 Forum index » Artists » Howard Moscovitz
The studio
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
cp
PostPosted: Sun Feb 26, 2006 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
I have even less of a need for a patch bay now than I had in 2003 when that picture was taken. I've gotten rid of the Mackie mixer now. All signals go into a MOTU 828MK2. I do all routings under computer control.
Are you mixing In The 828Mk2 Box?
I just *introduced* a patchbay in order to have indirection
both in and out of the 828MKII and mix Outside of the Box,
which to me sounds better than the in-the-box 828.
mosc wrote:
less is more.
Code:
~: ls -l /usr/bin/less
-rwxr-xr-x  1 root root 104604 Mar 29  2004 /usr/bin/less
~: ls -l /bin/more
-rwxr-xr-x  1 root root 32720 Nov 29  2004 /bin/more
thinking I don't understand how this shows equivalence, there is no symbolic link?
Caseypa
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Feb 26, 2006 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
you seem to forget that Mosc can travel from one dimension to another in the blink of an eye Shocked
PostPosted: Sun Feb 26, 2006 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
A paradox !
Count the bytes :-)
cp
PostPosted: Sun Feb 26, 2006 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed Got it!!!!!
cp
PostPosted: Sun Feb 26, 2006 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am fairly sure Howard does his mixing ITB but using his DAW for internal summing, and he is not actually mixing much outside of the DAW.
You are doing all the major summing in the analog domain? DACs to analog summing devices?
cp
PostPosted: Sun Feb 26, 2006 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just set it up-- two 828MK2's (total of 16 channel outs)
into a Rane SM-82 line mixer for the summing and the
effects loop for external effects. Trouble I'm running into
is trying to utilize the OS X Core Audio capability of creating
an Aggregate Device out of the 2 828's so that it can be
treated as one interface from the software's point of view.
I can create the device but it only shows half the number
of I/O as I expect.
cp
