cp
Posted: Sun Feb 26, 2006 10:48 am Post subject:
mosc wrote: | I have even less of a need for a patch bay now than I had in 2003 when that picture was taken. I've gotten rid of the Mackie mixer now. All signals go into a MOTU 828MK2. I do all routings under computer control. |
Are you mixing In The 828Mk2 Box?
I just *introduced* a patchbay in order to have indirection
both in and out of the 828MKII and mix Outside of the Box,
which to me sounds better than the in-the-box 828.
mosc wrote: | less is more.
Code: | ~: ls -l /usr/bin/less
-rwxr-xr-x 1 root root 104604 Mar 29 2004 /usr/bin/less
~: ls -l /bin/more
-rwxr-xr-x 1 root root 32720 Nov 29 2004 /bin/more |
I don't understand how this shows equivalence, there is no symbolic link?
Caseypa |
seraph
Editor
Audio files: 33
Posted: Sun Feb 26, 2006 11:36 am Post subject:
cp wrote: |
I don't understand how this shows equivalence, there is no symbolic link? |
you seem to forget that Mosc can travel from one dimension to another in the blink of an eye  _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
Joined: Apr 03, 2004 Posts: 24451 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sun Feb 26, 2006 12:09 pm Post subject:
A paradox !
Count the bytes :-) _________________ Jan
cp
Posted: Sun Feb 26, 2006 12:58 pm Post subject:
Got it!!!!!
cp |
Posted: Sun Feb 26, 2006 1:04 pm Post subject:
cp wrote: | Are you mixing In The 828Mk2 Box? |
I am fairly sure Howard does his mixing ITB but using his DAW for internal summing, and he is not actually mixing much outside of the DAW.
You are doing all the major summing in the analog domain? DACs to analog summing devices? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
cp
Posted: Sun Feb 26, 2006 2:42 pm Post subject:
elektro80 wrote: | You are doing all the major summing in the analog domain? DACs to analog summing devices? |
Just set it up-- two 828MK2's (total of 16 channel outs)
into a Rane SM-82 line mixer for the summing and the
effects loop for external effects. Trouble I'm running into
is trying to utilize the OS X Core Audio capability of creating
an Aggregate Device out of the 2 828's so that it can be
treated as one interface from the software's point of view.
I can create the device but it only shows half the number
of I/O as I expect.
cp |
