ericcoleridge
Posted: Fri Jan 02, 2009 8:00 pm Post subject:
Ok, I finished one half of this VCF, and everything appears to be working very well. This filter sounds awesome, I'm very happy with it!
But, I was trying to feed it an oscillator signal from my Dual Oddy VCO, and the output signal from the 291 is very very low. I believe the 291 expects a 10v p to p signal, is this correct? Is this why my output signal is so low (I think the Oddy VCO outputs a 5v waveform)? Last edited by ericcoleridge on Sat Jan 03, 2009 2:22 pm; edited 1 time in total |
guitarfool
Posted: Fri Jan 02, 2009 8:31 pm Post subject:
Re: Great Thanks ! |
| ericcoleridge wrote: | | But why does Verbos label it 'Q'? This is very confusing. |
The 5k trimmer (or panel mount) is indeed Resonance or "Q". There's a note on the Verbos/Buchla schematic concerning the gain change with Q, so maybe that's why the 100k input trimmer on the PCB parts placement is labeled as such?
I'm thinking of increasing a couple of cap values - I'd like mine to be able to go a bit lower
Oh, and thanks Luka for the new layout! Kinda wish I'd waited a few more days to etch mine  |
funkyfarm
Posted: Sat Jan 03, 2009 10:05 am Post subject:
(maybe too soon, but I feel that 3904 have a far more "agressive" response...3566 seem to smooth all the things down...tests are running...) Last edited by funkyfarm on Sun Jan 04, 2009 1:00 am; edited 1 time in total |
Photon
Posted: Sat Jan 03, 2009 12:40 pm Post subject:
Luka
I don't believe it! I've spent the last couple of days trying to incorporate Scott's updates into the Verbos layout. But you finished first.
Your posted layout doesn't seem to be full resolution when I downloaded it. Can you re-post the full-sized?
Peter |
ericcoleridge
Posted: Sat Jan 10, 2009 7:54 pm Post subject:
But, I was trying to feed it an oscillator signal from my Dual Oddy VCO, and the output signal from the 291 is very very low. I believe the 291 expects a 10v p to p signal, is this correct? Is this why my output signal is so low (I think the Oddy VCO outputs a 5v waveform)? |
OK, I've tried testing my 291 with a MFOS VCO, and I'm getting the same response as before. My output signal is very, very quiet. All of the knobs and controls seem to be operating as they should, and the filter performs and sounds really amazing-- but it's way too quiet to be useful.
The only thing I did different from the schematic was to use a 3.3v Zener rather than a 3.9v (but I have some 3.9v zeners on order and will implement them when they arrive). Is it possible that this is my problem?
If it's not the Zener, can anyone suggest a new resistor value, or something else, that I could use to boost my signal? I would greatly appreciate any suggestions.
Here is the 291 schematic |
Scott Stites
Audio files: 96
Posted: Sat Jan 10, 2009 10:28 pm Post subject:
My 291 is loud as hell - I'm not sure if the difference between 3.3V and 3.9V would be all that great. If it doesn't make a difference, I have a feeling something somewhere is not quite right. If the new zeners make no difference, maybe we can put our heads together on this and get it going.
I don't think they were meant for 10Vp-p at all - seems to me, Buchla audio is fairly tame in level (line level?), but the CVs are pretty large. Maybe a Buchla person can correct me on that if I'm wrong. The filter handles 10Vp-p just fine - Vactrols are quite forgiving.
Cheerios,
ericcoleridge
Posted: Sat Jan 10, 2009 11:28 pm Post subject:
| I'm waiting on some more Vactrols to complete the second half of this dual filter. Maybe that will help me understand what might be going wrong on the first VCF. Thanks for your response. |
funkyfarm
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Sun Jan 11, 2009 7:04 am Post subject:
| I have not gotten back into mine to fix the BW control, but can confirm it is LOUD. Although it does not self oscillate it seems to go right to the edge and really pumps. |
Scott Stites
Audio files: 96
Posted: Sun Jan 11, 2009 11:03 am Post subject:
Yeah - in fact, the bass frequency amplitude can really catch you off guard. I remember having some conversations with Peter Grenader about that. There's sort of an amplitude hump down there.
I used PN3566.
