G2 stand?
Page 1 of 1 [11 Posts]
ark
G2 patch files: 31
PostPosted: Fri Mar 07, 2008 9:21 am    Post subject: G2 stand?
Subject description: How can I support a small keyboard at a convenient height?
Keyboard stands seem to be made for bigger keyboards than the G2. What do the G2 owners out there do about supporting the G2 at a convenient height?
cebec
G2 patch files: 31
PostPosted: Fri Mar 07, 2008 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I use this:
http://www.bhphotovideo.com/c/product/152998-REG/Quik_Lok_QL402_QL_402_Roll_Around_Stand.html
It's the QL-402 (not the QL-400, which doesn't go wide enough). I put a little foam or fabric over certain areas to prevent scratching the bottom of the G2 (highly recommended), but this thing allows me to roll the G2 around, tilt it at several angles, raise or lower it, and holds it firmly in place while doing so. It's more expensive than your typical keyboard stand but I think it's almost perfect for this application.
 Filesize:  35.63 KB
 Viewed:  11643 Time(s)
PostPosted: Fri Mar 07, 2008 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I use this ultimate stand. Folds up very nicely, and I can throw a wodden board on the stand for my laptop/etc.
Ultimate Keyboard Stand
 Filesize:  103.41 KB
 Viewed:  377 Time(s)
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Mar 07, 2008 10:50 am    Post subject: Re: G2 stand?
check this out
down the thread you'll see my set up (G2 included)
I use this keyboard stand
ark
G2 patch files: 31
PostPosted: Fri Mar 07, 2008 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, quite a setup. My current rig is much more modest -- see attached photo.
Also note the cat eyes peering out from under the monitor.
 Filesize:  2.74 MB
 Viewed:  365 Time(s)
ark
G2 patch files: 31
PostPosted: Fri Mar 07, 2008 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I actually looked at the Ultimate stand, but I thought that perhaps it would be too big and heavy. Is it possible to remove one of the keyboard supports?
If I want one, I should probably order it promptly, as it has been discontinued but some people still have them in stock.
seb
PostPosted: Sat Mar 08, 2008 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Because I'm using the G2 beside a drumset, I need a small and low stand, so I found this one (for children, but high-quality!):
http://www.k-m.de/Keyboardstaender-fuer-Kinder.3+M5f255b6faec.0.html
Seb
ark
G2 patch files: 31
PostPosted: Sat Mar 08, 2008 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks perfect!
For that matter, I have used the rainbow version of this stand for years:
http://www.k-m.de/MUSIC-STAND.3+M5bd2fa72daa.0.html
Now I just need to find out where I can buy one of them in the USA...
cappy2112
PostPosted: Fri Mar 14, 2008 10:18 pm    Post subject: Re: G2 stand?
What is the blue box sitting on the G2?
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Mar 15, 2008 12:38 am    Post subject: Re: G2 stand?
an AdrenaLinn II
kvnvk
PostPosted: Sat Mar 15, 2008 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been using the same Ultimate stand for several years, works great with the G2.
