Crackle Box DIY Synth Project
Page 2 of 4 [76 Posts]
Wild Zebra
PostPosted: Tue May 30, 2006 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
What does C3 2n9 do in the crackling. After a quick check by bugbrand on my perfboard layout(if you can call it that) It's been said I did it right, (YEH) but I was curious about C3 cause I used a 2n2. I reckon it wasn't enough difference to make a difference, but what do I know. Also the added electro cap for the optional led. Don't you normally add a limiting resistor? What is the purpose of the cap? Just wanting to know.
thanks Take care
"your stripes are killer bro"
choklitlove
Audio files: 17
PostPosted: Wed Jun 21, 2006 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
if anyone is interested, i've done a layout for the cracklebox. it's here: http://geocities.com/worthekik/crackle.html
i haven't been able to test it yet, so maybe someone can help me verify it. either way, check out the rest of the site also, if you want. i don't really care. thanks!
Wild Zebra
PostPosted: Wed Jun 21, 2006 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I not an expert, but I thought it was bad to have an out jack to amp. W/O having some sort of transformer thingy like bugbrand did.
dnny
PostPosted: Wed Jun 21, 2006 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
that output needs to go directly to 8ohm speaker (small).
but you can always mod it whit bugs instructions
thanks for posting the layout.
www.koelse.org
flickr: cable porn group
choklitlove
Audio files: 17
PostPosted: Wed Jun 21, 2006 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, it should work fine with just an 8 ohm for now.
i'll make another layout with bugbrand's additions. possibly a switch with the headphone or ouput jack that connects bugbrand's addition when something is plugged in.
that brings me to a question: how would bugbrand's addition work with an 8 ohm speaker? just curious because it would be nice to not have to make it switch. thanks!
Wild Zebra
PostPosted: Wed Jun 21, 2006 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeh THANKS, yet to try Bancika's layout program. Gotta get my computer hooked up at home. The first thing I was going to try was a Cracklebox. fixin to make that passive mixer an your site for all my battery operated noise boxes. Was going to do the one on general guitar gadgets, but fewer parts means less money!
bugbrand
PostPosted: Wed Jun 21, 2006 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey there - I just posted a message on your site 'cos I think you've got the 14pin version pins muddled - check the LM709 datasheet 'cos its pins 1 & 2, 7 & 8, 13 & 14 that aren't connected.
I had problems taking an audio output instead of the speaker... I'd not have used a transformer otherwise! (('cos I don't know too much about them really...!...))
http://www.bugbrand.co.uk
choklitlove
Audio files: 17
PostPosted: Wed Jun 21, 2006 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
bugbrand-
thanks. i just went by the schematic and didn't know that the schematic used a different # of pins than what i had. i'll get on that as soon as i can.
since you made the output circuit, can you tell me what happens if a speaker is ran after it instead of the jack? i ask because it would really simplify what i want to do. thanks!
wild zebra-
let me know if you try to build anything from my layouts. if you have any comments or problems with them, you can use that form on each layout's page. then i could post your comment on that page to help others out. thanks for looking at the site!
choklitlove
Audio files: 17
PostPosted: Wed Jun 21, 2006 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's gonna take me redoing the layout to get the pins right. i'm taking it off the site, then i'll post here again with any updates. thanks for everyone's help!
bugbrand
PostPosted: Thu Jun 22, 2006 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
choklitlove wrote:
bugbrand-
Speaker after the output buffer? Hmm, haven't tried it.. The way I've worked things is that I treat the output (pin6) of the 709 as the main output - then connect this to 1) the line-output buffer and 2) the transistors for speaker driving. I'd say put both parts onto the layout.
choklitlove
Audio files: 17
PostPosted: Thu Jun 22, 2006 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i was planning on doing. i think i'll try the speaker after the buffer just to see how it reacts. thanks!
Wild Zebra
PostPosted: Thu Jun 22, 2006 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Good eye Bugbrand. I used the 14 pin. Thanks to Dnny for sending the data sheet for it. So I didn't go and mess it all up. I was fiddlin with it last night. Lotta fun. My friends supposed to give me a hand-me-down digi cam tonight (hehehe I can take pics of my DIY stuff) So I'll post pics ASAP.
Dnny your gonna dig the "front panel" Lets just say Crapper-Box!
Wild Zebra
PostPosted: Fri Jun 23, 2006 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Alright my friend game me an old canon S110. Sweet now I can take some pics of projects! I was going to put it in something else then I figured the clock already had a speaker and some holes. Then a little photoshop fun with a crapper disection voila. I still need to cut the front panel so when the LED goes off it will illuminate the crapper.
and a little vid
Audio files: 235
PostPosted: Fri Jun 23, 2006 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Laughing Cool
bugbrand
PostPosted: Fri Jun 23, 2006 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wild Zebra wrote:
DAMN COOL!
dnny
PostPosted: Sun Jun 25, 2006 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
that is really nice.
there are so many boxes around us that make perfect homes for little circuits like Cracklebox.
that panel whit led :
banana banana banana banana banana
www.koelse.org
Wild Zebra
PostPosted: Mon Jun 26, 2006 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks,
I was going to make a box, but hey 90 cents at the thrift store gets you a box with a speaker and predrilled holes. And yes there is a led, but I need to cut out the panel behind the clear plastic and put a sheet of cardstock or something, cause right now its just a little hole. We have a community festival here every year and I took some toys down and me and a buddy had a little noise jam. LONG LIVE BATTERY POWERED SYNTH CIRCUITS!!
crackle on!
Wild Zebra
PostPosted: Fri Jul 21, 2006 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
All right, be kind, here I am. Rockin my crackle box. My friends The Speedknobs went into the studio and I recorded some cracklebox on a hard rockin surf jam. When I get a copy of the CD I'll have to post it.
So here I am world!!
dnny
PostPosted: Sat Jul 22, 2006 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
looking good! specially your double clocked arm:)
www.koelse.org
Audio files: 235
PostPosted: Sat Jul 22, 2006 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the pic. It's always great to see the faces of our members.
Surf rock and cracklebox. I would ike to hear that. Very Happy
Scott Stites
Audio files: 96
PostPosted: Sat Jul 22, 2006 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, can't wait to hear the Crackling Surf!
Scott
Wild Zebra
PostPosted: Mon Jul 24, 2006 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Always sportin' the double-swatch!
Thanks MOSC,
I'll post the toon as soon as I can guys, if it doesn't get cut from the album Cool
Blacklight
PostPosted: Sat Aug 05, 2006 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made many circuit bent instruments where I've simply connected the terminals from the speakers to audio out jacks that can be plugged into an amp and they seem to work fine and don't seem dangerous at all. How is the Cracklebox different ? What makes it dangerous to connect it this way ? Just curious. Is it something in the way the circuit is designed in it ?
bugbrand
PostPosted: Mon Aug 07, 2006 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know about the danger aspect but you get bad-sound-ness-mess if you connect an audio out direct to the speaker in this case... Don't quite know why, but you do.!.
shawn
PostPosted: Mon Aug 07, 2006 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm probably the only person that hates these boxes. We had a noise fest recently out of state that I performed at and there was this joker with one of those boxes asking if he could perform between our sets (he wasn't on the bill). Then he proceeded to squealy squak it and I told him no. Later on, while another act was playing I heard this guy blatantly messing around with this crackle box DURING their set. Talk about very rude and annoying. He's lucky he didn't get mauled.
