kaputtpanzer
Audio files: 15
Posted: Mon Oct 03, 2011 5:58 am Post subject:
CD4031 tap looper... |
Hey,
I was wondering how to build one of these fancy tap loopers. I found this schematic (http://oi51.tinypic.com/34ye33c.jpg), but I am not sure how to combine it with the 40106 oscillators. Is there a complete schematic for something like this: http://www.youtube.com/watch?v=aD587BP67Ro
Thank you very much |
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Mon Oct 03, 2011 6:36 pm Post subject:
great find that SHIT IS AWESOME. _________________ home made noise and electronic ill-logic |
Kabzoer
Posted: Tue Oct 04, 2011 11:38 am Post subject:
I built one of these once, there is a schematic of it flying around somewhere on the internet, I'm busy looking for it! |
Kabzoer
tjookum
Joined: May 25, 2010 Posts: 360 Location: Netherlands
Audio files: 26
Posted: Wed Oct 05, 2011 3:11 am Post subject:
really need to build this! There was a very lengthy discussion about these on the sound of logic forums.
There are also the 4557(1 to 64 bit variable length) and 4562(128 bit). Both are hard to find but should add even more variety to this awesome design. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
jean bender
Posted: Wed Oct 05, 2011 4:31 am Post subject:
i'm still looking at new informations for building even more and different booleanish sequencers... I've seen that Eric Archer build a beautiful and very intersting thing with shift rgisters ( it's BirdBox) but it seems that it's webpage is not up any more.
Could someone here give me links to informations about shift registers ? Datasheet are helpful, but i think i need more information about them !
thanks... _________________ http://h.a.k.free.fr/
www.electroncanon.org |
Kabzoer
Posted: Wed Oct 05, 2011 5:31 am Post subject:
For some general information about shift registers: http://electro-music.com/forum/topic-46838.html
And I'm totally interested in that BirdBox, as well as all the other desingn in his “Big Box o’ Techno” (http://ericarcher.net/devices/big-box-o-techno/)
He uses a great combination of both analog and CMOS devices... |
jean bender
Posted: Wed Oct 05, 2011 9:28 am Post subject:
i totally agrre with you !!
Thanks for sharring the link to the other forum, but i would need some schematics, i don't really see how to wire this kind of ic to other lunetta's stuff ! _________________ http://h.a.k.free.fr/
concretedog
Posted: Wed Oct 05, 2011 10:21 am Post subject:
deadbeat wrote: | i totally agrre with you !!
Thanks for sharring the link to the other forum, but i would need some schematics, i don't really see how to wire this kind of ic to other lunetta's stuff ! |
So the one on my blog that is linked above has a schematic you connect the output of this to something that takes a gate or trigger input so simple solutions could be to connect it to a 4093 gated oscilator or I quite often patch mine to some simple envelope generators I have.
@Tjookum...I know you should build this as I reckon i sent you some of the chips in the great Tjookum-concretedog trade a while ago!
edit... Forgot to add...the 4031 version of this that Toptop came up with can do 4/4 timesignatures whereas the MC14557 based one on my blog can do lots of different timesgnatures as you can change the lengh of the shift register.
I waffle on about my tap looper in this video http://vimeo.com/21893709 |
kaputtpanzer
Audio files: 15
Posted: Thu Oct 06, 2011 3:42 am Post subject:
Its hard to find the MC14557 here. Is there no schematic with the 4031. Or can I just replace it with the mc14557...
Thankkk youuuu |
sneakthief
kaputtpanzer
Audio files: 15
Posted: Thu Oct 06, 2011 12:53 pm Post subject:
pssst! I just ordered a bunch of cd4031 an I want to use them... |
Kabzoer
Posted: Thu Oct 06, 2011 1:05 pm Post subject:
You can just replace it with an 4031, I did that too, for the same reason
The only differnce between them is the pinout and the fact that the other one has a variable length. |
concretedog
Posted: Thu Oct 06, 2011 3:42 pm Post subject:
Yep...thats who I bought mine off.  |
kaputtpanzer
Audio files: 15
PickNick
piedwagtail
Posted: Wed Oct 19, 2011 7:57 pm Post subject:
Don Lancaster :
Quote: | This is a fully static shift register with the ability to recirculate data. It is arranged as 64 serial-in/serial-out stages.
