torsig1967
Posted: Mon Apr 03, 2006 1:56 pm Post subject:
Patch: Bar arpeggiator Subject description: A nice arpeggiator patch |
Here's a patch called "barpeggiator 6tone". It's an arpeggiator that syncs to midicklock, can hold up to 6 notes and will resync at every bar border.
This is the first time I've managed to make a sensible arpeggiator on the NM1. I found it hard to make the basic components for this unit and I'd like to share my findings so I enclose two pictures explaining and describing how this unit is made.
Closer description:
- The arpeggiator will always play the current state until a bar border.
- It will play the notes that where pressed before the latest bar border.
- It will play 1-6 notes, repeatedly in the order they were pressed.
- Even if nothing is changed, the arpeggiator will always start from the first note at bar borders, making the time signature more obvious even for odd key numbers.
- As long as one key is held down one can add new notes.
- When all keys are released, the memory will be cleared next time a key is pressed. Starting all over.
- If more than 6 keys are pressed the result is undefined - although quite nice.
- Seems like this arpeggiator cannot handle interactive tempo changes.
Hope someone can enjoy this.
Tor Sigvardson
| Description: |
| This is the patch with the main sub-units marked. |
| Filesize: |
288.29 KB |
| Viewed: |
419 Time(s) |
| Description: |
| Handmade drawing of the schematics to make things clearer. Same names used as in the picture of the patch. |
| Filesize: |
181.44 KB |
| Viewed: |
376 Time(s) |
| Description: |
| The patch, zipped for compability. It needs midiclock running to work. Always start playing at the beginning of a bar. |
 Download (listen) |
| Filename: |
barpeggio 6tone MCLK.zip |
| Filesize: |
1.97 KB |
| Downloaded: |
439 Time(s) |
Joined: Apr 03, 2004 Posts: 24591 Location: The Netherlands, Enschede
Audio files: 309
Posted: Mon Apr 03, 2006 2:52 pm Post subject:
Nice one (even though I dont use the Classic very much anymore), and you even left some room for a synth
BTW, there should be no need to zip patches, was there ? _________________ Jan
torsig1967
Posted: Tue Apr 04, 2006 1:33 am Post subject:
| Blue Hell wrote: | | BTW, there should be no need to zip patches, was there ? |
OK. I belive I read something about Mac/PC problems with patches and since I'm on Mac I thought it would be better.
Since the classic is so small I thought I'd keep it as an auxiliary unit. My G2 should arrive later this week  |
Audio files: 309
Posted: Tue Apr 04, 2006 11:01 am Post subject:
| torsig1967 wrote: |
OK. I belive I read something about Mac/PC problems with patches and since I'm on Mac I thought it would be better. |
We had a lot of trouble with that on the mailing list yes, but when you'd add a pch extension (just to be nice to the PC people) all should be fine I guess. _________________ Jan
