Low level dsp 3rd Exp (SymphFromHell)
Page 1 of 1 [11 Posts]
ik
G2 patch files: 25
PostPosted: Sun Feb 13, 2005 6:14 am    Post subject: Low level dsp 3rd Exp (SymphFromHell) Reply with quote  Mark this post and the followings unread
Saw oscillators made by an accumulator (-64 -> +64) which resets itself at value 64 .....
.... then their pitch doubled .... take a look easy to follow...
"Symphony from Hell" sound from the G2 (for all guilty souls ... Laughing )
SymphFromHell.pch2
Evil symphony sound with "home made" saw oscillators.
 Filename:  SymphFromHell.pch2
 Filesize:  2.67 KB
 Downloaded:  1479 Time(s)
ik
G2 patch files: 25
PostPosted: Sun Feb 13, 2005 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
... and here is the SynC Modular rep. of the saw osc and frq. doubler ...
 Filesize:  41.24 KB
 Viewed:  15705 Time(s)
Audio files: 233
PostPosted: Mon Feb 14, 2005 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
These patches with the low lever dsp stuff are facinating, but understanding them when you see them is not very intuitive. drunken cheese blackeye
ik
G2 patch files: 25
PostPosted: Mon Feb 14, 2005 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
... not very intuitive.
Idea
This is the sawosc.
Here is how it works: the 'add' module and the 'reset' modules are looped. The output of the 'reset' module continuously monitored by the 'compare' module, and while B less the 64, then 1 added to the output.
When B reaches 64 it resets the output to -64 and the cycle starts again.
something like ...
B:=-64;
if B<=64 then
B:=B+1 else B:=-64;
goto @
ik.
sawosc.pch2
saw osc
 Filename:  sawosc.pch2
 Filesize:  1.09 KB
 Downloaded:  1334 Time(s)
Wan
G2 patch files: 46
PostPosted: Thu Feb 17, 2005 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed facinating...
I wondered if it could run at audio rates (red/orange cables), so i tried to make it. And it is possible, see the attached performance, slot a is audio rate, slot b is control rate....
Now in slot a it will play a few octaves higher...
Nice stuff IK Smile
DSP audiorater.prf2
 Filename:  DSP audiorater.prf2
 Filesize:  6.88 KB
 Downloaded:  1604 Time(s)
Grtz Wan
Audio files: 233
PostPosted: Thu Feb 17, 2005 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like a CS80 to me...
ik
G2 patch files: 25
PostPosted: Thu Feb 17, 2005 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
... if it could run at audio rates (red/orange cables), so i tried to make it. And it is possible ...
Ha .. ha this is great ... so you fooled the system, and now it runs at audio rates. Very Happy Very Happy Very Happy Very neat trick ! ...
Let me try to do the same on the sawosc...
ik.
ik
G2 patch files: 25
PostPosted: Thu Feb 17, 2005 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Works!
It gives 2 more octave! (Try the switch.)
Also, look at the patch! Once you "fooled" the system, you can remove the extra units, it "remembers", and runs as "red cables".
For info, I left in the bottom-right corner the "trick" how to ...
Once the network "turns" red, it could be rewired as the original .. Very Happy .
ik.
sawosc2.pch2
sawosc running at audio (red cable) rate. :-)
 Filename:  sawosc2.pch2
 Filesize:  1.59 KB
3phase
G2 patch files: 141
PostPosted: Fri Feb 18, 2005 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice stuff IK Smile
I cant download this patch but the others...maybe a corruption?
Audio files: 233
PostPosted: Fri Feb 18, 2005 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Which patch do you mean? The all work for me.
3phase
G2 patch files: 141
PostPosted: Tue Feb 22, 2005 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
The posting of Wan cant be downloaded with my machine..all otheres get downloaded.