In normal operation, data to be stored is routed to the Data In terminal and the Mode input is grounded. Data enters the register on the ground-to- positive transition (positive edge) of the clock.
In 64 successive clock pulses, entered data will appear as an output on pin 6 and as its complement on pin 7. The normal output (pin 6) may be routed as an input to a following register, cascading stages in multiples of 64. Pin 6 and pin 7 can each drive one TTL load.
If the Mode input is made positive, data at the REC IN terminal gets entered on the next positive clock. For recirculation, the REC IN terminal can be connected to pin 6 of this register or any cascaded register. Alternately, the Mode control can be used to select the data stream on pin 1 (Mode positive) or on pin 15 (Mode grounded).
The clock must be noise free and have only one ground-to-positive
transition per desired clocking. Unlike most CMOS circuits, the clock has a very high capacitance of 60 picofarads that must be driven with a rise time of one microsecond or less. Whatever is driving the clock must have a minimum source and sink current of 1 milliampere to drive this capacitance. As packages are cascaded with a common clock, the clock capacitance multiplies accordingly and the input drive current needed goes up proportionately.
A slightly delayed replica of the clock appears at pin 9 which can be
used to drive one additional register. "Daisy chain" clocking like this
introduces some recirculation problems—see manufacturer's data sheet for recommendations.
Maximum clock frequency is 4 megahertz at 10 volts and 2 megahertz at 5 volts. Total package current unloaded at a 1-megahertz clock rate is 1.2
milliamperes at 5 volts and 2.4 milliamperes at 10 volts.
Hyper clean hyper rise
SERIES another two of those 40106 inverters after the clock generator to drive the fkr. |
kaputtpanzer
Audio files: 15
Posted: Tue Oct 25, 2011 6:16 am Post subject:
I will give it a try. Thank you so much |
Top Top
Posted: Tue Sep 11, 2012 8:14 pm Post subject:
Sorry, realize it is a long time later, but I just found this thread when doing a search for my own schem.
I am the fellow who came up with that design initially.
For anyone who looks up this design, or is otherwise interested, I finally put up a post on my blog about this design:
http://www.tinydazzler.blogspot.com/2012/09/tap-loop-tap-loop-4031-tap-looper.html
kaputtpanzer wrote: | Soooo this is exactly what I have done:
Why is this not working? Ahh it's driving me insane  |
Looking at your schem, nothing looks wrong about it to me. Did you ever work it out? What were you gating with it? You know it doesn't produce sound on it's own right? You need to gate/trigger something with it.
Also, .1uF is a pretty small cap for a clock oscillator. Isn't that up in the audio rates? _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
PickNick
Posted: Sat Sep 22, 2012 5:20 am Post subject:
hi!
i built the 4031 tap looper based on Top Top's schemo, but mine play back just once.
i used cd4031BE and the clock source is 40106.
any idea?
hmmm...
i don't know what was the problem but now it's working:) _________________ Allow theex.nl |
Top Top
Posted: Sat Sep 22, 2012 3:54 pm Post subject:
PickNick wrote: | hi!
any idea?
hmmm...
i don't know what was the problem but now it's working:) |
If it is only repeating once, that means the output is not being looped into the input properly.
One thing to make sure is that your "clear" switch is a normally connected type of switch (if it is normally open, it won't allow the output to return back to the input). _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
PickNick
Posted: Fri Sep 28, 2012 7:48 am Post subject:
thanks Top Top!
now it's working.
there was some cold solder joint.
Glitch-Militia
Posted: Sat Sep 28, 2013 4:55 pm Post subject:
Would it be possible to have a LED output on the stages? Also triggering a drummachine instead of gating an oscillator? |
Top Top
Posted: Mon Oct 14, 2013 6:05 pm Post subject:
Glitch-Militia wrote: | Would it be possible to have a LED output on the stages? Also triggering a drummachine instead of gating an oscillator? |
1) Yes, just connect gate output -> 1K resitor -> LED -> GND.
2) Yes, actually sitting on my bench for like two+ years now is an unfinished gate looper drum machine. The module could trigger anything that takes gate or trigger inputs. Create a drum module that is trigger-able and this gate looper could trigger it. _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
Glitch-Militia
Posted: Tue Oct 15, 2013 9:38 am Post subject:
Thanks TOP TOP. |
