jojjelito
Joined: Jun 27, 2007 Posts: 50 Location: Stockholm, Sweden
Posted: Thu May 12, 2011 1:29 pm Post subject:
I'd be in for a couple of PCBs at any rate. My modular gizmo would benefit from this useful addition  |
Dave Kendall
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Thu May 12, 2011 6:36 pm Post subject:
absolutely orsm and exactly what i hoped it would be like
I think the sync daughter board i have been working on should be able to sync fonik's PWM master clock to this which would be outstanding
I will need to make some output multiples i think  |
Joined: Dec 11, 2010 Posts: 1025 Location: Toronto, Ontario - Canada
Posted: Thu May 12, 2011 7:59 pm Post subject:
That demo was great. Thanks for posting it.
What's the eta for the printed boards? No rush since I'm still working on other projects, but I'd like to know when you think they will be ready. |
tommi
brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Fri May 13, 2011 3:12 am Post subject:
WANT!
 _________________ Best regards
Greg |
Dave Kendall
Posted: Fri May 13, 2011 4:01 am Post subject:
Hi guys.
Mathias is the boss where PC boards are concerned. I think we need to get around 30 or more pre-orders to make it viable, and get the price down to something reasonable. I reckon we have around 10 or so folks who want one so far.....
Dave _________________ "Everything in moderation, including moderation" |
brother303
Posted: Thu May 19, 2011 8:46 am Post subject:
| Dave Kendall wrote: | | Mathias is the boss where PC boards are concerned. |
FOOOONIK,can you hear us?
| Dave Kendall wrote: | | I think we need to get around 30 or more pre-orders to make it viable, and get the price down to something reasonable. |
Perhaps ask over at Muffwigglers? Maybe some more folks are interested there...
Edit: Started a thread on this over at Muffs. _________________ Best regards
Greg |
rosch
Posted: Thu May 19, 2011 9:28 am Post subject:
ok, i better say 2 instead of the previously 1 board.
would be cool to see this happening. |
JoeMorris
| I would def take one. |
bigbluewave
Posted: Thu May 19, 2011 12:41 pm Post subject:
Yes, yes, yes!
I'm up for one of those board for sure!!!
Aaaagh, so many great designs to build already and now another belter...
Top stuff guys, a great collaboration indeed it seems.
Ben
www.bigbluewave.co.uk |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Thu May 19, 2011 2:57 pm Post subject:
Oh, yeah! As I read through I thought a simple build would be all I need for syncing sequencers to MIDI...now I know a full build is essential.
Definitely in for this one (or two)!  _________________ Looking for a certain ratio since 1978 |
diablojoy
Posted: Thu May 19, 2011 6:10 pm Post subject:
definitely up for one however
dave just to bring up the question
would 2 or more of these be usefull really in the context of a single modular even a really large modular ?
I was thinking to have a form of buffered multi's on the output to increase the number of outputs to what i would need,
is there an additional benefit to multiple modules that i haven't figured out yet ?
I will need a reasonably good arguement in favour, so i can justify the expense to my wife  |
Posted: Thu May 19, 2011 7:12 pm Post subject:
| 2 would be good to divide the rate differently for different devices. You can put me down for 2 now that I think of it. I might only build one right away, but I'm sure I will need the second in the future as I create more lunetta type devices and sequencers. |
Posted: Thu May 19, 2011 11:21 pm Post subject:
now there is some momentum here?
i think we will have to start a list... _________________
Tech Buddy at Random*Source |
diablojoy
Posted: Fri May 20, 2011 12:39 am Post subject:
| Quote: | | 2 would be good to divide the rate differently for different devices |
hmm yes i think i can see how that may be preferable to just using other dividers afterward though i can see i will do that also anyway
dave would a midi thru be reasonably easy to implement for chaining a few of these together ? no biggy i do have quite a few spare midi outs on my interface rack still.
mathias i may go to 4 of these possibly now. will need to recheck the budget first though  |
Posted: Fri May 20, 2011 12:44 am Post subject:
| diablojoy wrote: | | dave would a midi thru be reasonably easy to implement for chaining a few of these together ? no biggy i do have quite a few spare midi outs on my interface rack still. |
a decent MIDI thru circuitry needs another IC, and the board is rather large already.
Dave already said something about another reason for MIDI thru off: MIDI clocks are woven in the MIDI data stream. So you don't want to use MIDI clock data and other MIDI data on the same output.
