Drum Machine
Page 1 of 1 [10 Posts]
hjnewcomb
PostPosted: Thu Apr 13, 2006 11:03 am    Post subject:  Drum Machine
Subject description: Drum machine for performing live
in a fairly new electro acoustic etc band
im looking for a cheap as pos hardware drum machine
with sequencer on board as well maybe so i can save beats onto it from mac and maybe bass line too ?
and change them live atm i have been looking at stuff like that.. Boss DR202 Dr Groove bt that went on ebay at 77 in the end....
im a young student cheapskate....
hoping for sumthing around 30... any1 got any ideas..
thanks again guys..
H
Mohoyoho
PostPosted: Fri Apr 14, 2006 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
See if you can find a good deal on a Yamaha RM1X. That should do all that you request.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
machinefunk
PostPosted: Mon May 01, 2006 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
For that kind of money I would think the only thing you'll be able to get would be like a TR505.
x0x
PostPosted: Tue May 02, 2006 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
$30 will not get you much. Even a 707 is above a hundred dollars these days.
deknow
PostPosted: Tue May 02, 2006 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
...you might find an alesis hr-16 for that price, and for that price they are pretty good....plus, the manual is printed right on the darn thing!
deknow
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue May 02, 2006 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
right, I had forgotten about it. Very Happy the HR16 was my main source of drum sounds for a long time. it was really nice with each sound separately tunable.
ewblank
PostPosted: Tue May 02, 2006 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure you're going to find that in one unit, but this might work for you: The Roland TR-505 mentioned earlier usually goes for under $100, and has a midi-out, which isn't a feature the lower-cost drum machines (ie: zoom) on the market. You can sync that up with a Yamaha SU10 - which is a tiny midi-enabled sampler.
I think you could probably get a half decent drum/bass/ sample set up with these for under $150. It won't sound like Aphex Twin or Chemical Brothers - but it'll work. If you have any other cash, I'd also invest an a cheap multi-FX unit for the TR-505 - and the sounds on it are not tweakable and can usually use some help.
Good luck.
Reality is Subjective
Audio files: 235
PostPosted: Tue May 02, 2006 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the HR 16 was really a hot device in its day. I had one too. Still have it in fact...
http://www.synthmania.com/alesis_hr-16.htm
PostPosted: Tue May 02, 2006 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is your MAC a laptop? or portable? Can you get all your sounds from samplers, VSTs, or AU on the MAC?
That'd save you a bunch of $$, and unless you need the hardware interface, you could do everything on the MAC.
At least, that's the cheapest way to do things.
X-Electric
PostPosted: Sat May 13, 2006 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget about cheap QY-20 and similiar by Yamaha. They're just a simple music notepads with XG(?) sample set, but they're pretty usefull. 28k note onboard sequencer, MIDI IN/OUT, 8 part multitimbral and they go waaay below $100. Could work well as a drum machine, with sequencing possibilities. (AFAIK it works in pattern mode).
