Joined: Apr 03, 2004 Posts: 24476 Location: The Netherlands, Enschede
Posted: Sat Oct 28, 2006 2:42 pm Post subject:
Scott Stites wrote: | @#$%!!! son of a #$%! !!!!! The entire schematic source files for the entire last rev are gone |
Oh oh
BTW .. I like the fork dance ! _________________ Jan
Scott Stites
Audio files: 96
Posted: Sun Oct 29, 2006 12:23 am Post subject:
That's a dance I'd pay to see, too. As long as it's not a lap dance (seeing as how it involves multiple forks).
I had the previous rev resubmitted to me by Fonik (thanks Matthias), and it was a matter of going through and putting everything back to the current rev. Well, everything but the super deluxe output circuit (the one that had the CV and modulation inputs). That will get re-worked later.
Here's the latest zip file. Below are the contents of the text file, which is a part of the zip.
Scott
Model 2 Klee Sequencer Zip File Release 3
The Model 2 Klee Sequencer schematics are spread throughout five schematics, included in this zip file:
Clock and Load: Klee_Clock_and_Load_200r.jpg
Encoder: Klee_Encoder_210r.jpg
Scaler: Klee_Opt1_100.jpg, Klee_Opt2_100.jpg, or Klee_Opt3_100.jpg
Decoder: Klee_Decoder_120.jpg
Output: Klee_Standard_Output_110.jpg or Klee_Enhanced_Output_100.jpg
Gate Bus: Klee_Gate_Bus_140r.jpg
There are actually 9 schematics included in this zip file. The extra schematics contain optional elements that can be included in the Model 2 Klee at the builder's discretion.
The first set of options concerns the method by which the maximum range of the Klee's programming pots is set. There are three options, each of which are contained on a separate Scaler schematic.
Scaler Option 1 allows the operator to set the maximum range of the programming pots with a single rotary switch. This switch has 8 positions, and allows the operator to set the maximum range at the intervals of a major third, a perfect 4th, a perfect 5th, a minor 6th, one octave, two octaves, four octaves or eight octaves. If this functionality is desired, then the schematic Klee_Opt1_100.jpg should be used as the scaler schematic.
Scaler Option 2 allows the operator to set the maximum range of the programming pots with a single rotary switch, with the two octave setting allowing continuous control of the max range from 0V to just over two volts (two octaves). This switch has 8 positions, and allows the operator to set the maximum range at the intervals of a major third, a perfect 4th, a perfect 5th, a minor 6th, one octave, two octave variable range, four octaves or eight octaves. If this functionality is desired, then the schematic Klee_Opt2_100.jpg should be used as the scaler schematic.
Scaler Option 3 allows the operator to set the maximum range of the programming pots with two separate rotary switches. The first rotary switch is a 12 position switch that allows the operator to step the maximum range in voltage levels corresponding to half step intervals from 0V to 11/12V (one half step below a full octave). The second rotary switch is an 8 position switch that allows the operator to step the maximum range in 1V increments, corresponding to octave intervals, from 0V to 7V (seven full octaves). The combination of settings of these two rotary switches allows the operator to set the maximum range of the programming pots to any interval between 0V and a level corresponding to one half step under 8 full octaves. If this functionality is desired, then the schematic Klee_Opt3_100.jpg should be used as the scaler schematic.
The second set of options concern the output section. With this zip file, there are two optional output schematics. The difference between the two is relatively minor:
The 'Standard' output has a single output for each Klee voltage - A, B, and A+B. These outputs follow the slew circuits for each output. If this option is desired, then Klee_Standard_Output_110.jpg should be used as the output schematic.
The 'Enhanced' output has two unique output for each Klee voltage. The extra outputs are tapped before the slew circuit, so that there is an unmodified, and a 'slewable' version for each of the outputs (A, B and A+B). If this option is desired, then Klee_Enhanced_Output_100.jpg should be used as the output schematic.
A third 'deluxe' version exists, but the original source schematic is missing, so once it is re-drawn, it will be made available in the next zip file. This version allows input V/Oct voltages and modulation to be applied to all three outputs and the each output individually.
