NAMM 2011 snippets
Page 3 of 3 [57 Posts]
Goto page: Previous 1, 2, 3
cappy2112
PostPosted: Tue Jan 18, 2011 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
GovernorSilver wrote:
buzzr wrote:
I can't afford it right now Sad
And the G3 will be affordable?
Vaporware is always affordable.
GovernorSilver
PostPosted: Tue Jan 18, 2011 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
This analog delay pedal is starting to interest me more than the latest iteration of the EHX Deluxe Memory Man:
http://acapella.harmony-central.com/showthread.php?2728614-It-s-official-the-Malekko-Ekko-919-Analog-Delay
Features:
• 40 millisecond to 1.00 second BBD Delay using NOS BBDs.
• Largest dynamic range possible from a BBD Delay using -15V BBD ICs.
• Tap Tempo footswitch control of echo delay time with tempo rate LED.
• Knob control of echo delay time.
• Soft takeover between tap tempo and knob control. Tap the footswitch, its delay time is in control. Move the knob, the knob delay time is in control. Move freely between the two controls.
• True Bypass, Active Bypass and Active “Trail” Bypass, letting you hear the echo trail after switching to bypass mode.
• Mix from 100% Dry, 50/50 Mix to 100% Wet.
• Tone Equalization control.
• Specially tuned flat feedback response to below 100 Hz.
• Excess Feedback includes a limiter in the feedback loop for infinite sustain echo without annoying feedback howl.
• The combination of feedback limiter, tilt tone filter and modulation options make this a wild synthesized tone generator. No input is necessary except a dummy jack to activate the power circuit.
• LFO Speed and Modulation Depth controls and modulation enable switch.
• Wide range of LFO modulation shapes: sine, square, sample & hold and diffusion
Diffusion is an exclusive mode never before heard from any BBD delay, spreading the sound into a “cloud-like” atmosphere.
• Powered by +9.6 V 500 mA or greater power supply.
Looks like a great candidate for an analog delay that can be used for experimental sounds.
Some old stuff on VIRB
GovernorSilver
PostPosted: Tue Jan 18, 2011 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eventide's new reverb pedal, loaded with Eventide's unique reverb sounds:
http://createdigitalmusic.com/2011/01/eventide-for-the-rest-of-us-a-legendary-effects-processor-now-in-compact-reverb-form/#more-15886
GovernorSilver
PostPosted: Wed Jan 19, 2011 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matsuda's innovative take on harp guitar design:
http://www.flickr.com/photos/matsudaguitars/3057758403/in/set-72157612844105721/
A bit of description here:
http://harpguitars.net/blog/2011/01/namm-day-3/
cloudscapes
PostPosted: Wed Jan 19, 2011 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
the new Malekko and Eventide definately have my interest!
I've also preordered the teenage engineering OP-1
I've been looking forward to it for years! Shocked
Sonic Crayon DIY effects lab
Electrica
PostPosted: Thu Jan 20, 2011 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Some good picks in this thread... I also like Akai synthstation 49....
http://en.audiofanzine.com/midi-keyboard-controller/akai/synthstation49/news/
brontosaurus19
PostPosted: Thu Feb 17, 2011 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Man, that Ekko 919 delay looks pretty awesome!
