Axiom
G2 patch files: 28
Posted: Sun Feb 19, 2006 7:46 am Post subject:
GX7 - Yamaha DX7 to Modular G2 Conversion Tool Subject description: First beta release |
Introduction
How many times you have desired to convert your old Yamaha DX7 sounds to your new Clavia Nord Modular G2? Clavia gave us a good starting point, including FM Operators and a DX Router as modules. Each parameter is here, ready to be tweaked to achive our beloved DX sounds. But how tedious is tweak all those parameters manually?
People starts asking for a tool that helps G2 users to load Yamaha patches into their new G2 synthesizer but, until now, nothing was created.
This tool let you load any Yamaha DX7 SysEx bank and let you send patch parameters as Midi CC# to your G2 synthesizer. There are some limitations that don’t let us to send all parameters at once. DX7 parameters are over 150 while G2 usable Midi CC are less then 120. The workaround is to send parameters one Operator per time, doing some hand work on your G2 Editor.
Contents:
Inside the program you'll find a DX7 Template and the original DX7 ROM1a bank file converted to G2 format.
This program is Freeware. You can use it everywhere and you can share it. I only ask to you to join ProgSounds, in order to download this software, and share the link to this post instead sharing the file directly.
Musically,
Luca _________________
tombola
G2 patch files: 9
Posted: Sun Feb 19, 2006 9:16 am Post subject:
Great! Thank you. I've so far only been playing with the preset bank you created.
When changing patches, I get a weird 'tuning up' period - say I load batch 25-32, then hold down a chord, and the pitch rises slowly and it takes a few seconds to reach normal tune. Anyone know what's going on? _________________ http://www.musicthing.co.uk/ |
Axiom
G2 patch files: 28
Posted: Sun Feb 19, 2006 10:03 am Post subject:
Yes, I got the same issue. I think that is the Pitch envelope or the lfo.. I have to tweak the patch better.
Luca
p.s.:
I hope to see this news on Musicthing  _________________
jamos
Joined: Jun 01, 2004 Posts: 514 Location: Eugene, Oregon, USA
G2 patch files: 41
Posted: Sun Feb 19, 2006 2:16 pm Post subject:
I must be missing something here.
Why not just pump the DX7 data into a G2 .pch2 file and skip the MIDI CC step? The G2 file information has been reverse engineered - |
Joined: Apr 03, 2004 Posts: 24422 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sun Feb 19, 2006 3:56 pm Post subject:
jamos wrote: | The G2 file information has been reverse engineered - |
Unfortunately not completely, there is a lot of work to be done on that still. _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Feb 19, 2006 4:07 pm Post subject:
Well, I installed and even downloaded MSCoree.dll, but now it wants me to do... WHAT?
'Please set registry key HKLM\Software\Microsoft\.NETFramework\InstallRoot to point to the .NET Framework install location'
Who knows, tell it to me what it means...
Wout |
Audio files: 297
Posted: Sun Feb 19, 2006 4:18 pm Post subject:
Wout, you need the .net framework. _________________ Jan
Audio files: 297
Posted: Sun Feb 19, 2006 4:32 pm Post subject:
Oh that was the version 1.1. link, there is also a 2.0 version
Both seem to be suitable for win 98. _________________ Jan
cappy2112
Joined: Dec 24, 2004 Posts: 2494 Location: San Jose, California
Posted: Wed Feb 22, 2006 2:02 am Post subject:
Re: GX7 - Yamaha DX7 to Modular G2 Conversion Tool Subject description: First beta release |
Axiom wrote: |
Introduction
Luca |
Nice Job !! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Feb 22, 2006 5:19 am Post subject:
Hoppaah!
It chrashes as soon as I have loaded a sysex file and try to configure. Maybe I need to cinnect the Midi first
Wout
(digi-don't-know-how) |
Axiom
G2 patch files: 28
Posted: Wed Feb 22, 2006 6:24 am Post subject:
can you report me the error message?
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Feb 22, 2006 8:52 am Post subject:
Error Message |
Quote: |
Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Input string was not in a correct format.
Details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at gx7.fCmCfg.LoadCfg()
at gx7.fCmCfg..ctor()
at gx7.MainForm.btnCmCfgClick(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/MICROSOFT.NET/FRAMEWORK/V2.0.50727/mscorlib.dll
gx7
Assembly Version: 1.0.2241.20008
Win32 Version: 1.0.2241.20008
CodeBase: file:///F:/GX7/GX7.EXE
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Wout |
Axiom
G2 patch files: 28
Posted: Sat May 13, 2006 4:32 am Post subject:
I've just release a new version v0.9.2 that fixes some issues. Please upgrade your installation.
monobass
G2 patch files: 12
Posted: Mon Jun 12, 2006 3:38 pm Post subject:
Out of interest does anyone have a zip file full of converted DX7 patches they want to give me?  _________________ Steve |
Axiom
G2 patch files: 28
Posted: Tue Jun 13, 2006 5:57 am Post subject:
I've put a subsection, where you can download gx7, where users can upload their converted patches. take a look  _________________
monobass
G2 patch files: 12
Posted: Tue Jun 13, 2006 6:11 am Post subject:
Axiom wrote: | I've put a subsection, where you can download gx7, where users can upload their converted patches. take a look  |
ah.. duh.. I managed to look straight past that.. thanks
I just need to recreate my dx100 bass of doom from memory and I CAN TAKE OVER THE WORLD. muahaha. _________________ Steve |
monobass
G2 patch files: 12
Posted: Tue Jun 13, 2006 12:04 pm Post subject:
So looking at the library page there are not many patches..
So is anyone planning to convert all the original DX7 presets?
I'm a mac user so it's out of my reach! _________________ Steve |
W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Tue Oct 09, 2007 5:27 am Post subject:
where can i download GX7? the link is not working  |
Audio files: 297
Posted: Tue Oct 09, 2007 12:24 pm Post subject:
W.T. wrote: | where can i download GX7? the link is not working :( |
When you want to convert DX7 patches to NM G2 patches have look at http://electro-music.com/forum/topic-15405.html . I think Luca removed his tool after the g2ools stuff was made? _________________ Jan
W.T.
G2 patch files: 11
Posted: Tue Oct 09, 2007 12:42 pm Post subject:
thank you very much Jan! |