Schematic Revisions in this zip file are:
Clock and Load: Revision 2.00r (redrawn revision 2.00)
Encoder: Revision 2.10r (redrawn revision 2.10)
Scaler: Option 1, revision 1.00
Option 2, revision 1.00
Option 3, revision 1.00
Decoder: Revision 1.20
Output: Standard Revision 1.10
Enhanced Revision 1.00
Gate Bus: Revision 1.40r (redrawn revision 1.40) |
Scott Stites
Audio files: 96
Posted: Sun Oct 29, 2006 12:44 am Post subject:
Our triclopian beauty did not originally intend to wind up as an exotic dancer - she, in former days, aspired to dance in the ballet.
Her big break came with an audition for the New York Metropolitan Ballet. In preparation, she commissioned a work on an early prototype of the Model 2 Klee sequencer - a three bit pattern, with three voices (three being her lucky number). It was performed in 8X2 mode, with the voice controlled by output B frequency modulating output A. It began with an audio rate clock, a comparitively cheerful sound to Iris (in comparison to her life, that is) which was switched lower in frequency range, initiating her routine. She was set to dance Swan Lake at the audition, with this specially commissioned work.
Alas, halfway through her routine, the casting director stopped the performance and summarily dismissed her. Her manager, who also that day notified her of termination of their contract, claimed the music was inappropriate for Swan Lake, being as it was in an entirely different key (the key of L, I believe). Iris, however, to this day believes she was eliminated because her tiara slipped out of position during her gyrations, exposing her previously concealed third eye. In any event, life went downhill soon after for our poor heroine, and she subsequently took up dancing with dinnerware, scantily clad, when clad, in reptillian and...other....garb.
Attached to this post is the original piece Iris used in her aborted audition.
Scott
Description: |
Klee 8X2 sequence, with VCO controlled by A FM'ing VCO controlled by B. VCO controlled by A+B is an innocent bystander. |
 Download (listen) |
Filename: |
Third_Eye_Tiara.mp3 |
Filesize: |
1.22 MB |
Downloaded: |
1352 Time(s) |
Posted: Sun Oct 29, 2006 2:56 am Post subject:
I stopped getting notices for this thread!
I just checked to find that almost a page has gone by without me hearing about it!
I've unwatched and rewatched, so I'll see what happens. _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Sun Oct 29, 2006 9:48 pm Post subject:
Subject description: Something completely different....... |
Can you hear me now?
After clubbing you all over the head with the bizarro Triclops Stripper arc, here's something totally different - Ambient Klee.
I flipped on the Klee to play with it a little bit tonight - I set the LFO controlling the Klee into the lowest range and got this really neat sort of '40s movie soundtrack type of sequence out of the same 'Tiara' settings it was left with last night (though a quite different pattern). I tweaked the EG's with long attack/release settings, and threw in the DSC2000, gated from one of the gate bus outputs. It morphed into this really sweet ambient sequence, so I dusted off the Dim C, ran the signal through the Korg SD-400 analog delay into that, and out popped this attached sample.
So it's three VCO's, each through its own filter and VCA, plus the DSC2000 all plugged into my switchblade mixer module, from that into the SD-400, and from there into the Dim C. Both Dim C outputs are plugged straight into the D8, which makes this the first Klee sample I've ever recorded in stereo - the Dim C is doing it's lush stereo thing to it (it's in Mode 4 for those Dimension C afficianados out there). The sample plays through by itself - the only intervention from me was, halfway through it, to adjust a lot of glide into and add some vibrato to the voice controlled by output A (narrow pulse VCO going through half of the dual MS-20 clone filter - you'll hear it, it's pretty obvious).
The Dim C is one of those things that really deserves a Krunkus layout - a certain Germaniac once told me that if you ran a snow blower through a Dim C, it would come out the other end sounding wonderful. I love it to death, especially for polyphonic stuff. I swear on a stack of bibles if you built one, you would never regret it, and find yourself using it so much, you'd start to worry..... Anyway, it certainly sweetens the voices here, but the really nice thing is that the Gate Bus adds and takes away voices, too, which gives it a certain 'arranged' feeling.
I was thinking, too, there's a lot of Jeff Pontius in it - the recorder (Korg D and the SDD-400 were both given to me by Jeff. This sample sounds like, if not something he would do, something he would certainly appreciate.
