281 clone project- taking orders now for last run of these..
Page 10 of 38 [926 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12, ..., 36, 37, 38 Next
interested in a PCB or 4?
yep
98%
 98%  [ 151 ]
nope
1%
 1%  [ 2 ]
Total Votes : 153
Peake
PostPosted: Sat Apr 05, 2008 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the points- I truly don't know these things, although I know what feature sets make me grin.
I mean to have the front panel jacks available for use -plus- a cv source/pot to send voltage to each CV in as well, -plus- another attenuated input for keyboard cv, so summing sounds like "it". If anyone wants to hold my hand a bit and/or is interested in this direction and is willing to post specific changes and designs to accomplish it, I'm definitely all ears. Thanks again topp.
It's a good point; these ARE controllers!
Luka, thanks, I'm going to have to take a closer look at the 200e. My experience is only with the 200, and it only has attenuators in particular places (oscillators, etc.). The old 257 CV processor did a -lot- but was by need of its complexity, a dual processor only. If such wonderful complexity is any sort of a problem at all..
neandrewthal
PostPosted: Sat Apr 05, 2008 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, so attenuators really aren't important for this module? Just curious topp, in the scope shot that shows the rising edge of one function modulated by another one, is there any attenuation of the CV signal? Theoretically I would expect that when you apply an unattenuated CV to a rising function, it would hardly move at all when the CV is low and zip to it's maximum value very quickly when the CV is high; but this is clearly not the case in that scope shot, just a smooth ripple effect all the way to the top. On my dual panel design I have the attack and decay CV going trough a dual gang pot and one function has a switch to unattenuate the attack CV, while the other has one to unattenuate the decay CV. Maybe I don't even need this? It does help fill up the panel while keeping it nice and symmetrical though.
toppobrillo
PostPosted: Sat Apr 05, 2008 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, it's up to you to make that decision. i realize it's hard to know until you actually get using this module.
nope. the control is set to minimum.
it's the opposite. the rise/fall time increases with positive voltages. since the control is set to minimum [0V], 0v in cannot make the slope any sharper- however a negative input voltage would.
Funky40
G2 patch files: 5
PostPosted: Sun Apr 06, 2008 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
when building it just with multiple outputs,
one can patch over something like the attenuverter from fonik.
I build usually my modules with multiple outputs,
and you can be shure that everytime i think those are not necessary,
i miss them allready in the first evening when patching.
In this case, i think it's really not important that the CV input atenuators are direct beside the module ( the buchla 281 clone ),
I think the shapes of envelops are a big issue, but it also has to turn out first how cool that shaping works on the B-284
----> multiple outputs Wink
/mr
PostPosted: Sun Apr 06, 2008 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are the volume faders important on your mixing desk? Wink
Signal levels are always important! To get really good use of a signal input, you always need to be able to adjust how strong that signal is. If an extra pot+knob is considered a waste of cost+work+space on a CV input, I'd consider the CV input jack itself to be even more waste - if it didn't get any pot.
Output level pots is not very popular, outboard attenuator modules still needs that extra hardware and scattered controls, and input level pots is the third alternative. The choice is up to everybody. Smile
It depends, maybe the applied CV can't modulate over the whole pot's parameter range.
Now I check the original Buchla 281 schematics, and I see that having the Attack pot at MAX (and no CV applied) is the same thing as having the attack pot at MIN and apply a CV of 15V. That is more than Topp modulated it with, so the rise speed was never near its maximum in this example. But you're completely right in your reasoning! Smile
neandrewthal wrote:
... one function has a switch to unattenuate the attack CV, while the other has one to unattenuate the decay CV...
"Unattenuate"?? Ah, I think I got it...
/mr
PostPosted: Sun Apr 06, 2008 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like the ordinary Attack / Decay pots? You won't need more of those. Smile
BEEP - BEEP - BEEP Shocked signal racism alarm! Shocked BEEP - BEEP - BEEP... Wink
Is it wrong to listen to the sound of a 500Hz signal if it comes from a module that is similar to the ADSR found in hardwired synths?
And what is the difference between a VCO and a VC-LFO?