For distributing a MIDI clock to multiple instruments a simple multiple would do, i bet. _________________
diablojoy
Posted: Fri May 20, 2011 1:33 am Post subject:
| Quote: | | MIDI clocks are woven in the MIDI data stream. So you don't want to use MIDI clock data and other MIDI data on the same output |
yes i just reread that post
i was thinking more along the lines of having one dedicated midi out from my interface rack just for midi clocks rather than say having to use up 4 outputs if i were to build 4 of these modules
| Quote: | | a decent MIDI thru circuitry needs another IC, and the board is rather large already |
was thinking i could do a small add on board . as long as the midi clock data can be accessed . I think dave suggests later on all midi data is available on headers so it shouldn't be a problem just wanted a conformation that it includes the clock data
| Quote: | | For distributing a MIDI clock to multiple instruments a simple multiple would do, i bet |
that would be great but not sure if it would be all that simple.
midi can be horribly finicky especially on longer cable runs |
bigbluewave
Posted: Fri May 20, 2011 2:13 am Post subject:
Erhm,
MIDI is based on a current loop, so you would need to buffer this rather than just split it. The spec of MIDI is also very particular about grounding and to avoid earth loops and hum, hence being an opto isolated current loop.
I'm sure it wouldn't be too tricky to come up with a little distribution circuit if you wanted to send the same clock to several boards, maybe it could be after the MIDI decode, like a master/slave scenario?
Ben |
Posted: Fri May 20, 2011 4:31 am Post subject:
| bigbluewave wrote: | Erhm,
MIDI is based on a current loop, so you would need to buffer this rather than just split it. The spec of MIDI is also very particular about grounding and to avoid earth loops and hum, hence being an opto isolated current loop. |
you are correct, ben. nevertheless a simple split works. you do not want to distribute it this way to several instruments over long distances though, right? _________________
Dave Kendall
Posted: Fri May 20, 2011 4:59 am Post subject:
Hi guys.
If you wanted to distribute MIDI CLOCKS to more than one M2C, a 1-in 4-out MIDI thru box would be the easiest way. That way, The MIDI input only gets buffered and re-sent once.
Diablojoy - the best reason for having more than one M2C, would be that you have one in the rack to clock things with, and another on the test bench for developing new widgets with. Once you have got another set of dividers for instance, you can add them to the rack M2C as an expander module and keep experimenting..... Unplugging it each time an idea comes along would be a pain
As far as outputs go, there is a header on the PCB that carries;
24PPQN CLK
START
STOP
CONTINUE
ACTIVE SENSING - and a couple of others. It can be used without affecting the basic operation of the board. The signals are all fast positive-going +5V signals, and are unbuffered. A CMOS out put has a large fan-out, so could drive quite a few more IC's directly, but as you suggested, it might be a good idea to buffer the signals. A 74HC244 or 74HC245, or their regular CMOS equivalents would probably be good for this.
The good folks on the [sdiy] list pointed me towards some info on DIN-SYNC. It seems a small amount of extra logic would be needed - a 4013 flip-flop or 4027 could perhaps be used to generate the RUN/STOP gates that DIN-SYNC needs.
If Matthias is up for it, should we go ahead with a PCB run?
BTW - Matthias - I'll order one too for the test bench to make new devices with - lots of ideas already
brother303
Posted: Fri May 20, 2011 8:24 am Post subject:
| fonik wrote: | | i think we will have to start a list... |
| Dave Kendall wrote: | | If Matthias is up for it, should we go ahead with a PCB run? |
Yeah,make it happen!
Greg |
emdot_ambient
Posted: Fri May 20, 2011 1:20 pm Post subject:
I would suggest another output, along with start/stop/etc, if it's possible to add:
System Message: Song Position Pointer = 0
0xF2 xD1 xD2
If D1 = 0x00 and D2 = 0x00, then the song pointer is set to the beginning. This is VERY useful in synchronizing multiple sequencers DURING PLAYBACK. Most Seq. ignore the START command once playback has begun. (START is also interpreted to reset the song pointer). This can then be used to reset sequencers, LFOs, OSCs, etc in the analog realm.
Maybe you can recognize Song Pos Pointer, and toggle Start again? |
wmonk
Joined: Sep 15, 2008 Posts: 529 Location: Enschede, the Netherlands
Audio files: 15
Posted: Fri May 20, 2011 1:38 pm Post subject:
Certainly one pcb for me. Excellent project guys!
I've been waiting for this.
I could provide part kits for those who want that, if you, Dave and Matthias, agree on that.
Woody _________________ Weblog! |