If you have the impression that the Klee is only good for chugga sequencer/random stuff, give this sample a spin....
Scott |
Joined: Jan 31, 2003 Posts: 18251 Location: Durham, NC
Audio files: 226
Posted: Mon Oct 30, 2006 9:09 am Post subject:
Scott Stites wrote: | a@#$!!!!  |
Sorry to hear about that, Scott. This happens to me all the time. I'd like to offer some words of wisdom as consolation. The Book of Ecclesiastes, especially the translation by Rami Shapiro, would be my first suggestion, but maybe if you are in a hurry John Lennon's comment, "Life is what happens to you while you're busy making other plans." - John Lennon, "Beautiful Boy" - will suffice.
 _________________ --Howard
my music and other stuff |
Posted: Mon Oct 30, 2006 3:51 pm Post subject:
It's because you're so prolific and productive Scott. The "cosmic forces which surround us all" decided that you needed slowing down a bit!  _________________ What makes a space ours, is what we put there, and what we do there. |
vtl5c3
Posted: Mon Oct 30, 2006 7:25 pm Post subject:
hi scott.... dumb question, but the stage inputs connecting to the ctrl inputs on the 4066s in the decoder section... are they connecting to the steps #s on the encoder page, i.e. the CD4034 outputs? |
Scott Stites
Audio files: 96
Posted: Tue Oct 31, 2006 7:25 am Post subject:
Quote: | "Life is what happens to you while you're busy making other plans." |
That has always been one of my favorite Lennon lines ever.
Quote: | you needed slowing down a bit! |
Weird you should say that - got home from work last night, had a bit of a lie down, and didn't get up til this morning! Weird...
Quote: | but the stage inputs connecting to the ctrl inputs on the 4066s in the decoder section... are they connecting to the steps #s on the encoder page, i.e. the CD4034 outputs? |
Yes and a@#$!!!! yet again. I'd dropped the 'stage' mnemomic when I got rid of the 4050 buffers - 'stage' should now read 'step'. Thanks for pointing that out. When I redid the decoder circuit so that any option of scaler could plug into it, I used a previous version that still had 'stage' instead of 'step'. I'll fix that and upload the fix in a different zip. Sorry to you all for loading so many versions of essentially the same thing......
Scott |
Posted: Tue Oct 31, 2006 8:04 am Post subject:
i try to have the current and latest files uploaded to my site. if stripboard layouts would come, i'd be glad to upload them, too (if i'm allowed to). some may find it more comfortable to have everything on one view, not spread over a thread - just the outcome, no history...
p.s.: i really try to built an 2U!! version that can be operated without difficulties. i'm in the stage of drawing the panel, deciding which parts to use and how to distribute the circuits, pots, switches and sockets to a set of euro copper blanks... |
Scott Stites
Audio files: 96
Posted: Tue Oct 31, 2006 12:04 pm Post subject:
It would be nice to have the strips and everything in one place/file. Ultimately I think that would be the goal.
I plan on creating a mnemonic list, cal procedure, and panel wiring diagram, plus a nice theory of operation covering the soap opera in the previous sections of this thread. That and an operational 'tip' doc would be nice.
In the meantime, this zip file has the corrected "step" mnemonic on the decoder board.
Mmmmmmmmmmmnemonically,
Scott |
germaniac
Posted: Tue Oct 31, 2006 12:24 pm Post subject:
Scott Stites wrote: | a certain Germaniac once told me that if you ran a snow blower through a Dim C, it would come out the other end sounding wonderful. |
Well, here in California we call them leaf blowers, but that's just sort of a provincial thing. . . . Either way, the Dim C 'll work it's magic.
"Ambient Klee" is tres creepy, tres noir! Looking forward to hearing the twenty-minute version. . . . |
Posted: Tue Oct 31, 2006 2:03 pm Post subject:
germaniac wrote: | Looking forward to hearing the twenty-minute version. . . . |
Hey, who where what when ? I want it  _________________ Jan
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Tue Oct 31, 2006 2:32 pm Post subject:
Scott this really is an amazing project man!
Is anyone gonna do a pcb run?
