play
Joined: Feb 08, 2004 Posts: 489 Location: behind the mustard
Posted: Thu Mar 11, 2004 2:29 pm Post subject:
that bouncing ball delay effect |
I call it exponential delay or dynamic delay depending on the flavor. I've attacked this problem from many different angles mostly using reaktor. It's actually quite simple. You can use any sequential curve to create the delay. In reaktor this could be an event table driven by a ramp oscillator with variable rate. The read can be triggered by a gate signal and the length of the read controlled using a simple time to frequency conversion. So the ramp runs through the various table values which control your delay and you can change the curve live. Alternately, you can use a decay envelope to drive the table.
Another method is to still use the envelope but instead of reading sequential table data to get the delay times you use a simple algorithm. For instance, use an attack-decay envelope to control the frequency of a pulse oscillator whose amplitude spikes trigger sample playback. A long attack time will give you that exponential division of time because of the icreasing frequency of the oscillator. Add some filtering and slight delay between multiple samplers and you're starting to sound like autechre. Or multiply the envelope by a controllable constant to produce delay times for a simple feedback delay. This gives you the felxibility to control the maximum delay time in milliseconds or synchronized with a tempo.
There are a lot more variations on this but there's basically two methods: one is to use a curve to control the triggering of sample playback and the other is to use a curve to control delay times in a feedback delay. I'm sure there are some other broad methods but these are the ones I've messed around with.
I'll post a couple of reaktor machines illustrating these techniques soon ::) |
play
Joined: Jan 31, 2003 Posts: 18313 Location: Durham, NC
Audio files: 235
Posted: Sat Mar 13, 2004 7:34 pm Post subject:
| Is the zip file a Reaktor file? Can you upload an mp3? |
play
Kruge
Joined: Dec 28, 2003 Posts: 106 Location: Bonn, Germany, Europe, Earth, Sol System, Milky Way, Universe, Multiverse etc...
Posted: Sun Mar 14, 2004 1:31 am Post subject:
Hint:
If you believe that fx like the bouncing ball delay, as you call it, are something *special* you never ever should have a look at Cool Edit - the effects available there might blow you away...  _________________ brielmusik myspace reverb nation twitter |
play
Posted: Sun Mar 14, 2004 3:12 am Post subject:
actually, cool edit was my first audio processing software. I love it and use it probably more than any other program especially since my laptop is a piece of shniz and so it's hard for me to do certain things realtime. The first tracks I ever made were all cut and paste.
the reason I posted this thread was because someone was asking about this particular effect in the movie music thread. It seemed like an opportunity for some fun nerdiness as well as to maybe demystify this simple technique that's becoming somewhat of a fad. I mean, I built 2 machines in reaktor that do it in under ten minutes. There's no black art. It's just linear math, envelopes.
so rock on! cooledit rules. I haven't seen audition yet but it appears to be the exact same thing as coolpro2 but with a different splash screen. |
Kruge
cloudscapes
Posted: Sun Mar 14, 2004 9:09 am Post subject:
Pretty cool, thanks! Up till now I've been using a VST for that effect. I give this one a try once I'm more familier with Reaktor. |
Audio files: 235
Posted: Sun Mar 14, 2004 9:51 am Post subject:
Thanks for posting the mp3. Now I know what you are talking about. I've heard this in a lot of IDM stuff. It's a good effect for that kind of music. I'm still going though exercizes on the G2, but that's a good one to add to the bag of tricks. Everything in my kit must be for live performance, ya know.  |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Sun Mar 14, 2004 10:38 am Post subject:
| Miscellaneous Autechre pieces and "Bucephalus Bouncing Ball" by Aphex Twin immediately come to mind anytime I hear such delay effects... Regardless, nice reaktor structures. I found your post and the models quite informative. |
Anig Browl
Joined: May 05, 2004 Posts: 20 Location: San Francisco
Posted: Thu May 06, 2004 12:08 am Post subject:
| noiseusse wrote: | | so rock on! cooledit rules. I haven't seen audition yet but it appears to be the exact same thing as coolpro2 but with a different splash screen. |
It is; I was using it 'for the first time' on a movie shoot last weekend, but I've been using CE forever as well and I couldn't see anything different other than the brand. Good on Adobe for getting it more visibility, though now it isn't such a 'secret weapon' any more...I've always been amused that the crowd goes for Sound Froge or Wavelab when CE is so clearly superior
I too like the bouncing ball effect (actually i feel like I could have written most of your post noiseusse...I did my first track in CE in a stereo edit as well). I had a random inspiration the other day and discovered that my Yamaha RM1x does this rather well, as it has a nifty little feature in the MIDI delay screen that lets you specify exactly how many MIDI ticks to lengthen or shorten the delay line with each repeat (up to 99). You can change the pitch and velocity offsets as well.
Despite only having a hamstrung version of the rather crap XG architecture and mediocre effects on the tone generator side, that blue box has so many neat little sequencer tricks that it'll always be a part of my rig (unless I get its big sampler brother). It lends itself very well to electro-type stuff. I anticipate some serious fun once I hook it up the G2 and start building MIDI loops... |
play
Posted: Thu May 06, 2004 5:32 pm Post subject:
| Quote: | ...I've always been amused that the crowd goes for Sound Froge or Wavelab when CE is so clearly superior :wink:
no doubt. i only hope that future versions will not become overbloated by adobe's plan to add lots of video support. i like having simple, fast tools that are specialized for their task and adobe has a tendency to write bloated software. hopefully CE2 won't be the last good version |
