Aphex retrigger effect
Page 1 of 1 [12 Posts]
onosendai
G2 patch files: 4
PostPosted: Mon Nov 20, 2006 1:43 pm    Post subject: Aphex retrigger effect Reply with quote  Mark this post and the followings unread
I would like to reproduce Aphex-ish retrigger effect, witch is the base of gitch music but i'm not able to do something natural Crying or Very sad
Have you tried ?
Aphex-trig.pch2
Bad Aphex retrigger effect
 Filename:  Aphex-trig.pch2
 Filesize:  2.59 KB
 Downloaded:  1836 Time(s)
grimley
G2 patch files: 9
PostPosted: Mon Nov 20, 2006 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could try this:
http://electro-music.com/forum/topic-12027.html
and this:
http://www.xs4all.nl/~rhordijk/G2Pages/index.htm
-grimley
intoxicat
PostPosted: Tue Nov 21, 2006 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
use a tracker, with samples - like buzz for instance Very Happy
slave to this
G2 patch files: 7
PostPosted: Tue Nov 21, 2006 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
you could do it manually if that is what you mean by natural. try triggering the gate of your 'glitch' sound with a knob-assigned clock sync'd lfo. i think your initial idea is interesting though.
monobass
G2 patch files: 12
PostPosted: Wed Nov 22, 2006 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're using the wrong tools to achieve this effect, sure it's an interesting exercise but you're just not going to get the funky results you get by doing it by hand, aseembling PIECE by PIECE Smile
That's why aphexs edits stand head and shoulders above the average breakcore dross. There's no easy way out Wink
Steve
slave to this
G2 patch files: 7
PostPosted: Thu Nov 23, 2006 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
try creating a triggering system in the g2 for NI's battery that does that "piece by piece" method of working with the way it triggers short little bleeps and blurps at high speeds. at least you could do all that then copy and paste together what you like for shortcut purposes perhaps?
but yeah, you're right steve.
astroid power-up!
PostPosted: Tue Dec 05, 2006 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's a very basic retrigger effect. turn the decay knob on the env to make the effect. it's more autechre style than aphex, but it may be what you're after.
retrigger.pch2
 Filename:  retrigger.pch2
 Filesize:  950 Bytes
 Downloaded:  1935 Time(s)
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
Jason
PostPosted: Tue Dec 05, 2006 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
perhaps you speak of granular synthesis?
These effects are utilized extensively for stuttering effects...
Just a thought
Joe Misra
PostPosted: Tue Dec 05, 2006 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't have any proof that Aphex uses an MPC, but after I got an MPC1k I begain to suspect a lot of aphex twin's retriggering effects may just be excessive use of the 'note repeat' function (which is present on all models I believe), though I imagine Bucephalus Bouncing Ball might have been something else...
eerik inpuj sound - http://www.inpuj.net/
astroid power-up!
PostPosted: Tue Dec 05, 2006 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
there are tons of methods for generating the same kinds of rolls.
software/vst: buffer override, dblue glitch, beat repeat (in ableton), and several others which do a kind of buffer resampling
in a wave editor, you'd just chop little bits together, maybe put a volume envelope on it or some pitch shifting to make it sound more/less natural.
you can tweak delays to do the same kind of thing, by putting the feedback very high on a transient and then futzing with the delay time.
the envelope retrigger effect tends to sound more computer-y, algorithmic, like autechre and richard devine.
there's something else where you can "scrub" through a waveform (if you use something like reaktor, max/msp, grm freezer, a bunch of freeware loopers or ableton's simpler plugin). you make the window large enough to see a small part of the beat and then move over a transient, it does something like that.
another free vst to check out is called "livecut".
but steve is right, to do aphex style edits, you're most likely looking at doing it by hand, in a wave editor like cubase.
edit: and hardware. older hardware can be tweaked to do some of these rolls.
W.T.
G2 patch files: 11
PostPosted: Tue Dec 05, 2006 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I read that afx uses Protools to cut up the Drux album, kick a** album by the way!
Joe Misra
PostPosted: Tue Dec 05, 2006 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
If we're just listing ways of doing this, you can also acheive it using logic audio's environment, using the midi delay and arpeggiator.