I'd be interested for sure! |
Scott Stites
Audio files: 96
Posted: Tue Oct 31, 2006 3:50 pm Post subject:
Quote: | Well, here in California we call them leaf blowers |
Waaiiit a minute - an authoritative source (Mamas and Papas "California Dreaming") insinuates even the lack of need for a leaf blower. What gives?
Quote: | Looking forward to hearing the twenty-minute version. . . . |
Hmmm - I recorded that in 16X1 pattern - I wonder what 16X1 random or 8 pattern/8 random would be like - it would certainly deliver more than 20 minutes. I'd try it tonight, but my lab assistant has his sights set on me escorting him around town so that he can extort candy out of my neighbors, with the threat of dire mischief should they not deliver.
Quote: | Is anyone gonna do a pcb run? |
Uncle K is working on a stripboard version and I believe Fonik is working up a PCB version of it as well.
His web page on the Klee is here:
http://www.modular.fonik.de/Page22.html
Scott |
mono-poly
Posted: Thu Nov 02, 2006 12:09 pm Post subject:
Thanks Scott
I'll keep checking this tread.
And i'll ask my technican when it's time to make me a Super KLee! |
Scott Stites
Audio files: 96
Posted: Sat Nov 04, 2006 7:32 pm Post subject:
Quote: | And i'll ask my technican when it's time to make me a Super KLee! |
That sounds like a plan
Not much happening on the Klee front today - I spent some time moving my recording setup to a different computer. My 'main' computer, a hopeless old relic, has only 64M of RAM, so there are constant little clicks that show up while the hard disk is repeatedly accessed. The second computer (Jeff's old computer he handed off to me a long while back) has more RAM and a Yamaha sound card, which has to better than.....Compaq. Yeah, that's right - I'm using a crusty Compaq.
Anyway, recording is much more smooth with this other computer (that is, copying/mixing from the D8 to the computer).
I also spent some time uploading sound files to my website in hopes of reconstructing some of the missing sound files from this thread and putting them all in one spot. As the thread has progressed, I've succesively been deleting sound files to make room for newer ones. Today I figured out how easy it was to find where the sound files are; before that, I was just deleting and leaving the hapless reader of the thread wondering what sound file I was talking about at any particular point. I've started planting links to my file storage where those files have been deleted in this thread. Eventually I hope to turn the page into a sort of running history of this thread where samples can be accessed more easily,
In the meantime, I used the new computer to copy this sample I made a couple of nights ago. It's the Klee lurching about with four voices:
Voice 1 is a VCO run through the 2040 filter and controlled by the A output. It's the slewed bass line heard in the sample.
Voice 2 is a VCO run through half of the dual MS-20 filter, in HP mode. It's controlled by A+B plus the keyboard - I move its sequence to three different base notes throughout the sample. It's the high pitched voice that also has the slow, dry resonant HP sweep (controlled by a triangle LFO).
Voice 3 is a VCO triangle wave through the Wave Multiplier, then through MS-20 clone LP. This voice is controlled by the A+B output. It's the vaguely electric guitar sounding voice. Halfway through, I change the timing on the EG controlling it so that it has longer sustain/release, which also has the effect of lengthening its sequence and increasing its volume, bringing it a little more forward in the mix. I then flip it back to shorter release, then towards the end, flip it back to longer release.
Voice 4 is the DSC2000, which provides the short stabs throughout the sample. Controlled by A+B.
Klee itself is in 16X1 mode, with the max pot set to 1V. IIRC, it was a three bit pattern.
All four voices are mixed together in my Mixer module, then run through the Korg Analog delay, mono, into the Dim C, which transforms the mono signal into a more spatial stereo image, and is then passed straight into the recorder (no multi-tracking, as usual).
http://mypeoplepc.com/members/scottnoanh/sitebuildercontent/sitebuilderfiles/kleedimc1.mp3
File is 1.8 MB.
Scott |
Posted: Sun Nov 05, 2006 2:26 am Post subject:
As per usual Scott, this is a beautiful piece. Ready to be mastered and added to the Super Klee Compendium.
I think you should release an album of just Klee inspired works.
