Patch: Bar arpeggiator
Page 1 of 1 [4 Posts]
torsig1967
PostPosted: Mon Apr 03, 2006 1:56 pm    Post subject: Patch: Bar arpeggiator
Subject description: A nice arpeggiator patch
Here's a patch called "barpeggiator 6tone". It's an arpeggiator that syncs to midicklock, can hold up to 6 notes and will resync at every bar border.
This is the first time I've managed to make a sensible arpeggiator on the NM1. I found it hard to make the basic components for this unit and I'd like to share my findings so I enclose two pictures explaining and describing how this unit is made.
Closer description:
- The arpeggiator will always play the current state until a bar border.
- It will play the notes that where pressed before the latest bar border.
- It will play 1-6 notes, repeatedly in the order they were pressed.
- Even if nothing is changed, the arpeggiator will always start from the first note at bar borders, making the time signature more obvious even for odd key numbers.
- As long as one key is held down one can add new notes.
- When all keys are released, the memory will be cleared next time a key is pressed. Starting all over.
- If more than 6 keys are pressed the result is undefined - although quite nice.
- Seems like this arpeggiator cannot handle interactive tempo changes.
Hope someone can enjoy this.
Tor Sigvardson
This is the patch with the main sub-units marked.
 Filesize:  288.29 KB
 Viewed:  429 Time(s)
Handmade drawing of the schematics to make things clearer. Same names used as in the picture of the patch.
 Filesize:  181.44 KB
 Viewed:  388 Time(s)
barpeggio 6tone MCLK.zip
The patch, zipped for compability. It needs midiclock running to work. Always start playing at the beginning of a bar.
 Filename:  barpeggio 6tone MCLK.zip
 Filesize:  1.97 KB
 Downloaded:  445 Time(s)
PostPosted: Mon Apr 03, 2006 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one (even though I dont use the Classic very much anymore), and you even left some room for a synth Wink
BTW, there should be no need to zip patches, was there ?
torsig1967
PostPosted: Tue Apr 04, 2006 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
OK. I belive I read something about Mac/PC problems with patches and since I'm on Mac I thought it would be better.
Since the classic is so small I thought I'd keep it as an auxiliary unit. My G2 should arrive later this week Razz
PostPosted: Tue Apr 04, 2006 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
We had a lot of trouble with that on the mailing list yes, but when you'd add a pch extension (just to be nice to the PC people) all should be fine I guess.
