Pics of Moog 914 Fixed Filter Bank
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
PostPosted: Sat Dec 16, 2006 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought the core was a ferrite ring?
Wax-coated paper??
ACHTUNG!
PostPosted: Sat Dec 16, 2006 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, they wrap them up in wax paper at the end.
Makes them look like baby cheeses.
Kind of fitting for this time of year hey? Laughing
Audio files: 303
PostPosted: Sat Dec 16, 2006 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
How the hell do you wind a toroidal core coil anyway? :? I'm assuming there is no gap in the core, but it seems getting hundreds of winds of enameled wire on there must be a bit of a magic trick. :shock:
http://www.gormanmachine.com/videos/900m/900m.htm has a movie on top of the page, that'll make it clear.
PostPosted: Sat Dec 16, 2006 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan,
I still don't completely understand how it does what it's doing though.
Audio files: 303
PostPosted: Sat Dec 16, 2006 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe this will help - I can't see the pictures though as it requires quicktime and I've decided to deinstall that some days ago.
It doesn't seem to use the exact same principle - using some C shaped temporary wire storage thingy instead of a spool.
CZ Rider
PostPosted: Sat Dec 16, 2006 8:34 am    Post subject: 914 Fixed Filter Bank Reply with quote  Mark this post and the followings unread
Hey, great info on these. Those new winders make mine look like
something from the 50's. Smile On the old Moog winders, the ring is
a two part precision machined stainless piece. Looks solid when
put together. This is assembled through the donut (ferrite core).
I think, (I haven't tried this yet) you would then load this stainless
ring with the wire. On the outside of the ring is a tab that the wire
slides off then down to a small stationary hub in the center that
the wire guides around. As the ring spins the wire follows around
via the tab on the ring and center hub to make the loops on the
donut. On my old ones the donut is clamped in a vice that rotates
180 deg., then you have to stop and re-clamp for the other half.
Simple, right? Then you would strip and solder on heavier leads,
secure them and dip the assembly in hot wax. Done! Did I
mention there are about 5 different tensioners along the wire path
and all kinds of speeds for the winder and segment control. The
counters on these are vaccume tubes with segments in a circle to
indicate the number of turns. But I couldn't pass these up. The
seller said they would be trashed if someone did not pick them up.
A piece of Moog/Thomas history.
So If I actually get good at winding these, I still need to measure
the permeability of the cores to figure the amount of winds to get
the correct value for the 914. So, did anyone find a source for the
permeability meter or or a permeameter? Smile
bachus
PostPosted: Sat Dec 16, 2006 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yea, thanks Jan, I've always wondered how that was done Cool
jamos
G2 patch files: 41
PostPosted: Sat Dec 16, 2006 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
All of this makes me wonder...
is it no longer possible to buy inductors (the proper name for coils) off the shelf?
bachus
PostPosted: Sat Dec 16, 2006 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Try Allied:
http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=458337003C06E17F&N=4294966067
3phase
G2 patch files: 141
PostPosted: Sat Dec 16, 2006 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
this work for machines...
3phase
G2 patch files: 141
PostPosted: Sat Dec 16, 2006 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Vishay has them..but not from the shelf..you have to buy packs of 100 at least...
I will call the german company Haufe next week.. They are the best for audio inductors anyway... but... probably notr a company that holds stocks..
However..can be interesting to talk to an old man doing in audio inductors anyway.
I hears from a friend that ferid torodial inductors get into a kind of compression state in certain conditions..that can be wanted..or an item to be avoided.
I actually think it would be nice to have the coils etup in a way that the amplifier at the input can drive them into saturation.
I will see if i can get some more infos regarding that aspect.