Cheerios,
ericcoleridge
Posted: Fri Jan 23, 2009 11:16 pm Post subject:
I finally got both sides of my Buchla 291 Dual VCF up and running. Unlike some here, mine self-oscillates very strongly. I used 3904s instead of 3566s, but I transistor socketed them, so I'll probably see what difference, if any, the 3566s make.
This is definitely an unusual sounding filter. Unlike some Band Pass filters I've heard/used, this one (or mine at least) will not totally filter out the input (like a Low Pass, High Pass, or some Band Pass typically would). In this sense, it's more like Phase Shifter type of filtering. Not that it sounds like a Phase Shifter, just that it has that kind effect.
But, it's also extremely unstable sounding, especially with the resonance more than 2/3s up. In this way, it reminds me of the kind of raw, rough response of the dual MS20 filter... the way it blisters and breaks up at certain settings.
As others have reported here, my 291 is extremely loud--even with the input trim all the way down (which is where I'll leave it set). I'm really glad I built this filter, it's definitely adding new tonal variety to my synth, especially in the searing, cutting, biting area of sound. |
numbertalk
Posted: Wed Feb 25, 2009 8:10 am Post subject:
Hi Luka,
Do you still have a PDF for this for etching that you could post? Much appreciated.
| Luka wrote: | i have a new adaptation of the verbos layout with mods if anyone is interested. input mixer (with a error fixed from scott's mod schematic), cv processor, hp/lp tap/buffers - single filter per board.
here is a jpg
ill upload the pdf soon |
numbernone
Posted: Wed Feb 25, 2009 8:13 am Post subject:
Hmmm I would like to also see this modded layout.
Also, what is the error on the input mixer? Mine are flummoxed and I have just bypassed them. Im sure it simple but sadly this filter is so fun that I have not taken the time out to pull it and troubleshoot it. |
Luka
Posted: Thu Feb 26, 2009 2:06 am Post subject:
hey yeah i have a layout
it has added audio mixer, +/_ cv processor and the hp&lp output buffers
ill post it up soon
im just going to get it built first before i release it to the community
ive given it to a couple of people but kinda feel a bit bad about it as it hasnt been tested, it should be fine but i would like to give it a thorough test before i allow it to get into your hands just incase. _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
numbertalk
Posted: Mon Mar 02, 2009 3:06 pm Post subject:
| Luka wrote: | hey yeah i have a layout
ill post it up soon
ive given it to a couple of people but kinda feel a bit bad about it as it hasnt been tested, it should be fine but i would like to give it a thorough test before i allow it to get into your hands just incase. |
Makes sense. Looking forward to this! |
funkyfarm
Junk Rhythm
Joined: Jan 07, 2008 Posts: 81 Location: San Francisco, CA
Posted: Wed Apr 08, 2009 10:32 pm Post subject:
here is a jpg
Is the PDF version available? I want to breadboard it up and check it out. |
Luka
numbernone
Posted: Thu Apr 09, 2009 1:31 pm Post subject:
After fidgeting with my second build of the 291 a bit, I think I have it a bit more in line. I primarily use the HP tap, on which the BW control introduces a massive wave of what I normally think of as resonance (self osc levels). Can anyone else confirm this? I mean, it is like bottom of the ocean speaker destroying WHOOOMP! Modulating the cut and BW with various sources makes for just truly mind melting tones.
I Love this filter more everyday. |
Luka
jwilsey
Joined: Feb 24, 2009 Posts: 31 Location: Taichung City
Posted: Fri Apr 10, 2009 4:34 am Post subject:
| Thanks Luka for posting up the PDF. I am going to try your layout in the next 2 weeks. |
Luka
Posted: Tue Apr 14, 2009 7:51 am Post subject:
well the filter sounds awesome!
just powered it up tonight and it worked straight away
my xoxbox sounds sweet through it
ill populate the mod section this weekend and make sure it all works _________________ problemchild
melbourne australia
Photon
Posted: Sun Aug 02, 2009 7:54 am Post subject:
Luka
Photon
Posted: Mon Aug 03, 2009 10:32 am Post subject:
Thanks Luke. I hope to have some time this week to wire it. I'm really looking forward to playing with this.
You'll have to post some pics of yours when its finished. |
