuty Full!!  _________________ What makes a space ours, is what we put there, and what we do there. |
toppobrillo
Posted: Sat Feb 25, 2006 9:06 pm Post subject:
| thats a big ol' transformer there. |
lynes
Posted: Sat Feb 25, 2006 9:34 pm Post subject:
Its a little bit big.... I suppose I could find a smaller one. This one is 2 1/4 W x 2 1/4 D x 1 3/4 H. Its one that I had in my 'Come in Handy Transformer Box'. Maybe I could splurge and get myself another smaller one.
Bill |
lynes
Posted: Mon Mar 06, 2006 11:20 pm Post subject:
Ok Its been a while since I posted any photographs, most of my time on the project has been spent on the wiring design and finalizing the front panel. The front panel is now complete. I printed out my final design on some 32lb presentation bright white paper using a laser printer..... then I laminated the print and cut it to size with a scalpel knife. Next I stuck down 2 strips of 4 inch wide 'adhesive transfer tape' onto the back of the laminate. Then I cut out four of the corner potentiometer holes with my trusty 'sharp' scalpel. I used four of the tip jacks sticking up from the inside of the case to align the laminate, I removed the 'adhesive tape backing and carefully lowered the laminate over the jacks onto the case. After cutting out the remainder of the holes I mounted all the hardware onto the case. The photograph shows the final result minus the knobs.
Tonight I spent about 3 hours on the front panel wiring. I have included most of the sound patch outs and tweaks, so I ended up drawing out my own wiring diagram simular to the one on Ray's web site. It really helped as I started the wiring. The second picture shows the wiring so far.
Thanks for all the great feedback
Bill
| Inside of the front panel after 3 hours of soldering. |
183.22 KB |
| Viewed: |
315 Time(s) |
145.6 KB |
| Viewed: |
316 Time(s) |
| My wiring diagram draw using visio. Really helps to keep me on track with the wiring. |
213.91 KB |
| Viewed: |
393 Time(s) |
seraph
Editor
Audio files: 33
Posted: Tue Mar 07, 2006 12:37 am Post subject:
wonder full  _________________ homepage - blog - forum - youtube
Wild Zebra
Posted: Tue Mar 07, 2006 8:19 am Post subject:
I have a question. Oh and it looks awesome. So I see you have a rate LED for your LFO. How did you do it? Like Ray's diagram? I always had trouble with mine so I unhooked it. It allways "pulled down" on my oscillators even when I didn't have them patched to the LFO. Know what I'm saying? Without the LFO patched my OSC would be slightly effected by the LFO's LED. _________________ "your stripes are killer bro" |