If one thinks in terms of audio signals vs. control signals, one loses many of the beautiful benefits of the open modular concept and the principles of voltage control. Buchla and Serge made some of the most open and versatile modules ever, and it's almost blasphemy to call a Buchla module a "controller". Cool
(And you're already planning to add a keyboard CV input - well, then you have your b281 VCO right there!)
/mr
PostPosted: Sun Apr 06, 2008 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
topp wrote:
here are a few oscilloscope shots of the FGs to illustrate their operation sorry i didnt post these up sooner
Peake wrote:
I wanted to bring something up before people complete their front panels. The slopes of this envelope are linear. Grant Richter, in explaining the 281 and his own excellent Envelator, tells of feeding back some of the output CV to the time inputs, in order to continuously modify the slopes from linear through exponential through logarithmic, depending upon the voltage (positive provides one, negative the other, both in increasing depth).
Does Grenader still sell his miniPCB that provides a center-detented inverting attenuator, ala' the Serge and some Buchla modules? I can see having one for each envelope stage.
Ahh, the urge for CV attenuator knobs plus the two quotes above gave me an insight while sleeping tight tonight:
Add a CV attenuverting knob, like it or not. Feed back the output via the (switching! or bananas) CV input jack, and the CV attenuverting knob becomes a variable envelope slope control when nothing is patched to its input. Wohoo! Very Happy
Peake wrote:
Once you've played with continuously variable envelope slopes, you won't want to go back Very Happy
Darn, I think you're extremely right. Wink
Peake wrote:
A bunch of attenuators would so clutter a panel that it would be nigh unusuable (unless someone can prove me wrong).
I'm sure they don't have to clutter the panel very much, not much more than their CV inputs already do (which they don't).
Attenuators clutter a panel if they have unnecessarily big knobs and/or are placed in illogical locations. Another good way of making a bad panel design is to mount the panel components on PCBs and let this determine their position, rather than common sense, ergonomic and visual design, and usability. Embarrasingly many serious modular makers fall into ALL these traps... Rolling Eyes
neandrewthal
PostPosted: Sun Apr 06, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this gives me an idea for a new mod. Wouldn't you need some kind of switch to get a more narrow control range? Because if you were triggering your envelope in the audio range and you turn the attack and release knobs past say.... 5% of a turn, they would never reach their maximum value, unless you modified the range so that first 5% takes up the entire sweep of the pot.
Wasn't it buchla who physically segregated the audio and control by using different types of jacks?
Heheh. I just spent all the time since my last post trying to find a better use of the space the attenuator pots take up on my panel. Damn you for giving me second thoughts Wink It just occurred to me now that the reason attenuation is not important in topp's scope shot is because the modulating signal is much faster than the slope it is modulating. If it were the other way around it would be like a VCLFO and I certainly wouldn't want a VCLFO with no CV attenuation.
Anyway, what I came up with was to leave off the peak circuitry and replace it with a CGS Analog Logic board which provides the same functionality and more. The way the switching jacks were to be set up, for both the peak and trough(and and or) depending on which cables are plugged in they can compare the following signals:
A. Both function generators
B. Both function generators and one external signal
C. One function generator and one external signal
D. One function generator and two external signals
E. Two external signals
Now that I want the attenuators back I'll have to make some sort of compromise Evil or Very Mad
 Filesize:  34.32 KB
 Viewed:  193 Time(s)
Sound
PostPosted: Sun Apr 06, 2008 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't understand( maybe my english) could you explain that in other words Very Happy
About the attenuator point I'm very agree with you. It's clear that when I use my very nice VCS Bananalogue modules, when I plug the VC the first thing that I do is adjust the attenuator/inverting. A CV input needs an attenuator.
Clear, If you don't have the attenuator close the CV input you will tend to forget the CV Input but...
Take a look for example at the VCEQ-3 from Cwejman, It has 9!! CV inputs one for each three parameters of the three band/notch pass filters! So ! Is it necessary to add 9 knobs more?! Oh Man! my studio has 6m2!! Very Happy No! It is not necessary because you never will use the nine knobs at the same time! It doesn't have sense. It is better to have an attenuators module, because it is more useful and you save space. You assure that those attenuators will be always working. They will serve more than one module!
