mixing to Mp3
Page 1 of 1 [10 Posts]
eagertoknow
PostPosted: Sat Sep 16, 2006 12:18 am    Post subject: mixing to Mp3
Subject description: What processing delivers a bad Mp3
Could a slow or troubled internet connection interfere with the encoding process of an Mp3 to a website for upload? I have been having troubles with my connection lately. I have a very good recording of this Mp3 in I tunes but when I upload the Mp3 to my web page the beginning sound is a bit warbly. I'll upload it here as it will most likely do the same.
Well, now I feel very inept cuz I can't tell if the attachment I uploaded was attached. Guess I'll find out now as I send this off.
eagertoknow
PostPosted: Sat Sep 16, 2006 12:22 am    Post subject: mixing to Mp3
Subject description: Follow up to the 1st
This upload is not as poor as the one to my new month old website at
www.Jazz-elle.com. Would the encoding to 80 kbps make a difference in this kind of recording? And please all comments and advice on this recording is very appreciated. Thank you. Jazz-elle
K
PostPosted: Sat Sep 16, 2006 2:21 am    Post subject: Re: mixing to Mp3
no, I don't think so. the encoding is a process that happens inside your computer before you upload the song.
G2 patch files: 626
PostPosted: Sat Sep 16, 2006 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
80K is very low, it has been a long time since I experimented with low bit rates, but I think I decided 128K was the minimum usable rate for anything but voice recordings.
eagertoknow
PostPosted: Sat Sep 16, 2006 3:28 am    Post subject: Mp3 mix
Subject description: thanks for the input
I will go with 128 kbps and see if that helps .
THanks to you both..
Much obliged...
Audio files: 232
PostPosted: Sat Sep 16, 2006 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are several encoders that you can use. I have never compared them, but a few years ago I read that the LAME encoder is the best.
Another thing to experiment with is VBR (Variable Bit Rate). This is a mode where sometimes higher fidelity is achieved at a given max bitrate. In the past, some mp3 players have had difficulty decoding VBR, but the situation is better now. You can select VBR in the encoder settings. For most stuff, I don't use it...
PostPosted: Sat Sep 16, 2006 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
IMO, mp4 files sound loads better than mp3 files and use up far less space (and therefore bandwidth?).
You need Quicktime. Some users here really dislike Apple/ Quicktime stuff, but I really don't get why Confused
ACHTUNG!
Audio files: 232
PostPosted: Sun Sep 17, 2006 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
ogg files are better too, but if you are interested in the most accessable format, it is mp3.
PostPosted: Sun Sep 17, 2006 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Garbled start? Some older versions of QT ( the browser plugins that is ) will kinda start playing the file with a stutter.
Kassen
PostPosted: Sun Sep 17, 2006 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's proprietary, closed source (and uses those two to create artificial extra layers of incompatiblity), only available for two OS's (neither of which has a acceptable policy on security fixes), it's hard to deinstall, sucks resources, is way too bloated, starts up with a "buy a more expensive version" nag schreen and if you're not carefull you'll end up installing I-tunes as well (which is likely illegal in much of Europe).
Does that cover it?
I don't know why people encode in those formats but I don't think it creates a good image of what you are trying to say and how you are trying to say it if you require people to use Windows Media, Quicktime or Realplayer, especially now that there's VLC which runs everywhere and plays many formats.
Kassen
