sync cable
Page 1 of 1 [6 Posts]
Pehr
PostPosted: Mon May 01, 2006 11:21 am    Post subject: sync cable Reply with quote  Mark this post and the followings unread
0k, this might be a stupid question Embarassed , but could I use a MIDI-cable from sync to sync or is there a special sync-cable? Both uses DIN connections right? Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
x0x
PostPosted: Mon May 01, 2006 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
You do NOT want to use a MIDI cable for DIN Sync unless you are positive all 5 wires are live inside of the cable, MIDI only uses 3 of the 5 so the other 2 are not connected correctly.
IIRC, DIN Cables are compatible with MIDI but not visa-versa.
I've heard stories about people frying the DIN sync on 808s by using a MIDI cable.
Pehr
PostPosted: Mon May 01, 2006 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, I know that connecting midi to sync isn't a good idea... but I still don't understand. Embarassed Whats the difference between a midi-cable and a sync-cable... they both look like this
Is one of them crossed or what?
YouTube channel
flickr photostream
Audio files: 229
PostPosted: Mon May 01, 2006 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
They may look the same, but the internal wiring between the pins on the two ends may not be the same.
Pehr
PostPosted: Mon May 01, 2006 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was what I thought...
YouTube channel
flickr photostream
x0x
PostPosted: Mon May 01, 2006 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I always forget to post this:
http://en.wikipedia.org/wiki/DIN_Sync