It seems that design a front panel means compromise! If you choose A win X but lose Y, If you choose B You win Y but lose X Very Happy
Good to read you /mr.
neandrewthal
PostPosted: Sun Apr 06, 2008 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's an awesome Idea! Now I really need attenuators, but arghhh. Something has to be thrown out the window. Either my CGS logic idea, or my personal panel principals where all the most tweakable controls (EG slopes, oscillator and filter tunings) get big knobs Sad
/mr
PostPosted: Sun Apr 06, 2008 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll try! Smile
Do you know what a swiching jack is? The type of jack that can have an internal "preset signal" connected to it if no plug is inserted in the jack. The Korg MS-20 has lots of them, for example.
Let the Attack/Decay CV inputs have switching jacks. Connect the 281 output signal internally to these jacks. Add an "attenuverting" knob to each CV input jack - which means the knob should scale the CV by a factor of anything between -1x and 1x.
Then, if no plug is inserted in the Attack/Decay CV input jacks, they will get the feedbacked output signal and their knobs will function as continuous slope controls fading between logarithmic-linear-exponential shapes. Like Peake's suggestion above.
(But if a usual CV signal is patched in, the slope will be linear.)
Yes!!! Shocked I know, it's weird - but yes! If you want true control of them.
In the semi-modular Cwejman S1/S2, the lack of CV Sensitivity pots on some CV inputs could perhaps be explained by the fact that the synth was primarily meant to be used under MIDI control, and you could route some MIDI/CV cable to the input and take care of the scaling in your computer instead. But in a fully modular system this doesn't really apply very well.
That's why I'm curious to hear... how do you prefer to use such modules, guys?
Yes, external attenuator (or "attenuvertor") modules can always be used - and yes, the number of attenuators can be much fewer than the number of unattenuated CV inputs, since you'll never use them all at once.
BUT: I'd love to see somebody make a rough calculation of a typical mid-sized modular system with lots of nice (but often pot-less) CV jacks and the number of external attenuators needed, and then count all the associated hardware needed for this. Skip the pots and knobs, but count the extra jacks - two at each knob - and the extra cables - one for each external knob in use. In case of attenuverters, count the components behind the panel - the PCBs, the electronics, the power connection. The extra power connectors needed in the main PSU distribution.
I get the feeling that this amount of hardware is getting comparable to the knobs that was eliminated in the first place. And the extra jacks take up panel space. And the knobs for CV Sensitivity end up off-module. And... even worse... clever bonus features like the "switched-jack connected slope control" above can definitely be forgotten! Crying or Very sad
Synth design is full of choices. Smile
Good compromises are everything. Very Happy
Machines that can do "anything" are boring. Sad
Now go make some fun modules! Cool
/mr
PostPosted: Sun Apr 06, 2008 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Buchla 284 Quad Voltage-Controlled Envelope Generator?
I can't find any good picture... this is one of the many modules that are unreadable on buchla.com .
Does anybody have a better pic, brochure pdf, etc?
neandrewthal
PostPosted: Sun Apr 06, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can say that again! Here is the 5th(and better be final Evil or Very Mad ) version of my panel. Compromises are the Attack/Release CV/Slope for each function are controlled by the same dual gang pot, and the amount of function A into the And + function B into the OR share a dual gang pot as well. I'd still like to be able to switch off one of the attenuators for each function, should I ever not want both the attack and release CV attenuated the same amount, but I don't have room for any more switches. Does anyone know where I can get a 16mm body, 1/4" smooth shaft dual gang center-detent pot with push-pull SPDT switch? Laughing
God, this thing's gonna be a nightmare to put together. 5 PCB's(including LED drivers), attenuverters on a perfboard, 8 switching sockets etc... but it'll be worth it Cool
 Filesize:  38.74 KB
 Viewed:  207 Time(s)
/mr
PostPosted: Mon Apr 07, 2008 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps it would be a good idea. I'd want to experiment with it before I finished my front panel design. ( Razz )
It's a lot like having a normal VCO with a Coarse Freq pot ranging over 15 octaves - it might be hard to tune it precisely, and even if you have an additional Fine Freq pot the frequency tuning might be disturbed if the Coarse pot doesn't keep its exact value.
True... and Moog did the same... Serge was the only example I should have mentioned here. But function-wise, in clones like this with one type of connectors everywhere, I think the Buchla designs are quite free of signal discrimination.