"Hooked on Klee" sounds good. _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Sun Nov 05, 2006 9:17 am Post subject:
Oooh! If Krunkite Fashion Industries expands its plunder of the natural world to the as yet untapped phylum of the arthropod, we could manufacture natural spider's web leotards to go with our reptillian aerobics outfits. Then we could market them with a free copy of the workout tape "Sweatin' to the Klee". Richard Simmons might even be available!
Or better yet, "Buns of Klee" with Jane Fonda.
Scott |
Audio files: 226
Posted: Sun Nov 05, 2006 9:26 am Post subject:
electro-music media would be proud to publish such a work. _________________ --Howard
Posted: Sun Nov 05, 2006 9:27 am Post subject:
Scott Stites wrote: | "Buns of Klee" with Jane Fonda. |
"Hot from the bread board"
Another nice track BTW. _________________ Jan
StephenGiles
Posted: Sun Nov 05, 2006 3:12 pm Post subject:
That sounds very nice but I keep expecting Jeff Beck to crash in! |
Scott Stites
Audio files: 96
Posted: Sun Nov 05, 2006 8:46 pm Post subject:
Quote: | electro-music media would be proud to publish such a work. |
That would be pretty cool
Quote: | "Hot from the bread board" |
!! Never thought of that!
Quote: | That sounds very nice but I keep expecting Jeff Beck to crash in! |
Oh, yes - that. Due to no reply in response to my repeated requests for a small sample of his pituitary, my Jeff Beck voice module (Freeway-Jam-In-A-Box) has been put on indefinite hold.
BTW, it is soooo nice to hear someone from the UK voice recognition of Jeff Beck's immense talent. A few years back, I was stuck in Saudi Arabia sub-contracting for a Brit firm, and one of the gents over there would *constantly* talk music - we had a lot of time on our hands, so we really covered the gamut of music from ABBA to the Zombies. When I brought up Jeff Beck, he had nothing but derision for him, which really surprised me. According to him, Jeff had done some doofy, silly song that got airplay in the UK, and he hated it. He had absolutely no knowledge of "Blow By Blow" or "Wired", and seemed to indicate that no one else there really did, either. It was an odd blip in what otherwise was a fairly good grasp of music the guy seemed to have. I just chalked it up to one of those things where a career takes off in one country and craters in the other - I didn't think much more about it.
When I was in high school, I listened to "Blow By Blow" so much, I could literally play the album note by note in my head as I worked my mindless after-school job. A major high point of my life: seeing Jeff Beck open for Santana in Colorado Springs sometime in the early '90s. *Awesome*.
Tonight I hooked up the Thomas Henry UD-1 drum voice to the Klee. That's one module that I still haven't given proper attention to. Anyway, I used the same patch as the last few samples, just replaced the DSC2000 with the UD-1. I gotta tell you, the Klee and Drum Voice modules go together really well! The gate bus provides a lot of opportunity to providing percussion to this bizarre and not-so-bizarre Klee patterns. In fact, the nature of the patterns and the gate bus make it a wonderful tool for just generating percussion sequences.
I've got four different drum voice boards laying around here - the UD-1 on breadboard, a CGS Cynare board, and two CGS percussion voices. I'll have to wire them in and see what the gate bus does with four of them.
Here are some quick samples of the UD-1 playing with the Klee. The UD-1, which has a CV in for pitch, is being slightly controlled by the A+B CV out, and is triggered off of the gate bus (can't remember which bus for each). Just the Klee controlling the voices and UD-1, no analog delay or Dim C involved here.
Scott
Description: |
Klee and Thomas Henry UD-1 playing nice |
 Download (listen) |
Filename: |
UD_Klee1a.mp3 |
Filesize: |
1.49 MB |
Downloaded: |
1834 Time(s) |
Posted: Tue Nov 07, 2006 1:51 am Post subject:
hi scott,
technical: what's the power consumption of the klee 2 on both of the rails?
i wonder if i should build the klee with external or internal transformer/PSU... if it's below 100mA for each of the rails i would use an external wall wart and a small PSU on one of the PCBs.
matthias |
Posted: Tue Nov 07, 2006 2:16 am Post subject:
I'm betting it's about 300mA on the +ve rail and about 40mA on the -ve.  _________________ What makes a space ours, is what we put there, and what we do there. |
