zthee
Posted: Sun May 06, 2012 6:04 am Post subject:
So I did the changes suggested by Sound. The things I had to change in the changes was the noise level. Cause even with the noise level trimmer turned down it was still 4x higher than the replacement signal. So I reverted back to the 18K / 100K setting, which brought it down to a better level..
I'm not sure how to adjust the voiced / unvoiced detector. There's only like 3 different settings to it - Either there is no action at all, there is just some action (I.e. Say "T" and there will be a burst of noise, but it sounds imho a bit strange..) or a 3rd where it's a mix of everything. I'm not sure which I like the best. But if I set it to the 3rd option and then adjust the tone control to fine tune it better..
Here's a short MP3 clip http://thehumancomparator.net/music/living%20vocoder%203.mp3 _________________ http://www.thehumancomparator.net/ |
zthee
keithwin
Posted: Mon May 07, 2012 4:00 am Post subject:
Good work zthee and sound, just soldering my 1% caps in today, still got the trims and other box caps to order. Have used 25V electrolytics instead of 35V, this shouldn't make a difference, it's what I had in but the paranoia is creeping in  |
zthee
jwilsey
Joined: Feb 24, 2009 Posts: 31 Location: Taichung City
Posted: Mon May 28, 2012 12:41 am Post subject:
| Sounds amazing! Thanks for posting. |
SolderSmoke
Posted: Fri Jun 08, 2012 1:44 am Post subject:
Anyone did a suggestion for a frontpanel yet?
The patchpanels (Ghielmetti) seems hard to get. Anyone figured out a different solution, like analog matrix? |
Luka
Posted: Fri Sep 07, 2012 2:49 pm Post subject:
i just acquired a pcb for this project
i just wanted to tip my hat to sound and zthee for paving the way through the troubleshooting. thanks for helping out
does anyone have a panel completed / case yet?
is there anyone in australia who wants to join in on capacitor buying
there is a price break at 250 which halves the cost of the caps _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
vtl5c3
Posted: Wed Oct 24, 2012 5:41 pm Post subject:
| Has anyone in the US ordered the 1% caps? I'm trying to order them from RS electronics' german site, but it looks like they only ship to germany. I went to the UK site and found the same caps for almost double the price, so that's out. And their US affiliate is Allied, who doesn't have those caps. Any recommendations? |
Luka
Luka
vtl5c3
Luka
Posted: Sun Mar 03, 2013 12:50 am Post subject:
thanks
bad producer gave me that link earlier today as well
it is all starting to make more sense - time to start a panel design
has anyone thought about having led bar displays for the envelope detectors similar to the buchla 296e?
if so, would you need a bar graph driver for each channel or could you do it an easier way? _________________ problemchild
melbourne australia
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Posted: Sun Mar 10, 2013 5:57 pm Post subject:
I can't think of any other way of doing it - than bar graph drivers...
are you really thinking of doing that?
If you did that would it probably be best to have that whole section powered from a different 'dirty' PSU... _________________ http://loudestwarning.tumblr.com/ |
The Bad Producer
Posted: Sun Mar 10, 2013 6:01 pm Post subject:
I should add that my vocoder has been half finished for nearly a year whilst I've been moving in and out of different houses. I have a nice new workshop now, so have pulled it onto the desk again for finishing, can't remember where I got to though! _________________ http://loudestwarning.tumblr.com/ |
The Bad Producer
Posted: Sun Mar 10, 2013 7:22 pm Post subject:
So, I'm trying to get my head around the panel design for this as I near the end of soldering and beginning of testing. I thought I'd make a design for each part of the schematic to help me envisage how best to arrange everything, what to include etc..
Has anyone finished and got a panel done?
Be good to hear any thoughts on sections as I put them up over the next days...
I begin with the Speech Input Amplifier:
(posted this on muffs too) _________________ http://loudestwarning.tumblr.com/ |
StephenGiles
Posted: Tue Mar 12, 2013 8:59 am Post subject:
| The Bad Producer wrote: | | I should add that my vocoder has been half finished for nearly a year whilst I've been moving in and out of different houses. I have a nice new workshop now, so have pulled it onto the desk again for finishing, can't remember where I got to though! |
The trick is notes, notes and more notes - I have often told myself when I've been in the same boat! |
The Bad Producer
Posted: Tue Mar 12, 2013 9:15 am Post subject:
Yes, you're right - I've found all my notes too, but still feel a bit disorganised!
Did you finish yours? _________________ http://loudestwarning.tumblr.com/ |
Luka
Posted: Wed Mar 13, 2013 1:47 am Post subject:
| The Bad Producer wrote: | So, I'm trying to get my head around the panel design for this as I near the end of soldering and beginning of testing. I thought I'd make a design for each part of the schematic to help me envisage how best to arrange everything, what to include etc..
(posted this on muffs too) |
looks good
might be interesting to have a feedback input / aux input as well
i have that on my fs1 _________________ problemchild
melbourne australia
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Wed Mar 13, 2013 6:56 am Post subject:
| The Bad Producer wrote: | I can't think of any other way of doing it - than bar graph drivers...
If you did that would it probably be the best thing in the world! |
Fixed that for you.  _________________ Looking for a certain ratio since 1978 |
The Bad Producer
Posted: Wed Mar 13, 2013 7:09 am Post subject:
True!
I've done a bit more today on this, and I'll amend that panel Luka - do you mean like a switch and pot to allow the output to be mixed back into the input? _________________ http://loudestwarning.tumblr.com/ |
Luka
Posted: Fri Mar 15, 2013 3:56 pm Post subject:
trying to draw a signal flow diagram
got most of it done except -
where does the voiced and unvoiced outs goto?
edit - wait im blind - of course they go to the mode sections in the compander module _________________ problemchild
melbourne australia
Luka
The Bad Producer
Posted: Sun Mar 17, 2013 5:12 pm Post subject:
Looks good to me, but I can't double check it at the mo from this computer, I have done something the same, but it's too shoddy to post! I'll look it up when back at home next week... _________________ http://loudestwarning.tumblr.com/ |
Luka
Posted: Mon Mar 18, 2013 12:28 am Post subject:
removed the image above
the more i work on this the more errors i found
one point of confusion at the moment is the pause bus
regarding the the filterbank pots / slider
is that marked as PB on the schematics?
and
does CW of the pot / slider join to both the PS bus AND channel analyzer output? _________________ problemchild
melbourne australia
Luka