(Sorry to ruin this thread with loads of design philosophy (though, now is the time - after the build it's too late! Wink ) but is it known why Buchla started using two different connectors? The 200e site has a FAQ with 6 answers to this question at the bottom. I personally don't agree completely with any of those, hehe... and in addition some of them addresses the new digital stuff in the 200e system. What was the intention in 1963?
When it comes to Moog, different connectors were used for trig/gate signals. When Bob was here in Sweden to receive the Polar Music Prize in 2001 and we took him out on dinner, the question about different connectors was brought up. IIRC, he mostly claimed it was for practical reasons... and that it was better to only let customers be able to "connect things right" since they probably never wanted to connect things in other ways.)
clickmrmike
PostPosted: Mon Apr 07, 2008 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the idea, but I think your going to have to break down and go to a 3U panel...it's getting crowded in there!
clickmrmike
BananaPlug
PostPosted: Mon Apr 07, 2008 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Neandrewthal, maybe the thing to do is build the Analog Logic as a separate panel. More flexible that way too.
/mr
PostPosted: Mon Apr 07, 2008 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Definitely... and it's still just a dual Function Generator. The original b281 is a quad! Laughing
neandrewthal
PostPosted: Mon Apr 07, 2008 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can try all you want but I can never listen to reason Wink If it's too crowded I'll probably leave of the attenuverter circuitry. Actually, 2U is the maximum size I can make myself, so I just do those since I'm a cheapskate. I'm obviously gonna have to take a hit on the Klee and MFOS sequencer though.
I would, but I have this obsession with filling every square inch of panel space. Just a quirk I guess. I cannot stand to see one empty space that could hold another pot or jack. Also, the way I have it set up, you can still use the analog logic separately. You just have to turn down the hardwired attenuated EGs, then patching in the external inputs will override the unattenuated EGs.
BananaPlug
PostPosted: Mon Apr 07, 2008 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm with you in terms of not wasting panel space (raise a glass to Serge Tcherepnin). I think I made myself a little unwelcome on the Modcan Yahoo group for criticizing some of Bruce's decisions with respect to panel real estate.
I've found these to be good ways of getting a layout unstuck. In the spirit of Eno's Oblique Strategies use one of these to upset your thinking and then jiggle things around until it makes sense again:
Swap horizontal for vertical.
Use a different grouping paradigm.
Add or subtract a multiple (e.g. single, dual, triple, quad...).
Add or subtract features.
Pair it up with something relevant (e.g. your idea of the CGS A-Logic)
As a last resort, if you have leftover space for three holes add an independent voltage scaler: in, knob, out. You can build this on a scrap of perf board about the size of a postage stamp and a attach it behind the pot.
Audio files: 235
PostPosted: Mon Apr 07, 2008 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I was building stuff a long time ago, I would put in unconnected jacks where there was extra space and label them "exceptions".
Peake
PostPosted: Mon Apr 07, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Technosaurus fill every space in their patchbays with jacks, and those that are unused in the module itself are linked as multiples.
"Source of Exception"? Smile
neandrewthal
PostPosted: Mon Apr 07, 2008 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
My picks for best and worst use of extra panel space.
Best: http://www.wiard.com/modular/waveform_city/waveform_city.html
Worst: http://synthesizers.com/q116.html
runner up: http://www.synthtech.com/motm320.html
clickmrmike
PostPosted: Mon Apr 07, 2008 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why the 2U limitation? Are you fabbing your own metal, or using pre-painted blanks? Commercial blank MOTM-format panels are available in sizes up to 4U. I'm trying to go larger, but the paint is hard to match...I'd like to do my Klee at home, too. PM me if you want to exchange fabrication ideas.
clickmrmike
Sound
PostPosted: Tue Apr 08, 2008 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
/mr wrote:
I'll try! Smile
Ah! This is the behaviour of my very nice Bananalogue VCS modules. When their CV inputs are unplugged the CVattenuators work as continuous slope controls fading between logarithmic-linear-exponential shapes.
But they make it in another way because I don't see any swithching jacks.
But is it so easy? Only connect the output to the CV input?
I think you are right... It have sense. Also it's more fast and intuitive to have the attenuator close the CV input... I'll think more about that!
toppobrillo
PostPosted: Tue Apr 08, 2008 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
doesn't it have pull-switch pots?
But is it so easy?
basically, yes.
